This is a discussion thread titled "squeaky fan", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Old 01-24-2006, 06:51 PM
Dealer : Lorensen Toyota
Last Online: 05-09-2008 11:42 AM
adam2296 is on a distinguished road.
Send a message via AIM to adam2296 adam2296's Photo Albums
Default squeaky fan
the fan on my truck that blows air into the cab it makes a squeaking noise anytime i turn the fan on. has anyone experienced it or have any ideas what the problem could be
thanks adam
Old 01-24-2006, 07:57 PM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4
Last Online: Today 08:45 PM
LGL002 is on a distinguished road.
LGL002's Photo Albums
Default Re: squeaky fan
thanks adam
The fan motor bearings are out of oil. I recall one member took out the motor/blower wheel assy. took the motor apart and lubed it and it was OK. I took mine out decided to just replace it with a new Toyota assy. It comes from the dealer complete with motor and blower wheel attached for less than $100. It's easy to remove and you can see it below and behind the glove box facing upward. Piece of cake to change out or remove.
Larry
2004 Tundra V8 Limited Access Cab 4X4, Michelin 265/65/R17 ATX2 tires, Auto Dim Comp/Temp Mirror, Aero Turbine #2525 muffler, Access Roll Up Cover, Optima D31A battery, Multi-Vex adaptive outside mirrors, Eclipse AVN5510 Nav unit and Sirius SIR-ECL1 tuner as of 10/07 pictures in my photo gallery
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
If a combo of all these whizz bangs met their claims you'd have to syphon gas out of your tank every second day and sell the excess horsepower on the third????
Old 01-26-2006, 04:07 PM
so if i were to pull out the glove box it would be right back there easy to see?
Old 01-26-2006, 05:11 PM
LGL002's Avatar
You don't need to take out the glove box liner. Look to the rear of the glove box liner from the foot well and you will see the fan blower assembly towards the passenger kick panel. It fits in and out vertically. In other words the fan blower wheel is above the motor that you'll see and comes out attached to the motor. You will see the screws/bolts that attach that plastic assembly to the heater/a/c plenum. If I recall it takes a Phillips screwdriver to remove it and the wire connection is a clip together coupling that's accessible also.
Larry
Optima 34R battery
Old 01-26-2006, 08:45 PM
is there a special kind of oil that i should use? or would wd-40 get the job done
thanks adam
Old 01-26-2006, 10:37 PM
LGL002's Avatar
I'd remove it and look it over before asking about which lube to use. I've taken a lot of electric motors apart from 1/16 hp to over 500 hp and generally the smaller they are the more difficult they are to dismantle. If you are able to take it apart (which is very possible) without breaking it I'd use a 3 in1 type oil. WD-40 is pretty thin for motor use and won't last very long. Let us know how it goes and good luck.
Larry
Optima 34R battery
Old 01-26-2006, 10:45 PM
thanks for the help
adam
Bookmarks
Similar Threads for: squeaky fan
Electric Fan w/ Variable Speed Controller Installed... bamachem Engine & Drivetrain 0 06-16-2005 12:41 PM
Electric fan bearsfolks Engine & Drivetrain 15 11-27-2002 01:58 PM
take off that gas/power robbing fan autoteach Engine & Drivetrain 20 11-12-2002 05:21 PM
Electric radiator fan? nhparrot Engine & Drivetrain 0 03-28-2002 03:53 PM
