This is a discussion thread titled "foam padding under lid keeps squashing out", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
About every six months I have to go back to my ARE installer so they can redo the adhesive foam strips (the ones that go between the lid’s metal rails and the truck bed rails). Initially there was only one layer of foam, but that kept the lid too close to the bed rails and the lid scratched the bed rail.
To counteract this, they doubled up the foam to make it thicker. But it ends up squishing out. I don’t know if a single layer would do this as well, but apparently they don’t have any thicker stuff to use. Has anyone run into this and solved it?
I had a simular prob with the install of my tool box, rattled when it was on the rails. I went to the local ACE hardware and got some adhesive weather striping, 4 different thicknesses to see what worked best. Stopped that rattle and with just a single strip is squishes out ok to actualy seal. so I used it on my old 74 ford to seal the canopy on worked real good. Just let the adhesive sit for about 12 hours in temperate environment, to set up and you should be good. I have had the stripping on for 6 monthes outside and NO complaints. Also it will stick to the bed caps. Good Luck.
Originally posted by frankie stockboy About every six months I have to go back to my ARE installer so they can redo the adhesive foam strips (the ones that go between the lid’s metal rails and the truck bed rails). Initially there was only one layer of foam, but that kept the lid too close to the bed rails and the lid scratched the bed rail.
I have the ARE lid on my ride for last 18 months, and have not run into that problem. You may have already tried it, but, with the proper height adjustment on your rail stops, you should not have this problem. It sounds like your lid is set too low or close to the rails. My lid sits about 3/8" above the bed rails. I check the stops frequently to make sure they are tight. My lid has not touched the bed rails since install. Just a thought to consider.
__________________ John ..Sí, Dorothy, there is no place like home..!
The Toy: 2000 Tundra 4.7L TRD Limited 4x4 Red Pearl (22k Original Miles)
Interior:TRD Luxury Sport Leather|TRD Mats,Seat Belt Pads|2003 Console|Gentex Temp Mirror|Stratos Sunroof|15% window tint|Back Seat & Map Light mods|"Tundra" logo sill protectors|Alpine IVA W205|JL components|Fosgate Amps| Q-logic|Blackbird Nav|
Exterior:TRD Ivan Stewart Conversion|TRD IS 16" wheels|265x75 Toyo AT's|ARE LSII Tonneau|WeatherTech visors|Debadged|Muth Signal Mirrors|Color keyed Mirror Housings,Tailgate handle|Clear Corners front|C-Red-C Tails with color keyed surrounds|Bedrug|Fire Extinguisher|Toyota Emergency Road Kit|Ground Effects Step Bars|TRD Windshield Graphics,gas cap,license plate bolts|18" Powdercoat Antenna|PIAA lighting upgrade|Paint maintained w/ Klasse Products|
Engine/Driveline:TRD LSD|Red powdercoat Hellwig Sway Bar w/Poly bushings|TRD Red/Blue Bilsteins|TRD Red powdercoat Coils|2" Cornfed Spacer in Red powdercoat|Red powdercoat front Sway bar |Red PVC SS brakelines|Red Calipers|Frozen Cyro Slotted Rotors w/ceramic pads|Powdercoat Skid Plate w/SS hardware|TRD Headers (polished)|TRD oil-radiator caps|AEM Intake|Optima Red Top Battery|Complete changeover to Red SVH for all hoses|SS Metric bolts|Colorkeyed Brackets in engine bay|Gloss Black undercarriage complete| SS custom dual exhaust| PPD TB cover and Fuse cover|Blaster Horns|
I do adjust the rail stops, but those are placed at the rear and middle of the bed. There's no clearance problem there. The rubbing occurs right by the hinge, which has no height adjustment, other than the thickness of the foam padding. Guess I'll look into thicker foam.
[font=Arial]
I was also looking into an alternative to foam weatherstrip between the bed rails and camper shell. Was wondering if anyone found a thick rubber gasket material made for our trucks or just a better weatherstripping?
Mine seems to squish out over time and its a pain to replace.
Thanx,
Michael
I went back to the ARE dealer and they're now using a thicker, heavier duty foam. I had them redo mine. Unfortunately, I had to pay about $40 for it (wasn't the same dealer I bought lid from) and ARE itself was less than helpful in reimbursing me or even caring. The good news is that I had it redone over a year ago and it's still holding up like a champ--no squishing out!
