This is a discussion thread titled "How do I "zero" the tripometer", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Old 06-12-2002, 02:50 PM
mike.elmes's Avatar
Dealer : Sun Toyota - Edmonton
Last Online: Today 07:50 PM
mike.elmes is on a distinguished road.
mike.elmes's Photo Albums
Question How do I "zero" the tripometer
I hate to post such seemingly trivial stuff here but I can't seem to zero the tripmeter.
need help
Old 06-12-2002, 02:58 PM
Simias's Avatar
Dealer : Carson Toyota Scion
2001 Toyota Sequoia 2WD SR5,
2004 Toyota 4Runner 4WD V8 Sport
Last Online: 11-14-2008 09:49 PM
Simias is on a distinguished road.
Simias's Photo Albums
just keep the button depressed until it zeroes out. this works for the sequoia, so i assume this works the same for the tun. hope that helps!
Chris
2001 Sequoia 2WD SR5
Mods:
Rollers - 18x9 JAOS Super Ziga wrapped w/ 285/65 BFG A/Ts, Suspension: SAW 2.0 Adj. Coilovers, UCAs, Rear Coilspacers I.C.E. - Clarion H/U w/ built in monitor, DVD Player, Drop Down, Headrest Monitors, Exterior: - Stock OEM Foglights, Wings West Spoiler, Engine: TRD Drop-In Filter
Old 06-12-2002, 03:00 PM
cslinger's Avatar
Dealer : Beaman Toyota Co.
2002 Toyota Tundra
Last Online: 10-30-2008 02:04 PM
cslinger is on a distinguished road.
cslinger's Photo Albums
Simply use the stalk to get to the trip meter you want to zero. Once there just push th stalk in and hold it until the trip meter zero's out. Should only take a couple of seconds of constant pressure, maybe 3 seconds.
Chris
Ok, I must have replied at the same moment as the other guy. Hows that for service, form two Chris' at that.
Old 06-12-2002, 03:12 PM
mike.elmes's Avatar
Thanx guys,
I will try later. Makes sense though.
Old 06-12-2002, 04:41 PM
Dealer : Stevens Creek Toyota
Last Online: 11-25-2008 12:55 AM
akauth is on a distinguished road.
akauth's Photo Albums
Chris
Don't hold it too long, too. I did and it cycled onto the next one (b) after a while and zeroed that one out too. I use the (b) meter for Oil change intervals.
Maybe I accidentally let off and then pushed again, but I don't think so.
Anyway, a warning. Too, you can try to zero both if you wish that way (holding it down until they both clear) and see if it was just my mistake in letting up a bit, then pushing down.
Alan
Old 06-13-2002, 01:20 PM
TIGERTUNDRA's Avatar
Dealer : Toyota of Richardson
2001 Toyota Camry CE white,
2002 Toyota Tundra Desert Sand TRD 2wd
Last Online: 03-16-2007 11:45 AM
TIGERTUNDRA is on a distinguished road.
TIGERTUNDRA's Photo Albums
Alan
what a great idea
Old 06-13-2002, 01:28 PM
mike.elmes's Avatar
Thanx all,
I tried it last night and ...of course, it worked. I second the notion,
a really great idea using the (b) meter for oil change intervals.
Old 06-13-2002, 02:20 PM
SATundra's Avatar
Dealer : Alamo Toyota
Last Online: 01-01-2009 05:17 PM
SATundra is on a distinguished road.
SATundra's Photo Albums
Alan
I do the same thing. I use the A meter for checking my MPG. The B meter to keep track of miles for my oil changes. BUT I also put one of those oil change stickers on the top left inside of my windshield with the oil change mileage written there too. Never can be sure when you will have to dis-connect the battery, which will erase your settings I believe.
SATundra
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 06-14-2002, 11:05 AM
Dealer : McGeorge Toyota
2001 Toyota Tundra,
2004 Toyota Sienna,
2007 Toyota Prius
Last Online: Yesterday 09:13 PM
userw5 is on a distinguished road.
userw5's Photo Albums
SATundra
Ditto, here with the tripmeters. Now I just wish they had a Trp C so I could keep track of miles on road trips.
Jeff
Old 06-14-2002, 02:06 PM
Jeff
See, in the old days you could change the oil before you take the trip and the b meter could be your "road trip" meter too. So what if you changed the oil a few hundred or even a thousand miles early.
Today, that's not so easy. But even more so, I really don't recommend anyone EVER change their oil immediately before they go on a road trip. Give it a few days to settle in and see if something happens when you make a change on the vehicle - any change.
On the surface it seems like a great idea, but in reality most failures happen right *after* you've made a change. And if the failure happens (for whatever reason) you're a long ways from home and basically screwed for a while. So while you'll have nice clean oil, your chance for a problem in the middle of the trip are increased due to the change that "didn't take" properly.
The other time things happen, of course, is when you've not checked it for too long a time.
Alan
Old 06-15-2002, 03:10 AM
randyeverett's Avatar
Dealer : Coad Toyota
2005 Toyota Tundra,
2008 Toyota Rav4 Limited, V-6
Last Online: 07-27-2008 08:48 PM
randyeverett is on a distinguished road.
randyeverett's Photo Albums
Default road trip
Alan is right about not going on a trip immediately after changing your oil. I rented a car in Kansas heading to Denver a couple of years ago. A new Tauras, 24v, 6cl,---------peppy and fun to drive. Had to wait a few minutes as it was being serviced.
As luck would have it---------and having a bladder the size of a walnut--------I had to stop after only an hour (and about 100 miles-- like I said, it was fun to drive). As I pulled up to the station, smoke started pouring out of the hood, fenders, wheel-wells, everywhere. Oil had blown all over the engine compartment, transaxle. Oil cap was on and I couldn't find the source of the leak. Let it cool and then topped it off with $3.00 a quart oil X 3 and got back on the road.
I dumped it off in Hays, KS and rented the only vehicle available-----a mini-van, God help me. NOT a fun vehicle.
So, I agree, give it a few days after an oil change-----or any repair-----before taking off on that road trip. Same goes for a new vehicle. IMHO
Randy
Great Apes are not great......they're just big gay monkeys.
Bone-stock 05 Access Cab Tundra, V-8, 4x4, TRD Off-Road w/LSD, Spectra Blue Mica
05 Camry LE, 4cyl
Old 06-18-2002, 12:12 PM
Dealer : Oakbrook Toyota In Westmont
2002 Toyota Tundra,
1999 Toyota Camry,
2005 Toyota Camry,
2007 Toyota Tundra DC 4x4 1D6/Black Bnh
Last Online: Today 11:10 AM
RichR is on a distinguished road.
RichR's Photo Albums
Hell, I did it on my Tundra and the womans Camry in the same week.
Rich
Former Dodge Boy
Now a Toyota Man
Proud to be doing
Life@TS
Bookmarks
