Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Land Cruiser
Old 11-30-2007, 05:11 PM
Herculz's Avatar
Dealer : Claremont Toyota Scion
2006 Toyota Tundra Limited 4x4 DC
Last Online: 04-25-2008 02:16 AM
Herculz is on a distinguished road.
Herculz's Photo Albums
Default 80series issue with ignition swith on my 94
Hello everyone, i have run into this issue the second time in a month, my first time i had this issue i had a locksmith come out and fix what ever was wrong, i would insert my key and thats all i could do, it will not rotate, today 2-3weeks after the repair i ran into this issue again and had AAA come out and the tech tried to get it to turn and after inserting it and tapping on the key inward after fully inserting it, the key turned. Is this common and whats the fix? can i get an ignition switch and replace it myself or does it require specialty tools? THanks
Old 12-01-2007, 12:20 AM
firetruck41's Avatar
Dealer : Vancouver Toyota and Scion
1996 Lexus LX450 locked and lifted
Last Online: 11-15-2009 03:08 AM
firetruck41 is on a distinguished road.
firetruck41's Photo Albums
Default Re: 80series issue with ignition swith on my 94
Have you checked to make sure your "park" interlock switch is intact? IIRC, the ignition is set up so that you can not turn the key if it is not in Park (or maybe neutral too?). Anyway, try wiggling the shifter when you are turning the key, maybe the interlock is not quite getting switched by the tranny shifter. Also, try turning the steering wheel back and forth a smidge, while turning the key, in case there is pressure on the steering wheel lock causing it to bind.
How many miles does your rig have?
Ben
1996 Lexus LX450, 129k, front/rear factory locking differentials, Cooper STT 285s, OME 850/863 suspension lift, CDL/Pin 7, 30qt freezer, 2@aux fuse blocks, aux powerpoint, 850w inverter
1998 Lexus LX470, 139k- SOLD
1993 Land Cruiser, 198k- SOLD
Old 03-02-2008, 08:21 PM
Dealer : Toyota Scion South
2003 Toyota Tundra
Last Online: 03-09-2009 07:07 PM
71-CRUISER is on a distinguished road.
71-CRUISER's Photo Albums
If your lock cylinder is damaged you should be able to replace the whole piece fairly easily.
Michael Harness
www.AtlantaCustomCreations.com
TLCA #14378
03 Tundra 4x4
71 FJ-40 351w, NP435, SOA, 38.5s SXs, Disked/Longed/Aussie/4X4 Labs front, welded rear, MetalTech, Saginaw etc.....
