INFO: 4Runner Resetting Engine Oil Replacement Reminder
Reset the light by following the procedure below:
1. Turn the ignition key to the “ACC” or “LOCK” position with the odometer
reading shown.
2. Turn the ignition key to the “ON” position while holding down the trip meter
reset button. Hold down the button until the light goes off. Before the light goes off, it illuminates for 3 seconds, flashes for 2 seconds and illuminates for 1 second. If the system fails to reset, the light will remain flashing.
~Glenn
