removal of lowest middle dash panel (with cig outlets)
+ Reply to Thread
Results 1 to 2 of 2
Thread: removal of lowest middle dash panel (with cig outlets)
  1. #1
    Junior Member seto is on a distinguished road.
    Join Date
    Sep 2005
    Location
    Seattle, WA
    Posts
    195
    Liked
    0 times
    Rep Power
    8
    Default removal of lowest middle dash panel (with cig outlets)
    Hello,
    I'm trying to remove the lowest panel on the center dash, I have an access cab with the bench seat, 05 by the way. It's the piece the houses the 2 aux cigarette lighters, there's two plastic "buttons" on either side and I can feel the pointy thing on back but don't know how to take these off. It's a plastic circle with a small plastic dot in the center, any help would be appreciated. Thanks in advance!
    Rob
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member chrislloyd is on a distinguished road.
    Join Date
    Jul 2002
    Location
    Bay area, CA
    Age
    40
    Posts
    409
    Liked
    1 times
    Rep Power
    11
    piece of cake...
    press the center of the "button". it will push inward and release the clip. the clip should slide out after you do this. you can do this with a tip of a screwdriver or somthing similar
    to put them back on... pull the center out so it stick above the body of the clip.... slide the clip in... then press the center until its flush again.
    if your break one.. they are like 1.25 at toyota.
    i usually buy 5-10 of those if i break them.
  1. Dash removal
    By bayman in forum Interior & Exterior
    Last Post: 01-27-2006, 05:48 AM
  2. Tundra door panel removal
    By deanno in forum Interior & Exterior
    Last Post: 10-31-2005, 10:49 PM
  3. Tacoma Door Panel Removal Questions
    By supraxx in forum Tacoma
    Last Post: 06-18-2005, 01:32 PM
  4. Rear door panel removal?
    By Brian's Toy in forum Interior & Exterior
    Last Post: 10-27-2004, 10:16 AM
  5. Left Kick Panel Removal
    By primerhead in forum Interior & Exterior
    Last Post: 07-29-2003, 06:49 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
