my 02 LC just resently stared ( yes i probably did it) chipping 4 times then a last blast 5-10 sec later when I hit the alarm? what's a boy to do? I liked it better when it only beeped twice
any help out there?
any help out there?
Bass playing fool
Thump ta da thump
What does your alarm remote look like?
Is it built into the key?
What state are you in?
I need to know which alarm you have. Some states (gulf states use differant alarms).
Do you know if it was a Factory install or port installed, or added at the dealer?
Thanks
25 yrs with TOYOTA
Thanks
alarm built into key,
CA
Factory? I really don't know
the key is factory Toy
hope this helps
thanks
If it beeps 3 times when unlocking it, it means someone has set off the alarm and it has reset itself.
25 yrs with TOYOTA
it used to beep once? I think t's been a long time since it worked "right" a week, may be twice
but NOW it beeps 4 times the the delayed beep total 5 irritating times, i thought i read that there was a way to change the deeps?????
i up for suggettions
I have rear thru the whole alarm book w/install and diag instructions and it doesnt explain the beeps anywhere.
I have asked a freind of mine at Toyoyta Denver Region, but he is having trouble finding this info as well.
I am still looking
25 yrs with TOYOTA
I'll wait thanks, for the persistance,
does anyone know which system this is? RS3200??
is the system not in normal mode?
ookacho boop
Yes it is the RS 3200
and No I dont think it is in normal mode.
PM sent
25 yrs with TOYOTA
