This is a discussion thread titled "Leaking sun roof", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 03-21-2006, 12:45 AM
Dealer : Capitol Toyota Scion
2002 Toyota 4Runner
Last Online: 03-12-2007 05:04 PM
jakemad is on a distinguished road.
jakemad's Photo Albums
Default Leaking sun roof
Any one have a leaking sun roof???
Seems like the weather stripping around it has shrunk just enough to allow water to enter around it. There is a trouth under it that runs around both sides and the front with drain holes to relieve some water but nothing under the rear of it. My truck has smelled like a wet dog for some time now but I don't own a dog. This sucks. Anyone ever replace the weather stripping???
Old 04-06-2006, 08:26 AM
steveng777's Avatar
Dealer : Riley Toyota
Last Online: 07-18-2006 02:47 PM
steveng777 is on a distinguished road.
steveng777's Photo Albums
Default Re: Leaking sun roof
i had a similar problem w/ my celica. what i did was to blow pressurized air through the drain holes. i used a rubber piece on the end to make a good seal on the drain hole. hope this helps........sg777
2003 Honda F12X turbo
MacsBoost #30
http://www.macsboost.com
2005 Yamaha VX110Sport
2005 Kawasaki 750I 4X4 Brute Force
2006 Honda TRX250EX
1998 Honda TRX90 FourTrax
2002 Toyota Tundra SR5 4X4 access cab
dual exhaust K&N Cold Air Intake
JLAudio 1000/1 2-JLAudio K-6's
ProAudio 300/2
MBQuart 5.25" Component highs & mids
2002 Toyota Avalon XL (wifes)
1992 Toyota Celica Convt (g/f)
Old 04-06-2006, 05:05 PM
Agent WD-40's Avatar
Dealer : Fox Toyota of Rochester
Last Online: 09-20-2008 05:04 PM
Agent WD-40 is on a distinguished road.
Agent WD-40's Photo Albums
All sunroofs leak (even new). In fact they are even "designed" to leak. That is where the water management system comes in play. If it is plugged and fills up too much you will have trouble. This problem gets worse if you park on a hill and it ends up draining out onto the headliner (perhaps you are parked nose uphill and the water will drain out the back of the trough and not down the drain tubes). Make sure the drain tube is not plugged all the hoses are on tight. You might want to make sure your headliner isn't moldy.
If the gap between your seal and the roof is extremely large water might be overwhelming the water management. Can you provide a picture? I'm guessing you have a plugged tube or something though.
Old 04-06-2006, 06:55 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
2004 Toyota Sequoia,
- Other - 1967 Mustang
Last Online: Today 08:07 PM
mustang67408 will become famous soon enough. mustang67408 will become famous soon enough.
There are 4 drain tubes on your sunroof.(2002 4 runner) Blowing air thru them should help clear them out. Dont blow to hard or you will dislodge the tubes.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
Old 04-06-2006, 07:38 PM
2002 Toyota 4Runner
Thanks for the responses.
It was a drain tube problem. Passenger front ran down trough the dash where Toyota pinched it between the heater housing and the sheet metal body of the truck. This thing could never have drained from day one. To bad I'm out of warranty and had to remove half the dash and heater to fix it.
Thanks again for the help. This site and it's readers are awesome!
Mark
Old 07-08-2006, 01:43 AM
Dealer : Central Florida Toyota Scion
2006 Toyota 4Runner
Last Online: 07-08-2006 01:43 AM
jetcity73 is on a distinguished road.
jetcity73's Photo Albums
I have a 2006 4runner and yes the sunroof leaks and my brand new car smells like a wet dog. (I don't have a dog either.)
I took the car back to the dealership and they claimed it was fixed, but it still leaks. I'll need to take it back again.
Old 08-03-2006, 09:27 AM
Dealer : Westboro Toyota
2004 Toyota 4Runner
Last Online: 08-03-2006 09:27 AM
wcm4tthew is on a distinguished road.
wcm4tthew's Photo Albums
Lightbulb Re: Leaking sun roof
I noticed the sunroof on my '04 runner leaking quite a bit during a rainstorm last week - at least I can use it to explain the wet dog smell (though I do frequently carry wet dogs as well ). I found that if I use the tilt feature to slightly open and then re-close the sunroof, it does manage to seal properly.
I've heard way too many horror stories of dealers trying unsuccessfully to fix sunroof leaks so I've resolved to just live with it, so long as the tilt "cheat" continues to work.
Old 08-03-2006, 09:41 PM
2002 Toyota Tundra,
your sunroof may have inadvertantly become "OUT OF TIME".
Try resetting it with these instructions and see what happens.
23 yrs with TOYOTA
K.I.S.S.
Old 03-12-2007, 04:02 AM
Dealer : Universal Toyota
1999 Toyota Camry
Last Online: 03-28-2007 07:06 PM
jakov is on a distinguished road.
jakov's Photo Albums
\I just bough(t) a 1999 camry and the sunroof is silicone sealed, maybe is because it leaks water , can somebody tell me what to do,because I like the car because the toyota repuation and the sunroof/monroof :P too , whats the steps to fix a leak???? and where are the 4 tubes drain?
sorry for my english:S
Bookmarks
LinkBack to this Thread: http://www.tundrasolutions.com/forums/interior-and-exterior/59745-leaking-sun-roof/
Posted By For Type Date
4runner Sunroof Leak - Kosmix This thread Refback 01-05-2009 05:00 PM
toyota sunroof drains Hotwords.com This thread Refback 12-14-2008 11:30 AM
Similar Threads for: Leaking sun roof
Sun Roof? Tundra06 1Gen-Tundra 32 08-13-2007 04:20 AM
Sun Roof has a rattling Noise at 40+ MPH devillar 1Gen-Sequoia 13 03-09-2005 03:24 PM
Rain = leaking roof..HELP TRD SyRuP California 7 02-21-2005 08:36 PM
Sun Roof cubic22 Interior & Exterior 6 02-19-2003 11:38 AM
Sun Roof TUNDRA CHIEF Interior & Exterior 7 05-27-2002 09:36 PM
