1. Remove the driver's sidekick panel.
2. Unplug the 8 pin connector, coming from the ignition switch.
3. Unplug the other 8 pin connector next to it (looks like an 8 pin connector that loops into itself).
4. Connect the ignition 8 pin connector into the one you just unpluged and the other into the ignition plug. That should get your RS3000 plugged in and ready for programming.
5. To activate it, turn ignition to the "ON" position and press both buttons on your transmitter for over 2 seconds, then press the top button once to activate (button you use to unlock your truck). All this should be done w/in 30 seconds or else it goes back to its original state.
Edited from thread
RS3000 Security, TOTAL RIP OFF
GBS ECU #08192-00970 (Approx $30.00 plus tax)
Status Monitor #08192-60880 (Approx $35.00 plus tax)
