received my clear corners for my 04 tundra DC today from
ebay, took about 10 min to put them on, the longest part was figuring how to take the originals off. they were harder than i thought. after you remove the anchor/screw from the top, pry the bottom lens using a flathead screwdriver, make sure to use some foam or rubber on the bottom so you will not chip any paint, after that they should pop right off. they look great on my black tundra, ill post some pics if you guys want.
