This is a discussion thread titled "Green "condom"", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
today i replaced a bulb behind the a/c control on the instrument panel. the bulb i was replacing had a green condom on it that gave the light a green tint. it was standard toyota issue. the auto discount store i went to today had never heard of them. i know this is a minor issue but i would like that bulb light to match the others....where can i find this??
moving to the exterior. the mount for my antenea is loose. i tried removing the panel (in the crack where you open the door)....but getting my fingers in there was near impossible and there seemed to me a metal mount i would have to unscrew before even seeing where the antenea is mounted. it appears to me to need a tightening...when i drive the wind with blow it back. any ideas on how to fix this.
Your antenna isnt loose. its warped and the antenna assy has to be replaced.
I can get you the green bulb cover and the antenna if your interested.
Pm me for details
23 yrs with TOYOTA
just shake the shiit out of it and slip it on again
__________________ HAVE YOU DRIVEN OVER A FORD LATELY?
Team West SAWS (cranked up to 3.25")
Total Chaos UCA
ORS Manual hub kit
reese front receiver hitch
10,000 lb. winch on receiver hitch
Warn Quick connects front and rear
rear brake porportioning valve mod
3" perfomance products body lift
skyjacker AAL
wheelers urithane kit for front swaybar and steering rack
BFG AT's
Eagle101 wheels
CB radio W/ dual fiberglass 48" ant.
you see the green condom actually tore when i took it off the other bulb.....reusing a torn one? that would be pushing it. toyota dealership said i could find them maybe at autozone.
Here's a pic of a good antenna
and a description of what happens.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
you could try putting a little dab of clear silicone on it, the tear that is. its kinda getto but it should work.
of course i wouldnt try that with a real condom.
MODS: TRD urban package - tint, stereo, jack-in-the box antennae ball, my middle finger.
...And as a matter of fact, i cant spell.
[quote=calebm12]today i replaced a bulb behind the a/c control on the instrument panel. the bulb i was replacing had a green condom on it that gave the light a green tint. it was standard toyota issue. the auto discount store i went to today had never heard of them. i know this is a minor issue but i would like that bulb light to match the others....where can i find this??QUOTE]
Sylvania SilverStar Headlights
PIAA Ion Crystal Fog Lights
Clear Corners w/Sylvania SilverStar irridescent/amber Signal lights
PIAA High Intensity White LED rear liscense plate lights
PIAA Xtreme White front/rear map and door lights
PIAA Xtreme White front/rear dome lights
Superlumination Red 15-LED tail/stop lights
Superlumination Red 5-LED Wedge Matrix rear tail markers
Superlumination Super White 9-LED backup lights
Superlumination Red 5-LED Wedge Matrix top rear brake lights
Sunroof and door wind deflectors
10 in. Bazooka Base Tube
265/70/16 Michelin Cross Terrain SUV's
...and the list grows!
Future Mods
Rear LED turn signals
Navigation System
Black Rims w/ chrome trim
upgraded exhaust system
K/N Air Filter
Black Front Grille Guard
Black Rear Light Grilles
