Free Shipping at Buy.com!
FREE Personal Trainer Program
This is a discussion thread titled "Dash Rattle – Problems and Solutions", within the Interior & Exterior forum, part of the Technical & Vehicle Assistance Forums category.
Old 04-05-2002, 12:48 AM
ripshion's Avatar
Inactive Account
ripshion's Photo Albums
Last Online: 02-06-2005 12:49 AM
ripshion is on a distinguished road.
Thumbs up Dash Mod for creak works!
Just did the dash mod that other members here suggested for dash creak, it works! The creak in my dash was driving me nuts, could not figure out what was causing it. Went to Home Depot, bought some 1/2 inch Backer Rod, shoved it between the dash and windshield from end to end(perfect fit), and bada bing! No creak!
To whomever thought of this fix....thanks for sharing!
Old 04-05-2002, 03:00 AM
Dealer : Longo Toyota
iforceV8's Photo Albums
Last Online: 08-06-2008 02:07 AM
iforceV8 is on a distinguished road.
What is this 1/2'' backer rod supposed to be used for? What section would I find it in?, I have some dash creak, and it is pissing me off. It sounds like its coming from the center of the dash.
Old 04-05-2002, 09:19 AM
MarkHolbrook's Photo Albums
Last Online: 04-21-2007 06:17 PM
MarkHolbrook is on a distinguished road.
Ok...
I admit it... I don't even know what to listen for to detect the dash creak.
Can someone give me some hints on when I should hear it and what it should sound like?
Mark
Old 04-05-2002, 09:37 AM
ripshion's Avatar
Inactive Account
Backer Rod is used for caulking, supposed to set a good bead etc. It is round insulation foam rubber that can be found in the insulation section of Home Depot. I didn't think the 1/2 inch size would fit between the dash and the windshield but you will be surprised, it fit's in there perfectly! Just use a small screwdriver or something to push it down for a snug fit. Good luck!
Old 04-05-2002, 06:58 PM
2006 Toyota 4Runner
Montfort's Photo Albums
Last Online: 08-04-2007 06:00 PM
Montfort is on a distinguished road.
Default Windshield/Dash Creak
For those of you that have done this fix, is the caulking visible/noticeable once inserted in place?
Old 04-05-2002, 08:04 PM
ripshion's Avatar
Inactive Account
Default Re: Windshield/Dash Creak
No caulking needed with this mod! All you are doing is using the Backer Rod by itself to stop the creak. The Backer Rod slips nicely into place between the dash and the windshield from end to end. You can use a small screwdriver to push it down to get a snug fit. When in place it is hardly noticeable, very clean! Again, no caulking needed!
Old 04-06-2002, 01:05 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Dude Boy's Photo Albums
Last Online: 02-24-2008 12:50 AM
Dude Boy is on a distinguished road.
Originally posted by MarkHolbrook
Ok...
Mark
The noise sounds like someone tapping the edge of a business card on a table. It's most noiceable in cold weather and goes away usually when summer comes. It will absolutely drive you nuts. Sometimes it sounds like it's coming from the center pod and other times it sounds like it's at the base of the windshield. The Frost King foam backer rod will end your problem if you have it.
ADDING POWER HAS NEVER BEEN SO FAST!
Old 04-06-2002, 01:36 PM
tsb tsb is offline
Inactive Account
tsb's Photo Albums
Last Online: 12-27-2004 01:17 PM
tsb is on a distinguished road.
Default over bumps and etc.
it seems i hear it whenever i'm over a bump, pot holes and etc..
it creaks around the radio console and the top of dash, somewhere between windshield and whole dash i guess..
is this the sign of wht u guys are describing?
Old 04-06-2002, 05:53 PM
ripshion's Avatar
Inactive Account
Default Re: over bumps and etc.
Yes, it is the exact sound that I had before I installed the Backer Rod. This mod will take care of that problem! Again, thanks to the person responsible for this fix.
Old 10-06-2002, 08:47 PM
tundralover01's Avatar
Inactive Account
tundralover01's Photo Albums
Last Online: 02-13-2004 12:10 AM
tundralover01 is on a distinguished road.
Send a message via Yahoo to tundralover01
Default Dash noises!!!!!
Does anybody have the annoying problem of their dash making crackling noises when you hit a bump in the road?????
Old 10-06-2002, 09:08 PM
SATundra's Avatar
Dealer : Alamo Toyota
SATundra's Photo Albums
Last Online: Yesterday 11:38 PM
SATundra is on a distinguished road.
Heres an old thread that might help you out.
Fix for dash creaking
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 10-09-2002, 12:22 AM
Inactive Account
aika's Photo Albums
Last Online: 12-26-2002 01:46 PM
aika is on a distinguished road.
all right i went to home depot and asked two guys where the backer rods were and they looked at me like i wasnt speaking english. this is the second time thats happened to me since ive been on this site, both times at home depot. come on guys- whats the real name of the stuff that works with the dash and what is it used for? thatll help next time i go in to home depot and ask those jokers where it is. also, this doesnt cover up the defroster? i havent looked but now that i think about there should be seperate vents right? thanks for the help.
Old 10-09-2002, 03:44 AM
Inactive Account
redmondrr's Photo Albums
Last Online: 06-24-2005 03:27 AM
redmondrr is on a distinguished road.
Default Caulk Backing
The material you need is caulk backing. Home Depot carries Frost King brand caulk backing. It comes in 3/8 and 1/2 inch rolls. If I remember correctly you will find it in the weather stripping section. It'll be a package about the size of a gallon ziploc.
Old 10-24-2002, 11:13 AM
Dealer : Maplewood Toyota
2000 Toyota Tundra,
1998 Toyota Corolla,
2003 Toyota Tundra
mstever's Photo Albums
Last Online: 11-15-2007 08:35 PM
mstever is on a distinguished road.
Default Dash Rattle
Hey everyone,
I recently purchased a used 2000 Toyota Tundra. It's the red access cab model with Package C. I love the truck.
One small problem though. The truck has this annoying dash rattle that occurs when I hit any small or big bump on the road. The noise seems to be coming from the passengers side of the dash.
Anyone have similar problems? Is this just the nature of the beast? The truck only has 43000 highway/city km's on it. I wouldn't expect any noise.
Any comments?
Matt
Old 10-24-2002, 11:19 AM
Dealer : Lustine Toyota/Dodge
Andy's Photo Albums
Last Online: 07-31-2008 12:09 PM
Andy is on a distinguished road.
Is it a rattle or a squeak? If it's a rattle, try taking everything out of the glovebox and see if it happens again. Could be something loose and shaking around.
If it's a squeak, a fellow TS'er Redmond came up with a great solution. Go to Home Depot or wherever and get some Frost King 1/2" caulk backing and stick it in btwn the dash and windshield. You should be able to find it in the weather stripping section of the store.
Lot of members have done this quick and simple mod and it works terrific!
BFG A/T 285.75.16 / MT Classic II's / Fabtech Coilovers / TRD Add-a-Leafs / SkidRow skidplate / Snug Lid / Grey Line-X / Color-keyed front & rear bumpers / Hella Supertones / Husky floor liners / Amsoil bumper-to-bumper / K&N drop-in / Super Magnet oil drainplug / TRD radiator cap / 55w Aux reverse lights / DRL's disabled / Fog light mod / Map light mod / Power outlet mod / Back seat angle mod / Visor labels removed / TS sticker!
