Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Member Mods > Knowledgebase Archive
Closed Thread
Old 09-21-2004, 07:35 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 06:22 PM
nhparrot's Photo Albums
Default INFO: Highlander Resetting Engine Oil Replacement Reminder
The system must be reset after the engine oil replacement. Reset the system by the following procedure:
1. Turn the ignition key to the “OFF” position with the odometer reading shown.
2. Turn the ignition key to the “ON” position while holding down the trip meter
reset knob. Hold down the knob for at least 5 seconds. The odometer indicates “000000” and the light goes off.
If the system fails to reset, the light will continue flashing.
~Glenn
Closed Thread
