Re: replacing torn radio mast for TLC Prado
This is for a 2001 RX300.
I have included some PDF's to help.
Your right if the cable broke, then you have to remove the antenna assy and open it up, remove the broken piece. Re-install antenna and then feed in the new cable/mast assy.
25 yrs with TOYOTA
