Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Land Cruiser
Old 10-22-2006, 04:14 PM
lexusdriver's Avatar
Dealer : Lighthouse Toyota Scion
2000 Lexus LX470,
2003 Lexus IS300 Manual Transmission
Last Online: 04-24-2007 10:38 AM
lexusdriver is on a distinguished road.
lexusdriver's Photo Albums
Default Pads & Rotors
I'm trying to change the pads and rotors on the front of my 2000 Lexus LX 470 (sounds easy, right?) and I can't figure out how to get the rotors off. The calipers are easy enough to remove and the pads can be replaced like any other car I've ever had, but I can't figure out how to remove the rotors. I signed up here hoping to find a downloadable PDF file that would cover this but have had no luck. I found all the info for a Tundra, but the calipers and wheel configuration are totally different. Any assistance would be greatly appreciated. Thanks!
Old 11-07-2006, 11:10 AM
Dealer : Rudy Luther's Toyota
1997 Toyota Land Cruiser
Last Online: 11-07-2006 11:24 AM
cdvorak is on a distinguished road.
cdvorak's Photo Albums
Default Re: Pads & Rotors
I did this work on my 1997 Lancruiser a few months back. You need to remove the hub to get the rotors off if its set up like mine. You will need a hub wrench and may want to change the wheel bearing grease as well. From memory it goes something like this.
1. Take a chisel and remove the dust cap.
2. There is a lock washer inside that needs to be bent so you can loosen the big nut, hub wrench is like 24-30 mm cost about $15.
3. The hub and rotor will then slide out along with the bearings. Keep everything clean and keep track of what goes where.
4.I do not recall how the rotor seperates from hub. Look at the new rotors and it should be clear.
5. Put it back together.
6. Tightening the bearings is tricky. Some say you have to use a tool to measure the tightness. Or you can put it back where you found it or you can tighten it up real snug while you spin the hub and back it off a little.
Chris
Old 11-11-2006, 10:49 PM
Dealer : Wilson Toyota
2000 Toyota Land Cruiser
Last Online: 11-11-2006 10:50 PM
kwb210 is on a distinguished road.
kwb210's Photo Albums
Default wh the rotors?
How come you need to remove the rotors? I replaced pads, out with the old and in with the new, certainly no reason to remove the rotors in my case. So I'm curious, why do the rotors need to come off? How many miles on your vehicle? I have 75,000 miles, replaced just the rear pads, which surprised me that the rears went first, usually the fronts do most of the work.
kurt
2000 tlc
All TS members please read and help nocturnal_demon_13 Brakes 8 11-07-2005 10:22 PM
Need Help - Frozen Rotors, Carbon Kevlar Pads - Way Too Noisy!!! fteter Suspension & Axle 53 05-29-2005 12:26 AM
COMPLETED GROUP BUY: SP Brake Rotors Jack Burton Group Buys 74 04-25-2005 10:38 PM
PROPOSED GROUP BUY: SP ROTORS, HAWK & PERFORMANCE FRICTION PADS Jack Burton Group Buys 33 04-10-2005 05:27 AM
Bed in procedure for ceramic pads and Brembo rotors? keninsb Suspension & Axle 4 04-05-2005 12:08 AM
