Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Member Mods
Old 11-28-2004, 12:23 PM
MrBeanley's Avatar
Dealer : Toyota Of Portland
2004 Toyota Tundra
Last Online: Today 08:39 PM
Images: 5
MrBeanley is a splendid one to behold. MrBeanley is a splendid one to behold.
Send a message via Yahoo to MrBeanley MrBeanley's Photo Albums
Default Defroster Mod for Double Cab
Ok, for all you "control freaks" out there, I just figured out how to "fix" the defroster on my Double Cab.
Since I bought "Brutus", its driven me nuts that the A/C has to run when the defrosters are on. There's plenty of times when I'd just like the air blowing on the defrosters, not the A/C. And, since I am an admitted control freak myself, I also would like to have separate control over the recirculate/fresh air setting when I'm in defrost mode. So, I've "fixed" it!
The mod is:
1) Remove the "Integration Panel" thingy. Pull off the three control knobs, and you'll see a phillips head screw behind each. Then, tilt back both of the air vents (next to the radio) as far as they will go. You'll see two more. Take 'em out.
2) Now that you have the screws out, pull. There are some clips holding the IP in place, but it pulls out very easily.
3) With the IP out of the way, you will be looking at the HVAC controls, which look like
http://www.tsphotopost.com/photopost...cat/500/page/1
Slide this panel straight down, and it comes out. Now you're looking at the top of it...something like this:
4) Now, you'll have to do some bending and contorting, but you need to look under the thing. There's a small microswitch at the far right side (passenger side). Just pull off one of the plugs ( like http://www.tsphotopost.com/photopost...cat/500/page/1 )
...and, now, you have complete control over the HVAC.
Basically, this switch is what tells the Body ECU that you've turned on the defrosters, so it can override your AC and Recirc settings. Since the switch is always open now, the computer never knows! (Bwaaaa ha haaa!)
Good luck.
MrBeanley
Glenville, New York
2004 Tundra Double Cab 4x4
Old 12-26-2005, 11:11 PM
MrBeanley's Avatar
2004 Toyota Tundra
Images: 5
Default Defroster Mod for Double Cab (Updated Links)
The mod is:
http://www.tundrasolutions.com/photo...0/ppuser/24247
4) Now, you'll have to do some bending and contorting, but you need to look under the thing. There's a small microswitch at the far right side (passenger side). Just pull off one of the plugs ( like http://www.tundrasolutions.com/photo...0/ppuser/24247 )
Good luck.
MrBeanley
Glenville, New York
Old 12-27-2005, 07:14 PM
ToyzOnly's Avatar
Dealer : Folsom Lake Toyota Scion
1998 Toyota Avalon XLS
Last Online: 09-01-2008 01:04 AM
ToyzOnly is on a distinguished road.
ToyzOnly's Photo Albums
Default Re: Defroster Mod for Double Cab
There's those pix I was lookin' for.
Thank you sir!!!
And they've been in your gallery the whole time.
I should've checked your "NEW" gallery since it was re-arranged a while back.
Thanks for re-linking them. Mucho appreciation.
