Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
View Poll Results: What would you do
Keep the plastic liner 8 61.54%
Try the DIY herculiner 5 38.46%
Voters: 13. You may not vote on this poll
Old 09-08-2002, 10:30 AM
jdc580's Avatar
Last Online: 08-21-2003 08:23 PM
jdc580 is on a distinguished road.
Send a message via AIM to jdc580 jdc580's Photo Albums
Question Herculiner?
Has anyone used the DIY liquid liner Herculiner?
-John
Old 09-08-2002, 02:27 PM
ricqik's Avatar
Last Online: 11-20-2009 08:48 PM
ricqik is on a distinguished road.
ricqik's Photo Albums
I've got one on mine. Really nice texture. soft rubbery finish. I used one gallon and then added another layer of bondo-liner(hard finish) on top of it because they ran out where I bought mine. I also put my plastic bed liner back on top of it. That's superior protection. I not really sure about the durability of it nor any spray/roll-on liner. They all gouge easily if used hard. Try two coats of it.
Stuffs:
JBA Headers, Costum Exhaust, ASP U/D Pulley, Centric Crossdrilled & Slotted Fr Rotors, LSD, IS Kit, Manik SS Steps, HID Headlights & Fogs, Pacer Tailgate LED Light Bar, Blacked Out Headlight & corners, LED tail lights
Toys:
04 Skeeter ZX250 w/300 Vmax HPDI (79.35gps so far)
05 Polaris Sportsman 700TWIN EFI (rarely ride)
Old 09-08-2002, 07:45 PM
mladd72's Avatar
Last Online: 04-21-2007 10:49 PM
mladd72 is on a distinguished road.
Send a message via Yahoo to mladd72 mladd72's Photo Albums
Thumbs down A sticky mess
My experience with Herculiner was pretty negative. It was a PITA to apply and once applied was very easily gouged. If you're going for a spray-in type liner, I'd look at one of the professionally applied liners and stay away from Herc. Course, I'm plenty satisfied with my current drop-in liner. Guess it depends on what you're doing with the truck.
Old 09-10-2002, 01:06 PM
fpb fpb is offline
Dealer : Fremont Toyota Scion
2005 Toyota Sequoia
Last Online: 07-07-2009 12:21 PM
fpb is on a distinguished road.
fpb's Photo Albums
I've had mine on for about 9 months and have had no problems. You sure would want to run around on it with bare feet as it is pretty rough. It sure keeps stuff from shifting around tho.
I does take some elbow grease to put on as you have to sand down the nice finish first - tough to do on a new truck.
Good luck,
Paul
Old 09-11-2002, 09:53 PM
Last Online: 07-15-2004 10:12 PM
tundraphenia is on a distinguished road.
tundraphenia's Photo Albums
It's very messy, and labor intensive, but I am very pleased with the final results. It's a two day process to complete. But considering I was quoted almost $500 for a Rhino liner, it's a great deal if you have the time.
Make sure to rub the paint down with xylene per instructions. It seems to soften the paint and make it bond with the Herculiner.
Important to take your time on the preparation. The little sanding pad they supply is not really abrasive enough, I found a similar 3m pad at the hardware store that cut the paint better, and also used my random orbital sander (used 220 grit), where I could lay it flat on the metal.
I haven't tried to drag an engine block across it, but I've carried some fairly heavy stuff around and have observed no chips or scratching.
They give you two rollers, one for each coat. Make sure to take the first roller off the handle right after the first coat; it's a pain to get off once it dries.
One kit (a gallon) does two complete coats on a short bed. You need more if you have a long bed.
Old 06-30-2008, 06:25 PM
punisher's Avatar
Dealer : Carson Toyota Scion
Last Online: 02-09-2009 03:49 PM
punisher is on a distinguished road.
punisher's Photo Albums
Default Re: Herculiner?
just did a test of herculiner. Spent about 8 hours just to do my tailgate. so far I am very impressed with the product. I will see how it looks after a month of use and either finish the whole bed or not.
Old 07-10-2008, 10:56 AM
TundraSurfBum's Avatar
Dealer : Wesley Chapel Toyota
Last Online: 03-09-2009 07:27 AM
Images: 5
TundraSurfBum is on a distinguished road.
TundraSurfBum's Photo Albums
junk!
you'll save $$$ in the long run with linex
only reason I would use herc is under a drop in bedliner.... if I was bored
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
285 Nittos on OEM Alloys
Flowmaster Delta 40
LUND Genesis Tri-Fold Tonneau
WADE in-Channel Visors
Lil Boom under the seat compliments of RF
Full LED conversion
Nothing too fancy, just better than stock!
Old 07-10-2008, 09:24 PM
apimpdad's Avatar
2002 Toyota Tundra
Last Online: Yesterday 11:36 PM
Images: 57
apimpdad is a splendid one to behold. apimpdad is a splendid one to behold.
Send a message via AIM to apimpdad apimpdad's Photo Albums My eBay
After about a year of having my Hurculiner, it started peeling off. Complete waste of money IMO.
SAS Tundra
Build Thread-
SAS on 02 Tundra
Old 07-11-2008, 12:36 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Images: 22
Herculiner is a great product for things like your HiLift handle, bottom of your fuel cans, bottom of your CO2 tank, inside of the cab, stuff like that. It's very thin compared to Rhino or LineX.
My preference is toward LineX in the bed, with a few good tiedown brackets around, or a neoprene bed mat on top. It's a bulletproof combo, great for construction materials, metal, stuff like that.
Rhino is great if you're hauling more fragile stuff like mountain bikes, coolers, things that need to stay put or not be scraped or damaged. It's tackier than LineX but tears easier.
-Sean
GFX by FreedomEagle50
Manual Hubs
Old 07-16-2008, 05:37 PM
123Gone's Avatar
Dealer : Toyota Of Fort Worth
2005 Toyota Tundra
Last Online: Yesterday 04:41 PM
123Gone will become famous soon enough.
123Gone's Photo Albums
If you're the type of person that would go to Wallymart and buy a few cans of Krylon spray paint and paint your truck with it, then you're the type of person that would be pleased with a do-it-yourself bedliner product. If you're the type of person that would only have your truck painted by a professional, then you're the type of person that would be please with a professional bedliner, like LINE-X.
