Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
  #31 (permalink)
Old 03-11-2007, 11:52 PM
Dealer : Menlove Toyota
2004 Toyota Sequoia
Last Online: 03-08-2008 04:56 PM
rleighter04 is on a distinguished road.
rleighter04's Photo Albums
Default Re: Installing Overhead Info Console
Originally Posted by Tytanium View Post
Metts,
That info may be a huge help - I'll look into this later in the week. I'm hoping it helps to narrow down the 7 P/Ns to a more reasonable number for the harness in the pillar. Hell, of it came down to two $25ish harnesses I'd get tham both and eat the loss on the wrong one just to get this little project finished and a working solution for the group.
Thanks a bunch.
T
I have an 04 sequoia that did not come with an info center, I took the overhead console down and the part number for the roof wire for no info center is 82171-0C 061 so you can cross that one off your list . It only has a plug for the map lights. I'm doing the same thing I bought a overhead console on ebay from a 06 Sienna. I'm going to take the info center out of it and attempt to install in my Sequoia I will keep you all posted of my findings and of course will be watching your posts for information as well.
Thanks R.
  #32 (permalink)
Old 03-13-2007, 06:54 AM
Dealer : Germain Toyota Scion of Sarasota
Last Online: 04-10-2008 07:24 AM
Phozmo is on a distinguished road.
Phozmo's Photo Albums
Thanks R.
I learned the hard way that the info center from the Sienna is a different size than the one in the Sequoia/Tundra. I couldn't get the Sienna one to fit in my overhead console.
I have one of the wire harnesses on order from the local dealer and will post once everything gets here and is installed.
  #33 (permalink)
Old 03-13-2007, 11:40 PM
2004 Toyota Sequoia
So what did you do? was it larger or smaller? was it goofy or can it be modified to fit?
Thanks,
R.
  #34 (permalink)
Old 03-14-2007, 08:10 PM
The one from the Sienna was just a little bit too big to fit into the Tundra opening. A steady hand with a Dremel could probably make the hole big enough to fit but I'm not sure about the angles of the glass matching the angle on the console itself...
Why Toyota would take on the costs of two different meters when the consoles themselves are virtually identical between the Sienna and the Tundra/Sequoia is beyond me.
I ended up putting the Sienna one in my dad's Sienna when they were over this weekend and pulling a Sequoia one from a junkyard for the Tundra. With any luck the harness will be at the dealer by Friday.
  #35 (permalink)
Old 03-18-2007, 08:47 PM
metts's Avatar
Dealer : Taylor Toyota
2004 Toyota Tundra
Last Online: 09-07-2009 04:10 PM
Images: 3
metts is on a distinguished road.
metts's Photo Albums
Well I was able to find the other end of the wiring harness for the overhead console. It plugs into the back of the fuse box. If you are looking at the fuse box it plugs in the top left corner. Since it is in the back it is hard to get to, but I was able to do it.
Now I just need to buy the correct wire from Toyota and we'll be in business.
  #36 (permalink)
Old 03-20-2007, 11:44 PM
2004 Toyota Sequoia
Let us know what you find out on the part #'s for the harness (roof Wire)
R.
  #37 (permalink)
Old 03-25-2007, 09:01 PM
I'm pretty sure that it's NOT part number 82171-0C070 (Sequoia SR5 w/ Accessory Meter). That's the one that I ordered and the end plugs are rectangluar instead of the the square that, at least at the console end, is needed.
  #38 (permalink)
Old 03-26-2007, 01:00 PM
metts's Avatar
2004 Toyota Tundra
Images: 3
That's strange. I remember my plugs being rectangular. I'll have to double check after work today. Are you returning the one you bought, or selling it?
  #39 (permalink)
Old 03-26-2007, 11:34 PM
2004 Toyota Sequoia
My Sequoia has a rectangular plug in the overhead that connects to the lights right now,but most of the info centers I've seen have a square plug coming out of them. I think there must be a wire we are missing, that the rectangular connects to the square plug in the info center. Maybe if someone that has a Sequoia with the info center could tell us how the roof wire connects to the info center.
R.
  #40 (permalink)
Old 03-27-2007, 06:42 AM
metts's Avatar
2004 Toyota Tundra
Images: 3
My Tundra had a rectangular roof wire plugging into the lights. When I installed the new console with the meter the roof wire plugged right into it. Unfortunately the roof wire only has 2 wires and the console about 8-10.
  #41 (permalink)
Old 03-29-2007, 03:03 AM
Dealer : Larry H. Miller Toyota
2005 Toyota Tundra
Last Online: 03-30-2007 01:17 AM
05ltd is on a distinguished road.
05ltd's Photo Albums
This is strange, I have an 05 Tundra limited that came without the temp/compass/homelink overhead console, so I bought one (used) with all that stuff out of an 06 seq. It plugged in just fine, but the compass was way out, so I just started messing around with it and pretty soon the compass started working fine, then, because of what I had heard, I never really worried about the outside temp as I thought it was going to be a mess to wire in, so I just looked at the dashes for awhile, then finally today I decided to order the ambient temp sensor and plug it in (dealer had it in stock) low and behold----it worked immediately---no wiring, no nothing, just plug and play??? Go figure? How did I luck out?
Pretty strange, it sure is nice to have one now!!
Thought some of you might find this interesting?
  #42 (permalink)
Old 03-29-2007, 06:49 AM
It sounds like 05ltd has the roof wire and part number we all need.
Is there any chance you could look at the sticker on the harness and let us know what the part number is? On the harnesses I've seen, the sticker is about six inches from the plug so it's likely under the headliner but towards the console end.
  #43 (permalink)
Old 03-29-2007, 10:38 AM
Dealer : Toyota of Greenville
Last Online: 11-23-2009 08:48 AM
T-Nick is on a distinguished road.
T-Nick's Photo Albums
I ordered all the parts today. For the wire I used metts list to oreder the one for mine. I will let you all know if the install goes smooth.
BTW toyotapartsales.com had the best price for all the parts even after shipping. ebay was a fight for the console though.
  #44 (permalink)
Old 03-29-2007, 08:12 PM
metts's Avatar
2004 Toyota Tundra
Images: 3
I ordered the parts today too. I've been planning to go to the dealer but never got around to it. Everything was easy and cheaper at toyotapartsales.com
I'll let you know how the install goes when everything is delivered.
  #45 (permalink)
Old 03-30-2007, 01:16 AM
2005 Toyota Tundra
I would be happy to, it only takes a couple of minutes----so I will do it Saturday and let you know.
2005 Tacoma In-Cab power Outlet sbessel Member Mods 0 03-22-2005 10:00 PM
Tacoma: 05 Overhead Console Removal Don Presten Interior & Exterior 6 03-19-2005 04:49 PM
Tapping power from overhead console - Tacoma Don Presten Audio & Stereo 3 03-02-2005 11:54 PM
Where to buy replacement bulbs for buttons in overhead console ? ctedja 1Gen-Sequoia 1 11-29-2004 04:00 AM
Need info. on console add-on Mercer Interior & Exterior 1 01-13-2004 12:25 AM
