Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Member Mods
Old 05-27-2002, 07:08 AM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 07:17 AM
nhparrot's Photo Albums
Lightbulb HOW-TO: Disable Daytime Running Lights (DRL's) on a Sequoia
Sequoia's with DRL's have a gray electrical connector (D1) located between the battery and the inner fender liner. This connector is fastened to the fender liner and has two wires leading to the Daytime Running Lamp Resistor, also fastened to the fender.
Disconnect this one and your daylight running lights are inoperative. If you change your mind simply reconnect and you are back to stock.
Link to > Location of DRL Resistor
see DRL Disable Mod Pic courtesy of Ring Steel
