Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Land Cruiser
Old 11-21-2008, 05:41 PM
2008 Toyota Land Cruiser
Last Online: 11-21-2008 05:41 PM
alfalasi101 is on a distinguished road.
alfalasi101's Photo Albums
Exclamation i need help with the spark plugs
hi
i have a toyota land cruiser v6 4500 EFI 71 and it has the denso K16tr11 spark plug on i would like to replace them with the trd spark plugs IK24 but i am confused becouse the orignal ones are 2 headed and thik head the trd ones have a fine tip and single head so if change them to the TRD will that harm my car ?? i dont really know the diffrnce between them unfrtunatly i have alreday bought the TRD one i thout they where the same .
hope to get a replay soon .
thanks
Old 11-26-2008, 10:49 AM
Krookz's Avatar
Dealer : McGeorge Toyota
2006 Toyota Tacoma
Last Online: 05-11-2009 10:52 PM
Krookz is on a distinguished road.
Krookz's Photo Albums
Default Re: i need help with the spark plugs
Probably the wrong fourm, but the Deno's are most likley the Iridium plugs. The tip looks smaller but its alot better, the TRD ones are most likely the NGK plugs.
Old 11-27-2008, 07:42 PM
Dealer : Toyota Of Scranton
2005 Toyota Tacoma,
2002 Toyota Sienna,
2007 Toyota Tundra mark
Last Online: 08-30-2009 09:38 AM
Gregory_K is on a distinguished road.
Gregory_K's Photo Albums
The second "head" is a back up in case one falls off.
Old 12-14-2008, 11:43 PM
Last Online: 12-14-2008 11:43 PM
sako243 is on a distinguished road.
sako243's Photo Albums
hy gregory im from ne pa. bought my tacoma from the scranton dealer too any problems with the service there? ill be taking mine in for the first oil change.
Old 12-16-2008, 10:42 PM
Dealer : Valley-Hi Toyota
2005 Toyota Tacoma,
1995 Toyota MR2 1991 Sunroof w/ 1MZ
Last Online: Yesterday 11:39 PM
Jason.MZW20 is on a distinguished road.
Jason.MZW20's Photo Albums
The TRD ones are too cold for your application. 16 is your heat range, while the TRD ones are using a 24. Denso plugs are rated lower for hotter, and higher for colder (opposite of NGK). The TRD one is probably recommended for the supercharged 4.5L.
If you want iridiums, try SK16R11. It's OEM spec for Toyota, and will last quite a while.
Don't worry about the dual grounds. Toyota used these on some distributor-based V6/I6s and most early direct ignition motors w/ wasted spark to ensure proper firing. The smaller tip on the iridiums requires less voltage and doesn't need an additional ground.
2005 Tacoma Double Cab V6 4x4 w/ TRD Off-Road pkg., Auto
1991 MR2 V6 (1MZFE)
Old 02-27-2009, 08:25 PM
Last Online: 02-27-2009 08:48 PM
BAM-BAM is on a distinguished road.
BAM-BAM's Photo Albums
Originally Posted by alfalasi101 View Post
hi
thanks
should be fine as long as they are for your vehicle & the threads are the same.
Old 07-11-2009, 03:08 AM
allangering
This message has been deleted by Tundradrenalin. Reason: phishing from international waters
