Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Member Mods > Knowledgebase Archive
Old 07-22-2004, 08:26 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Yesterday 08:35 PM
nhparrot's Photo Albums
Default Can I install an aftermarket alarm or remote start without voiding my warranty?
Yes, the Magnuson-Moss Warranty Act of 1975 protects you.
The Magnuson-Moss Warranty Act (15 U.S.C. 2302(C))
This federal law regulates warranties for the protection of consumers. The essence of this law concerning aftermarket auto parts is that a vehicle manufacturer may not condition a written or implied warranty on the consumers using parts or services which are identified by brand, trade, or corporate name (such as the vehicle makers brand) unless the parts or service are provided free of charge. The law means that the use of an aftermarket part alone is not cause for denying the warranty. However, the law's protection does not extend to aftermarket parts in situations where such parts actually caused the damage being claimed under the warranty. Further, consumers are advised to be aware of any specific terms or conditions stated in the warranty which may result in its being voided. The law states in relevant part:
“No warrantor of a consumer product may condition his written or implied warranty of such product on the consumers using, in connection with such product, any article or service (other than article or service provided without charge under the terms of the warranty) which is identified by brand, trade or corporate name....” (15 U.S.C. 2302(C)).
Warranty Denied?
Warranty Contacts
Old 07-22-2004, 08:33 PM
nhparrot's Avatar
1997 Toyota Camry,
2000 Toyota Avalon
Default Where are the wires to install an aftermarket alarm in my Tundra?
Refer to the chart below for the wires needed to install an aftermarket keyless entry, alarm or remote start on your Tundra.
Item - Wire Color - Location
Starter - Green/Black - Ignition Harness
12V Constant - White/Red or White - Ignition Harness
Ignition - Black/Yellow - Ignition Harness
Second Ignition - Black/Red - Ignition Harness
Accessory - Blue/Red - Ignition Harness
Tach - V8 - Blue/White *1 - Instrument Cluster - Brn Plug
Tach - V6 - Black *2 - Instrument Cluster - Brn Plg
Speed Sense (4k) - Green/Orange - Instrument Cluster - Brn Plg
Brake(+) - Green/White - Left Kick Panel
Courtesy Lights(-) - Black/White - Left Kick Panel
Parking Lights(+) - Green - Left Kick Panel
Parking Lights(-) - Red/Black - Steering Column
Headlights(-) - Green/Yellow - Steering Column
Domelight Supervision - Use Door Trigger
Door Lock 3 Wire(-) - White/Green - Left Kick Panel
Door Unlock 3 Wire(-) - Red/Yellow - Left Kick Panel
Door Trigger(-) - White/Blue - Driver's Door Harness
Lock Motor - Blue/White - Driver's Door Harness
Unlock Motor - Black/Yellow - Driver's Door Harness
Power Window F. Left Up(+) - Light Green - Driver's Side Switch
Power Window F. Left Down(+) - Blue/Yellow - Driver's Side Switch
Power Window F. Right Up(+) - Red/Black - Left Kick Panel
Power Window F. Right Down(+) - Red/Green - Left Kick Panel
Disarm Defeat - Red/Yellow - Driver's Door Harness
Horn(-) - Green/Red - Steering Column
Wipers (+) - Blue/Black - Steering Column
Factory Alarm Disarm(-) - Blue/Black - Driver's Door Harness
*1 - You can use the Blue/White on connector E4 of the ECU or the Black/Blue at coil #1 on the drivers side.
*2 - The black wire is also found on the drivers side of the motor at the diagnostic connector.
These wires are confirmed on 2000/2001 Tundra - verify against wiring diagrams for other years
