KORE
Free Shipping at Buy.com!
FREE Personal Trainer Program
This is a discussion thread titled "Dash Rattle – Problems and Solutions", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
  #16 (permalink)
Old 10-24-2002, 11:38 AM
peid's Avatar
Dealer : Billion Motors
1996 Toyota T100
peid's Photo Gallery peid's Photo Albums
Last Online: 07-31-2008 08:18 AM
peid is on a distinguished road.
Don't over look items in the ash tray or having the cup holders out, they rattle like crazy. It is possibly even the cup holder when it is in the closed position. Try removing it and see if it goes away.
1996 T100, 177,000 and counting
  #17 (permalink)
Old 10-25-2002, 11:33 AM
Dealer : Maplewood Toyota
2000 Toyota Tundra,
1998 Toyota Corolla,
2003 Toyota Tundra
mstever's Photo Gallery mstever's Photo Albums
Last Online: 11-15-2007 08:35 PM
mstever is on a distinguished road.
I tried removing all the stuff in the dash and the ashtray/cupholder...No change. It sounds like the rattle is coming from the passengers side inside the dash.
Has anyone had similar rattles?
  #18 (permalink)
Old 10-25-2002, 01:00 PM
hendricksonl's Avatar
hendricksonl's Photo Gallery hendricksonl's Photo Albums
Last Online: 06-18-2006 01:15 PM
hendricksonl is on a distinguished road.
Try looking at the weatherstripping / trim on the outside of the windsheild. Was squeaking against the windsheild when at highway speeds and cold. Sounded like it was coming from the passenger side dash or windsheild. Service manager put some one-side sticky thin felt strips between trim and windsheild and has gotten rid of 99% of the noise. Glad it wasn't the windsheild (Brand new 2003 Tundra)
Q. Anyone else think the paint is really fragile and hearing some "klunking" noises from the brakes when first backing up or driving off after it's been sitting for a while?
  #19 (permalink)
Old 10-25-2002, 01:25 PM
Dealer : McGeorge Toyota
2001 Toyota Tundra,
2004 Toyota Sienna,
2007 Toyota Prius
userw5's Photo Gallery userw5's Photo Albums
Last Online: Today 03:32 PM
userw5 is on a distinguished road.
The klunk noise is the ABS test when you first start-up. It has been noted here in many threads.
The topic of thin paint has been discussed also. Perform a search or look at some of the older threads and you will find a lot of information on both subjects.
Jeff
  #20 (permalink)
Old 11-03-2002, 02:29 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Dude Boy's Photo Gallery Dude Boy's Photo Albums
Last Online: 02-24-2008 12:50 AM
Dude Boy is on a distinguished road.
I've been using the 1/2" backer rod to keep the "clicking" noise out of my dash for about a year. A while back, the noise came back and I had to put in a new strip. Now it's back and I've put in a third new strip, but the noise wants to persist. Someday I'm going to have to get to the real cause, plastic nubbin to lube, or whatever. When it was new, I the dash open 3 or 4 times trying different things, but nothing helped as much as the foam backer rod. Anybody else have the noise come back?
ADDING POWER HAS NEVER BEEN SO FAST!
  #21 (permalink)
Old 11-07-2002, 07:42 AM
2000 Toyota Tundra,
2003 Toyota Tundra
Question Still noisy...
Well I tried stuffing 1/2" foam rope caulking in the space where the dash meets the windsheild. It worked great for three days and now that rattle/clicking noise is back.
Is this foam rope the same thing that you guys are calling "backer rod" ? I can't find any product called "backer rod"?
What now? Any other suggestions? Should I stuff more foam rope in there?
To reiterate the problem...There is a rattle/clicking noise coming from where the dash meets the window right in front of the passengers airbag. Almost every bump triggers the noise. I can even push up and down on that spot and produce the same noise. It seems to be coming directly under the dash surface.
Does anybody know what is the cause of this problem and what is required to fix it once and for all?
Is there a TSB/recall for this deffect?
If it requires dismantling the dash how long does this take and has anyone here done it themselves?
Thanks for your help...
Matt
  #22 (permalink)
Old 11-08-2002, 02:47 PM
ibleedblue's Avatar
Dealer : Griffin Toyota
2005 Toyota Camry SE Indigo Ink,
2006 Toyota Tacoma DC TRD Sport
ibleedblue's Photo Gallery ibleedblue's Photo Albums
Last Online: 08-04-2008 01:11 PM
ibleedblue is on a distinguished road.
I had the same problem and tried the backer rod solution. Didn't work. Tried stuffing another piece in there, still didn't work. The squeak in my truck sounds as if it's coming from the middle of the dash against the windshield. It only does it when it's below 50 degrees or so, so I haven't had to worry about it for the last 6 months. With the return of cold weather, the squeaking is back.
Last year I determined that the squeak is coming from the defrost vent that blows on the windshield. If I stick my fingers through the holes in the dash I can feel the vent vibrating like crazy while going down the road. If I hold the vent steady, the squeak goes away. Now it's just a matter of figuring out out to fix it. I'm off work Monday, so maybe I'll get around to working on it then.
Greg
  #23 (permalink)
Old 11-10-2002, 11:14 PM
thekurgan's Avatar
Inactive Account
Dealer : Folsom Lake Toyota Scion
2005 Toyota 4Runner
thekurgan's Photo Gallery thekurgan's Photo Albums
Last Online: 10-29-2005 09:49 AM
thekurgan is on a distinguished road.
I found the 3/8" backer rod to be more effictive as I would shove it farther down where the dashcap meets the vent's plastic pieces. I removed the radio assembly and was able to reach in and see where the dashcap "creaks" against the other plastic pieces below. The 1/2" rod was too large and unsightly to be effictive for me. YMMV Good luck.
  #24 (permalink)
Old 11-12-2002, 09:52 AM
bbfirebird's Avatar
Dealer : Power Toyota Scion Tempe
2006 Toyota Tundra,
2005 Toyota 4Runner
bbfirebird's Photo Gallery bbfirebird's Photo Albums
Last Online: 07-23-2008 01:59 PM
bbfirebird is on a distinguished road.
i just began experiencing the same problem. my 2002 has just over 2k miles on it, and i used the windshield defroster for the first time on saturday. after that, i would hear what i can only describe as slight clicks. when i was driving, i would put my hand on the dash in front of me and press down slightly. this would make it stop, but when i moved my hand again it started. i don't know what the deal is. usually i can't hear it cause my music is loud. i'm gonna take it to the dealer soon for my first oil change anyway, so i'll have em fix it then.
  #25 (permalink)
Old 01-27-2003, 02:12 PM
TundraBear's Avatar
Dealer : Carson Toyota Scion
2005 Toyota Sienna,
2006 Toyota Tundra 4x2 Limited DC
My eBay TundraBear's Photo Gallery TundraBear's Photo Albums
Last Online: Today 01:22 AM
TundraBear is on a distinguished road.
Send a message via Yahoo to TundraBear
Going to Home Depot tomorrow to pick up some of that Frost King Backer Rod. The sound it most irritating! Sometimes it sounds like it's behind the clock and other times it's echoing to make it sounld like hte center console is freaking out!
It really trips me out how shobing this inbetween the windsheild and dash will avoiding this noise........
btw...it is a foam or rubber like around the doors?
Off Topic & California Forum Moderator
2006 Tundra Limited DC: Ram Air Performance System | TrueFlow Sealed Air Intake | 24" Bassani X-Muffler with Quick Time Electric Cutouts | IS Rims w/ BFG RT 265/70R16 (for now) | SkidRow FSP | Hellwig Antisway Bar | Retrax Bed Cover | Bazooka VSE | front/rear parking sensors | power tailgate lock | debadged | tinted windows | 2x baby mod (car seat)
2005 Sienna: Purple Plazma Headlights | de-badged | 2x baby mod (car seat)
  #26 (permalink)
Old 01-27-2003, 09:41 PM
Dealer : Earnhardt Toyota
AZ TUNDRA's Photo Gallery AZ TUNDRA's Photo Albums
Last Online: 07-19-2007 10:56 PM
AZ TUNDRA is on a distinguished road.
Here in Arizona we install Dash Mats. They are custom fit to your dash in whatever color you want. They protect the plastic dash from the heat. Cost about $ 39.00. They fit between the windshield and the dash. We can buy them everywhere down here.
  #27 (permalink)
Old 01-30-2003, 08:34 AM
Inactive Account
lefty's Photo Gallery lefty's Photo Albums
Last Online: 06-28-2005 12:19 PM
lefty is on a distinguished road.
Backer Rod ! Ha ! You guys are great ! Who wudda thunk of that one ???
Ran out yesterday and spent a whopping $2 on some and "installed" it last night in 5 minutes. Haven't really had the chance to test it out yet.
One update to the installation procedures - use a spatula to push the rod between the dash and windshield. You don't risk scratching anything\punching holes. Just don't let your wife catch you !
Steve
  #28 (permalink)
Old 02-07-2003, 12:33 AM
Acura_Bossman's Photo Gallery Acura_Bossman's Photo Albums
Last Online: 06-18-2008 11:50 AM
Acura_Bossman is on a distinguished road.
ive had the backing rod in my dash now for about 2 months and the rattles havent come back.... Toyota needs to tell the dealerships about this simple fix. In the 3 years Ive own my truck I had the dealership try to fix the rattle at least 5 times and they never figured it out.
To the person who asked if you can see the rod, my interior color is gray and the color of the frostking rod is dark gray so I didnt push it all the way in. Its almost all the way in but I can still pull it out if I need to and it looks like its supposed to be there....
and for those wondering what kind of noise... it is a tapping noise like a credit card tapping your dash constantly....
  #29 (permalink)
Old 02-07-2003, 01:35 AM
Inactive Account
vector1's Photo Gallery vector1's Photo Albums
Last Online: 02-27-2003 07:48 AM
vector1 is on a distinguished road.
I applied the 1/2" caulk backer last year and it compressed slightly, so the squeak came back. I pushed it all the way in (out of sight) and applied one more strip on top (it fits, beautifully). Looks EXACTLY like the foam piece in our Honda Pilot. Really does the job.
  #30 (permalink)
Old 02-16-2003, 09:18 AM
sdmahr's Avatar
Dealer : Frank Smith Toyota
sdmahr's Photo Gallery sdmahr's Photo Albums
Last Online: 12-13-2007 03:23 PM
sdmahr is on a distinguished road.
Angry
Well, I tried a piece of the backer rod between the dash and the glass and the noise is still there. I pushed it all the way in and it still is there. Should I push another piece in or am I looking at the wrong solution? The noise I experience is at cold temperatures and at high speed sounds like a credit card tapping on the dash above the glove-box.
Any suggestions?
Questions? Please use the Contact Us link. Dealer Hunter JPV Photography Consumer Electronics Hunter
