OK, just did this myself and it's amazingly easy. Don't go to the dealer to have this replaced. Sorry the pictures are a bit dark, but they're good enough for you to get the idea.
Part Numbers (for 2000 AC, Oak interior)
62910-34012-E0 (Passenger side)
62920-34012-E0 (Driver Side)
Step 1) Remove the door panel - Remove the two phillips screws, and the trim ring from around the door handle. The trim ring can be tough to remove, it does come off with a bit of force. After those are removed, I start at the top and work my hands behind the panel and pull firmly straight outward. The trim buttons should pop loose. Work your way down around the edges until the whole thing pops off. Click here for picture
Step 2) Remove the two 10mm bolts from the frame, then the phillips from the window. Make sure to remove the foam gasket if it sticks to the window. Click here for picture
Step 3) Open the new lock and put the Phillips side of the replacement hinge on first. Then bolt the hinge to the frame. Don't over tighten the glass side...it is after all, just glass. Click here for picture
Step 4) Replace the door panel, trim ring, and screws.
That's it!
Genthar
Awesome. Mine just broke as well and I was planning on replacing them this weekend. I have been staring at the door all week trying to figure out how it comes apart without breaking anything.
Thanks for taking the time to post such detailed instructions.
That's it!
For listing and showing the proceedure.Passenger side broke last night.
I hope I can get both parts quickly.I'm gonna attempt this even though I have TimTayloritis
Former Dodge Boy
Now a Toyota Man
Proud to be doing
Life@TS
np.
Also note that these are complete replacements of the hinge, you cannot buy one half or the other, it's the entire hinge from the door frame to the window. I don't know what the part numbers are for different years (or even if there is a difference) or different color interiors.
Parts cost me $27/each at the dealership.
Genthar
That's it!
Unless being covered under warranty right. I took my truck to the dealership to have my passanger quarter window latch replaced last month. I took it to the dealership not because it was hard to replace but because they picked up the price of the part and labor. My cost $0 .
2003 Tundra Imperial Jade TRD offroad Performance modifications
2.5 Camburg C/O w/ King 14" 600lb springs, Skidrow Automotive Skidplate
285x75x16 Goodyear Wrangler ATS, 16x8 Ivan Stewart Wheels
4.30 ring and pinion gears, Stock exhaust w/ Magnaflow 18" muffler, TrueFlow filter, Superlift TruSpeed Cosmetic modifications
Debadged, De-decaled and De-labeled sun visors
Pace Edwards Retractable Cover, Toyota Sport Grille
TRD radiator cap, TRD oil cap
RS 3200 Plus Upgrade Modification wishlist
TRD or JBA titanium headers
JBA or possible custom y-pipe
TRD supercharger
IPT valve body mod
Custom Offroad Bumper
Demello offroad sliders
rear disc conversion
Moonroof and power sliding rear window
Where does it ever end
Of course. But someone not too long ago posted that they were charged $100+ to have this repaired at the dealer! If you're out of warranty just fix this yourself, it's really not that difficult.
Genthar
Thanks Genthar!!,
I finally found a roundtuit and replaced the broken and the other latch.
It was fleet maintennace last weekend.
Only been almost a year.
I read and re-read your post to really get the picture.
Thanks for helping all TSers.
Former Dodge Boy
Now a Toyota Man
Proud to be doing
Life@TS
Make em out of metal, then they never break! I did.
Like many of you I had both my original latches replaced under warranty despite the fact that I rarely opened those windows, becase the cheap plastic link cracked, and the replacement links started cracking in the same place a year later.
I am very disappointed to learn that they haven't improved the parts, and that they only sell them as part of a very expensive latch assemble. Shame on Toyota.
Not about to spend the money for new ones, I got some small pieces of aluminum and made a pair of replacement ones that should never break. I used the broken ones as a guide and used a die grinder with a carbide bit to do the final shaping. They look and work just like the original ones, and only look different becase I left them bright aluminum instead of painting them black.
Final cost to me, about 1/2 hour of my time, and $0.50 cents worth of aluminum.
Great idea Anamouse! I have the same problem, and would like to try your solution. Could you tell me where I might look for a piece of aluminum stock like you used?
Re: Make em out of metal, then they never break! I did.
I haven't looked closely but how are the old links put in? Is it some type of screw that can be reused, pop-rivet or steaked in pin?
If anyone knows where I can get a pair of the aluminum links, please drop me a line. Willing to pay for anyone's time, materials and shipping if I can get a couple...not interested in paying dealer prices on something that's likely to break again before too long.
Thanks, Fastman...any idea how I can contact the person in the know? Also, how much were the links as part of the group buy? There are some on ebay for $50...
Regards,
Read over the Group Buy forum with window latches.
