Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Member Mods
Old 05-27-2002, 06:58 AM
nhparrot's Avatar
Assistant Administrator
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: 10-10-2009 08:00 AM
nhparrot's Photo Albums
Lightbulb HOW-TO: Disable Daytime Running Lights (DRL's) on a Tundra
There are two ways to disable your DRL's.
Method 1: Tundra's with DRL's have two gray electrical connectors located between the battery and the inner fender liner. One of these connectors (D2) is fastened to the fender liner and has two black wires leading to the Daytime Running Lamp Resistor, also fastened to the fender.
Disconnect this one and your daylight running lights are inoperative. If you change your mind simply reconnect and you are back to stock.
Link to > Location of DRL Resistor
see DRL Disable Mod Pic courtesy of Ring Steel
Method 2: Link to > Toyota Technical Service Bulletin EL0011-00
