Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
  #16 (permalink)
Old 02-27-2002, 06:40 AM
Last Online: 02-16-2003 05:10 PM
SCtundra is on a distinguished road.
SCtundra's Photo Albums
Default Re: Bedliner advice needed....(and hitch info)
The coupon is for $20. The $320 includes this discount. Thanks for the advise anyway. I can't wait to get it done
  #17 (permalink)
Old 02-27-2002, 07:33 AM
Last Online: 05-06-2005 08:09 PM
TundraGuy is on a distinguished road.
TundraGuy's Photo Albums
Just out of curiosity, Does anyone know how much LineX weighs compared to a drop in liner?
Sean
  #18 (permalink)
Old 02-28-2002, 10:48 AM
Last Online: 12-03-2004 03:06 PM
LINE-X is on a distinguished road.
LINE-X's Photo Albums
Sean,
They should be pretty close on the wieght. Generally 35-40 pounds depending on size of truck and type application.
  #19 (permalink)
Old 02-28-2002, 08:36 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
My Tundra's DrawTite receiver with six frame bolts is rated at 5000# for weight carrying (I'd never tow that much that way) and 8000# with a weight distributing hitch (exceeding the Tundra's capacity). Both DrawTite & Reese are brands of Metaldyne Corp. http://www.metaldyne.com/Tow.html Your Reese receiver really should have a capacity label on it. If the receiver is rated at 5000#, it's Class III. If it's rated higher with weight distributing, it's Class IV. What is the virtue of the two additional bolts into the bumper? The bumper is bolted to the frame anyway.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
  #20 (permalink)
Old 03-01-2002, 05:24 AM
Dealer : McGeorge Toyota
2001 Toyota Tundra,
2004 Toyota Sienna,
2007 Toyota Prius
Last Online: 11-21-2009 11:57 PM
userw5 is on a distinguished road.
userw5's Photo Albums
My Factory Toyota is rated as a class IV hitch as is. That's correct the bumper is bolted to the frame, which is the last cross member. The additional bolts tie the hitch to the last crossmember along with the lateral frame rails giving you a stronger application.
Jeff
  #21 (permalink)
Old 03-01-2002, 09:21 AM
fletch's Avatar
Last Online: 01-09-2007 12:54 AM
fletch is on a distinguished road.
fletch's Photo Albums
I got under the truck last night with a flashlight and did find a label on the hitch. It says the hitch is rated at 5000lb for V6 and 7200lb for V8 so they are just going by the truck ratings. The included drawbar says its rated for 6000lb so not sure whats up with that. Date of manufacture is Jan 31,2002 so I am guessing this is a new model (Reese 38555) and thats why they have zero info about it on their site. Reese still has not replied to my request for info on the hitch as of this time. As far as the liner goes, I got an email that gave me a great idea and its basicaly the same thing my dad got in 1985. Get the line-x and have them put the toyota drop-in back in afterwords. Anyone see a problem with this?
Thanks, Fletch
  #22 (permalink)
Old 03-01-2002, 11:12 AM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Fletch,
The truck and the receiver are only rated at 5000# tow weight and 500# tongue weight without a weight distributing hitch, so the 6k# drawbar is more than enough. The label you saw on the receiver probably referred to spec V-5, not a V6 engine. V-5 is a Federal hitch specification.
Ken
  #23 (permalink)
Old 03-01-2002, 01:03 PM
punisher's Avatar
Dealer : Carson Toyota Scion
Last Online: 02-09-2009 03:49 PM
punisher is on a distinguished road.
punisher's Photo Albums
per manufacturers specs. the tundra v8 is rated to tow 7200 pounds, 4x4 7100.
  #24 (permalink)
Old 03-01-2002, 07:09 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Originally posted by fletch
Thanks , will look again tonight. I am pretty sure that the V8 version of tundra is rated for 7200. I think 6 is lower though. Bumper mount is rated for 5k on both. I am going on memory so I could be wrong...
Agreed, the V6 is rated to tow 4900# to 5250# depending on cab size (weight, really) and transmission type. Anyway, the sticker on the receiver doesn't relate to the engine, just to weight carrying or weight distributing capacities.
Ken
  #25 (permalink)
Old 03-01-2002, 10:48 PM
Last Online: 04-08-2002 02:38 PM
cufh is on a distinguished road.
cufh's Photo Albums
quote: As far as the liner goes, I got an email that gave me a great idea and its basicaly the same thing my dad got in 1985. Get the line-x and have them put the toyota drop-in back in afterwords.
If you are getting Line-X, why bother with the crappy drop-in? Line-X will look way better, and things won't slide around as much. Ever put a 5-gallon bucket in a bed with a plastic liner? You hear it bang every time you start or stop!
  #26 (permalink)
Old 03-01-2002, 11:03 PM
Dealer : Larry H. Miller Toyota
2006 Toyota Highlander,
2008 Toyota Tundra Slate Limited
Last Online: 11-17-2009 07:21 PM
Images: 1
Larry Lawton is on a distinguished road.
Larry Lawton's Photo Albums
IMNSHO (In My Not So Humble Opinion), you really ought to secure your load so it doesn't slide around, no matter what bedliner you have. I've cut a piece of stretchy nylon rope a little longer than enough to go from the right rear cargo tie-down to the front right, front left and rear left. I leave it tied there all the time. A single item slips under the rope. If I need to tie down more than that, the rope is right there.
Larry Lawton
Retired in Wyoming
  #27 (permalink)
Old 03-02-2002, 12:55 AM
fletch's Avatar
Thanks , will look again tonight. I am pretty sure that the V8 version of tundra is rated for 7200. I think 6 is lower though. Bumper mount is rated for 5k on both. I am going on memory so I could be wrong.....Fletch
