Remember, its not just a scoop. A hole new hood is comin out (carbon fiber). Just check your thread. Its call all the info. I'm supposed to check back around January with SUVconcepts. No one else has a planned Tundra hood. Theres no new info about a hood scoop. And, its too hard to just bolt one on... so you're stuck with the CF hood.
__________________ 2002 Limited TRD Tundra 4x4
Unichip / ASP Underdrive Pulley / K & N FIPK / Bassani Split Side Deuces / White Powdercoated ARB Sahara Bar with IPF 900XS lights and Warn M10000 Winch / Demello Offroad Sliders / ORS Manual Hub Conversion / TRD Limited Slip Differential / Fabtech Performance 3" Lift / Fabtech Performance Rear Shocks / Fabtech 1.5" Add-A-Leaf / 285/75/16 BFG All Terrains / Mickey Thompson Classic II's / Total Chaos Uniball Upper Control Arms / Total Chaos 1" Differential Drop Spacer / Bates Porsche 930 CV Boots / White C/R/C Taillights / TRD Radiator Cap / Molly Designs I.S. Grille w/TRD Emblem / Clear corners / 20% Tint / Better Built Quantum ATB Series bed box / White Rhino Liner / Odyssey PC1700MJT Battery / Wilson 4' White Fiberglass Whip / Cobra 29 WX NW ST CB/PA / Viper 791XV Responder w/530T Window Roll-Up/Down module / Focal 165K2 Polykevlar component set / U.S. Acoustics USX4085 amp / Alpine CDA-7998 / JL Stealthbox
2003.5 BMW M3
Supersprint Sport Exhaust / 15% Tint / CSL Trunklid / CSL Diffusor / 6000k HID Headlights and Foglights / BHS Pulleys
The hood scoops you saw in the pictures are all TRD vehicles (I'm 99% positive on this one). They were custom made for TRD for the SEMA shows. There is no plan for production.
2003.5 BMW M3
I saw a Tundra last week with hood scoops that looked awesome. Guy said they were made by LUND, and he had them painted to match his truck. They install with 3M tape, (which is hidden by the profile of the edge of the scoop against the hood), and they looked great ! Obviously they are not functional, but was a nice addition to the hood.
Classics by Bernt worked on the very first S/Cd TRD tundras body work. i believe they did the same for this one. i'll have to check when i get home because i took a pic of the spec sheet.
__________________ 2001 Sequoia 2WD SR5 Mods: Rollers - 18x9 JAOS Super Ziga wrapped w/ 285/65 BFG A/Ts, Suspension: SAW 2.0 Adj. Coilovers, UCAs, Rear Coilspacers I.C.E. - Clarion H/U w/ built in monitor, DVD Player, Drop Down, Headrest Monitors, Exterior: - Stock OEM Foglights, Wings West Spoiler, Engine:TRD Drop-In Filter
I was looking at www.truckperformance.com at hood scoops for the 2001 Toyota Tundra. They have one, but they say it fits the SR5 model only. Why? It is a fake hood scoop and is applied by 3m tape. What is the difference between the SR5 hood and the Limited hood? Do you think the hood scoop would fit my Limited model? Thanks for any info.
There is no difference between the hood on the Limited and the SR5. I looked at the hood scoop and it would work fine. You could put it on anything really. Hope this helps.
I was wondering if a person strategically placed the hood scoop in regard to the the bottom of the hood structure if it could become functional? If you were to punch a hole into the hood and fab an air duct into the air box?
