This is a discussion thread titled "Upgrading to an auto dimming mirro with compass and temp", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Old 01-13-2006, 01:26 PM
T100_2_TUNDRA's Avatar
Dealer : Checkered Flag Toyota
2005 Toyota Tundra
Last Online: 01-01-2009 10:59 PM
T100_2_TUNDRA is on a distinguished road.
T100_2_TUNDRA's Photo Albums
Lightbulb Upgrading to an auto dimming mirro with compass and temp
I just got an autodimming, compass, outside temp, uv sensing mirror off ebay. Its the one from exon, taiwanese made, has the readout on the bottom instead of the glass. If the weather holds this weekend I will go ahead and install it. If somebody has already documented the process, can you point me to that link? If not, then I will go ahead and shoot some pix and document it in this thread.
Real quick, the a-pillar cover comes off after removing the grab handle and what else?
Thanks.
Old 01-15-2006, 03:52 PM
Agent WD-40's Avatar
Dealer : Fox Toyota of Rochester
Last Online: 09-20-2008 05:04 PM
Agent WD-40 is on a distinguished road.
Agent WD-40's Photo Albums
Default Re: Upgrading to an auto dimming mirro with compass and temp
This is something that I'm also interested in. Let me know how the install goes.
Old 01-15-2006, 09:08 PM
morganater's Avatar
Dealer : Nye Frontier Toyota/Scion
Last Online: 01-03-2009 12:50 AM
morganater is on a distinguished road.
morganater's Photo Albums
Yes, quite a few of us are interested in this mod. Post up with install details!!
My Truck: 2000 Black TRD AC SR5
  • 2005 Tails, Clear Corners
  • Dual straight pipes behind cat
  • DRL disable
  • Jensen VM9410 DVD In-Dash
  • CDT CL-61 components
Dad's Truck: 2006 Salsa Red Double Cab SR5
  • Leer Canopy
  • Nerf Bars
  • Wet Okole Seat Covers
  • Compustar 2-way
REPRESENTING ANCHORAGE ALASKA
Old 01-16-2006, 08:09 AM
2005 Toyota Tundra
Okey dokey. I put it in over the weekend. Some parts went smoother than others. Will post the pix and description in the next day or so.
Old 01-16-2006, 11:01 AM
Tundraspv's Avatar
Dealer : Orleans Toyota
Last Online: 01-04-2009 09:17 PM
Tundraspv is on a distinguished road.
Send a message via AIM to Tundraspv Send a message via MSN to Tundraspv Send a message via Yahoo to Tundraspv Send a message via Skype™ to Tundraspv Tundraspv's Photo Albums
Smile Re: Upgrading to an auto dimming mirro with compass and temp
I am having a Toyota accessory auto dimming rearview mirror installed in my truck this coming Thurs. I am stoked!! Congrats on the purchase of yours!! I just wish the drivers side mirror did that, like it does in our Solara!
Old 01-16-2006, 09:02 PM
2005 Toyota Tundra
Thumbs up Installing the mirror
As installs go, this was not one of the easier ones I have done, but it wasnt all that bad. This is a brand new truck, less than 2000 miles on the clock, so tearing apart the dash is something I do with a bit of trepidation. The first step is to remove the old mirror, comes out with a hex key. Once that is out, then you need to remove the map light fixture. The fixture comes out with two phillips screws and pulls out and down. There is one power connector for ground and 12v and a line from the door switch. I disconnected the fixture at the connector. While I had the fixture down, I did the mod to remove the aluminum plates that limit the light to the two smal ovals. Much brighter now.
Once the light was removed, I removed the driver side grab handle, the a-pillar cover (snaps in and out so you just pull on it) and the plastic edge over the drivers door. You will also need to remove the drivers side sun visor so you can run the wires under the headliner. Remove the driver side sill cover and kick panel. The only other trim I had to remove was the cover for the electrical 12v outlets to tap into a 12v ignition on source.
The New mirror front view
New Mirror rear view with connector.
Once you have gotten to this point you are ready to start running wires. This mirror comes with a temp sensor and a uv sensor. Both have two wires that need to run from the cab through the firewall to the engine compartment. I decided to go through one fo the rubber grommets as the least intrusive way of getting the wires through. I ran the wires from the engine compartment back into the cab using a real thin screwdriver and caught the edge of the connector pin on the blade of the screwdriver and pushed it through the rubber. This worked well with all but one connector pin which got a bit mangled up. I ran both sets of wires up to the front of the grill going behind the battery. I clipped the temp sensor in the grill, I had to leave the uv sensor wires tied up as it started to rain at that point. Will wire the uv sensor in this weekend.
Here is where the wires go through the firewall.
The wires come down here behind the kick panel.
This is where you route the wires so the fit behind the a pillar molding. When you get to the top of the molding, push them under the headliner and route them so they come out the opening for the map light fixture. Previously I had routed the short connector that goes from the mirror into the map light opening and connected that to the mirror. The other end of that connector also mates up with another connector that you plug the individual wires with pins (remember I mangled one of em) so I had to finagle that so all my sensor wires made contact. If it doesnt make sense, it will once you read the directions and see the wires in the kit.
After running all the sensor wires, all that was left was to find 12v battery and 12v ignition on sources. This proved to be the biggest PIA part of the whole install. There is no convenient way of tapping into a fuse block or some other panel to tap off the two sources. I knew there was 12v battery to the map light fixture so I was good there, but 12v ignition was tough. I ended up tapping into the source for the power outlets and running an wire over to the mirror kit harness and splicing it in. I tapped into the battery wire for the map lights and once that was done, it was wired.
This was the biggest pain, I snapped one of the plastic buttons that hold the trim piece on, but it fit back together ok.
Here it is, installed and running. It did not take all that long to replace the kick panel, sill cover, door trim and a-panel cover and grab handle. Ditto the sun-visor and map light fixture.
When I first drove witht he mirror, it seemed like it looked better than it performed. I hadn't run the calibration in which you have to drive in a 360 circle while its in the calibration mode. Once I did that, the compass became much more accurate. I have a magellan map330 gps mounted as well and I set it to a magnetic readout and the compass was within about 2-10 degrees all told. (after I played around with the zones for the magnetic deviation) This particular compass will allow you to select degrees f or c or the compass heading. Thats a nice feature.
All told I am pretty pleased with the install. The mirror is available on the bay for around 100 bucks plus 10 to ship. The autodimming feature seems to work well. Temp readout seems pretty accurate too. Will have the UV feature (why I need it I dont know )when I install this little bugger later on:
Old 01-17-2006, 11:38 AM
cliffie1946's Avatar
Dealer : Right Toyota
2002 Toyota Tundra,
2006 Toyota Avalon Pearl White Ltd
Last Online: 01-04-2009 12:03 AM
cliffie1946 is on a distinguished road.
cliffie1946's Photo Albums
I'll be doing this upgrade in the near future on my 2002 Tundra. Good write up. Looks good, too! Did you have to purchase the additional adaptor for the winshield mount?
Thanks
Old 01-17-2006, 03:37 PM
2005 Toyota Tundra
No, the mirror fit stock. Thanks.
Old 01-18-2006, 06:56 PM
Wow, thanks for the write up. That looks like more than I really want to get into right now. Don't feel too bad about tearing up a brand new truck... This was my brothers Tundra about a month after he got it.
Old 02-01-2006, 12:52 PM
Dealer : Big Two Toyota
2005 Toyota Tundra
Last Online: Today 05:01 PM
devo is on a distinguished road.
devo's Photo Albums
Everything I'm seeing on ebay shows this mirroe for a 2005 Tundra. Does it work with a 2001?
Old 02-01-2006, 01:14 PM
KAELA's Avatar
Dealer : Northridge Toyota
2004 Toyota Tundra,
- Other - 2006 MB E350,
2009 Toyota Sequoia *soon to come
Last Online: 12-31-2008 08:09 PM
KAELA is on a distinguished road.
Send a message via Yahoo to KAELA KAELA's Photo Albums
I thought of doing this a while back and still may be interested in it.
Old 02-01-2006, 01:36 PM
Garth's Avatar
Dealer : Handy Toyota www.handycars.com
2000 Toyota Tundra,
- Other - 2002 Audi A6 Quattro
Last Online: Today 09:22 PM
Garth is on a distinguished road.
Garth's Photo Albums
The mounting bracket changed in 2002 or 2003. If you want to put one on a Tundra prior to that, you need to get the adaptor bracket. I got mine from one of the mirror vendors (I forget which one now), it was easy mounting it on my 2000 Tundra, and looks and works great now.
-Garth
Old 02-01-2006, 02:16 PM
Garth's Avatar
2000 Toyota Tundra,
-Garth
Old 09-19-2006, 12:16 PM
ChazT's Avatar
Dealer : Maroone Toyota Scion
2004 Toyota Tundra
Last Online: 06-30-2007 08:58 PM
ChazT is on a distinguished road.
ChazT's Photo Albums
Cool Re: Upgrading to an auto dimming mirro with compass and temp
Just got mine on ebay, looks to be the same model as T100 2 TUNDRA's. Got it for $68 shipped
Looks like a fairly complicated install, but thanks to Tundrasolutions & T100 2 TUNDRA's extra effort I'll be putting mine in this weekend if the weather holds.
I hope it's not too much harder than installing a Backup camera or Hellwig
2004 Black Tundra Double Cab Limited
De-Badged, Power Moonroof, Oak Leather, Power Rear Window, Lighted Running Boards, Tow Package, JBL 6-disc w/Cassette & VSE Subwoofer, PIE Adapter w/Creative ZEN Widescreen, Tri-Glass Hard Tonneau, Color Backup Camera System, Domelight Mod, Auto-Dimming Mirror w/Temp & Compass, Hellwig Rear Anti-Sway Bar, Sylvania SilverStar Headlights & Fogs
Old 10-11-2006, 10:16 PM
Dealer : Gale Toyota Scion
Last Online: 09-15-2007 11:28 PM
cabinfever is on a distinguished road.
