This is a discussion thread titled "rock sliders?", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Old 10-21-2002, 11:23 PM
Last Online: 11-15-2004 06:55 PM
southerntundra is on a distinguished road.
southerntundra's Photo Albums
Default rock sliders?
yes can anyone give me info on rock sliders i am going to try to fab my own but would like to know if anyone has tryed it so i could learn from there mistakes/gain knowledge of ! thanks
Old 10-22-2002, 01:41 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
dyogim will become famous soon enough.
dyogim's Photo Albums
Check this out for some additional info: http://4crawler.cruiserpages.com/4x4...kSliderZ.shtml
Mike - http://dyogim.blogspot.com
Old 10-26-2002, 05:34 PM
TMS2U's Avatar
Moderator
Dealer : Longo Toyota
Last Online: 12-30-2008 12:30 AM
TMS2U is on a distinguished road.
TMS2U's Photo Albums
That is an excellent resource Dyogim posted. I like his design as no tube bending is needed. In fact, he is fabing a set for us as we "type". You can buy them from him as a kit and do the welding yourself if you like or borrow his design, get 10 ft of 1 1/2" sq tube (1/8) and 40 ft of 2" sq tube (also 1/8 or maybe 3/16), some 4x4x1/4 plates, some spare metal for gussets, a good chop saw to cut precise angles, a 100 amp welder (arc or MIG), about 2 days free time, and you will be set!!!
Old 11-05-2002, 11:02 PM
Joe's Avatar
Joe Joe is offline
Dealer : Tim Corwin Toyota
Last Online: 12-31-2008 10:15 AM
Joe is on a distinguished road.
Joe's Photo Albums
I have a set of HD sliders from Kong's http://www.kongs4x4.com/.
They are 82" long and are made from 3/16" rolled steel tubing. I also reinforced the frame by welding a 1/4" steel plate to the outside of the frame and had the holes cut with a plasma cutter. I have some pictures posted in my photo section showing the sliders, frame and a few trails around the Phoenix area.
Old 11-06-2002, 08:38 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
How much did the sliders cost? Those are pretty bada$$
Old 11-06-2002, 09:18 PM
Joe's Avatar
Joe Joe is offline
Joe's Photo Albums
They cost $514.00 plus $40.00 for the powdercoating. The "normal" Kong sliders are $349.00 but mine are 82" in length and 3/16" (.188) thick tubing whereas the "normal" sliders are 1/8" (.120) thick tubing and 76" in length for the Tundra. I needed (wanted) the 3/16" tubing as I feel they will hold up a lot better when I use the slider to pivot the Tundra (with its longer wheel base) around "obstacles".
Old 11-10-2002, 09:17 PM
TMS2U's Avatar
Moderator
Here is the set that I am currently working on
They aren't welded yet, but that won't take long now that everything is cut to length
Old 11-11-2002, 10:23 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Looks simple and beefy. I'm assuming you are going to cut, weld and install yourself?
Old 11-11-2002, 11:42 AM
TMS2U's Avatar
Moderator
Yep! Today I am figuring out the frame mounting locations. I figure 4 per side will do the trick. One part of the frame up front is enclosed so if I bolt them on I will have to use self tapping bolts. I still have not decided if I want to weld them, on or bolt them on. It would actually be easier to weld them on.
It only took me about 3 hours to do all the cutting, but it shredded my chop saw blade when a piece moved and torqued it
Old 11-11-2002, 05:26 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Did you use 2x2 or 1x1 square tubing?
Old 11-11-2002, 11:29 PM
TMS2U's Avatar
Moderator
I used 1 1/2" sq tube for the frame mounts and internal bracing, 2" tube for the runners; both 1/8 thick.
I got half of the frame mounts done this afternoon. Wish I had a gas MIG at home, would make things alot ezr.
Old 11-14-2002, 11:19 PM
TMS2U's Avatar
Moderator
I got one side done! (welding wise anyhow) The inside welds are a pain due to the limited access. Need to clean off all the slag so I can paint 'em.
I am gonna weld them on afterall as it will be easier than doing the drilling.
Old 11-15-2002, 12:12 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Tedd: Let us know how it works out when you weld or bolt it on. Looks good!
Old 11-26-2002, 11:46 PM
TMS2U's Avatar
Moderator
Smile halfway done!!
Well, I got the passenger side sliders on! I hate daylight savings time and 5pm sunsets. I do still need to finish up some of the welds, but its on there!!
Old 06-14-2004, 02:04 PM
Dealer : Power Toyota Scion Tempe
Last Online: 06-27-2007 01:08 PM
monomial is on a distinguished road.
monomial's Photo Albums
I am not finding alot of sources for Tundra sliders. Any suggestions? I think I would prefer bolt-on to welding. Any opinions ?
