I just got my 7336 and used it today to buff some scratches out and to put a coat of wax on, it worked real well, but i noticed that it didnt really spin when i had it pressed against the trucks panels, then when i would pull it away it would spool up and spin as well as vibrate. I know it is supposed to spin in 2 different orbits but it seems like the pad stops spinning as soon as i put pressure on the pad, and it just kinda vibrates. The vibration works well but i just wanted to make sure im not burning the motor or somethin becaues it feels like im holding it from wanting to spin.
LinkBack URL
About LinkBacks
. It won't necessarily rotate strictly in a circular motion when you press down on the buffer hence the name random orbit, but it will rotate. Hope this helps somewhat for you
