Subwoofer install 05 Taco DC
Decided to put an 8" Kicker Comp VR sub behind the rear seat back on passenger side, same place the factory sub is located with the JBL system. Box dimensions are 20" wide, 9.5" tall, depth at base is 8" and depth at top is 5". That gave me an interior volume of .4 cu. ft., which is the recommended minimum for this speaker. I could have went wider, but I wanted room for the amp behind the seat also. It was a little tricky to build, as the front has to be angled to keep clearance from the seat back. The black plastic unit that I had to remove is 2 pieces and I just removed the portion from behind the passenger side. I thought about cutting it and reinstalling the upper part to cover the exposed metal(rear of cab), but that would not have been reversable, so I just covered the metal with black felt. Pics attached.
