No matter what brand wipers I use (I've used Toyota, Bosch Micro Edge Exel, Piaa, etc) they ALL still create some type of haze!! I just recently changed my Toyota wipers to the Micro Edge Exels because the Toyotas were pretty worn, however the Exels still create haze on the windshield. I have not used Rain-X at all recently (meaning past 6 months). I even used rubbing alcohol to remove the Rain-X when I did use it a while back. I've also used No Touch Auto Glass Stripper to remove any of the silicone provided by the Piaa silicone wipers back when I used them nearly a year ago as well. The No Touch worked temporarily.
Do fellow Sequoia owners have a similar problem with thier wipers creating haze on thier windshield or is it just me? Could it be the windshield itself thats causing the problem?
No Touch Auto Glass Stripper is good stuff. You might need to use more until that haze is finally gone. I haven't found anything else that removes Rain-X, not even laquer thinner, and you might still have some on the glass.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
believe it or not but coca-cola will clean any residue off of glass, including oil or silicone. just pour it on wipe it down good and rinse very well, it wont hurt the paint like some other stuff will.
__________________ HAVE YOU DRIVEN OVER A FORD LATELY?
Team West SAWS (cranked up to 3.25")
Total Chaos UCA
ORS Manual hub kit
reese front receiver hitch
10,000 lb. winch on receiver hitch
Warn Quick connects front and rear
rear brake porportioning valve mod
3" perfomance products body lift
skyjacker AAL
wheelers urithane kit for front swaybar and steering rack
BFG AT's
Eagle101 wheels
CB radio W/ dual fiberglass 48" ant.
Coca-cola?? Impossible......how so? This is not a joke is it?
If you ask me, buffing glass wont be THAT much more effective that hand applying. What you should do is just get a car polish(megs deep crystle for OTC buyers) and polish your windshield. Then apply a sealant or wax such as megs NXT or other such OTC brands. If it does not clear up after that, try a new windshield like I did!
__________________ 2003 Toyota Tundra V8 4x4 AC Exterior: Trd Off-Road package, Trd Skid Plate, Borla Side Exit Exhaust, 15% Lumar tint, Enkei Deep Six 20's, 275/55/20 Scorpion ATR, Bilstein 5100's, Toytec add-a-leaf, UWS Lo-Pro Toolbox Interior: Alpine 9851, CDT 6.5" components, Alpine MRP-F240, MRD-M300, ED SQ 10, Ruger SR9 9mm in the console.
Showroom Shine Details Premium Automotive Detailing
www.ShowroomShineNC.com
But it doesn't clean very well, and leaves a mess. If the carbonic acid in the soda reallyd oes clean, use club soda...at least it won't leave a sticky brown mess. http://www.breakthechain.org/awards/0307.html
Ken
Ken
to each their own, but I have used it for battery terminals and to get road sludge off the windshield and dead bugs off the bumper grill and windshield...all worked surprisingly well. as to the break the chain link, If you are aiming to debunk something then thats usually what happens.
Total Chaos UCA
ORS Manual hub kit
skyjacker AAL
BFG AT's
Eagle101 wheels
Try this: http://www.properautocare.com/glassscrub.html , I bought some at my local Auto Barn. Haven't tried it yet though. Do you use the windshield squirter a lot? What is in the bottle? What kind of fluid do you use? I had use the Rain-x fluid for a while but it left white spots all the time but did add a little to the beading performance longevity. You might want to flush the bottle and or try some white vinegar also. The acidic properties have helped many with the hard water/mineral stains/spots from sprinklers etc. Might want to just run some through your system once emptied. That what Mr. Coffee and other recommend to clean your coffee maker from scale and build up from the water. Just make sure to wash the truck afterward.
I took my '04 Sienna in for servicing, and they took it upon themselves to change my wipers, which were working fine. Since then I have had a haze on the windshield when it rains and I have to use the wipers. I went back twice and had them change the blades, to no effect. I was told to give it a while and it (might) wear off. Good answer. This was almost two months ago, and still haze. I've tried No Touch, changed the driver's wiper (have to try the passenger) and used comet, which was recommended by a glass company. Still haze.
