Go Back   Toyota Tundra Forums : Tundra Solutions Forum > News and Events Forums > Mid-Atlantic
Old 09-19-2007, 10:35 AM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 04:05 PM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Default Alignment Shop in Virginia Beach
Bert's Alignment, Balance & Brakes since 1988.
The shop is inbetween Independence Blvd and Witchduck Rd.
I had a good experience, thought I'd share (price was comparable to other shops). I called in and got an appointment, took them 1 hour to align. They let me in the garage during the entire process, but not under the truck. I talked with the mech, told him the specs I wanted. He said no problem, even guided me through each step he was doing. He told me my caster was causing my pull to the right. Drives pretty good now.
Here's my readings.
before
cam: -0.25,-0.25
cas: +1.00, +0.75
toe: didn't see
after
cam: +0.25,+0.25
cas: +1.25, +2.00
toe: +0.08
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Follow up alignment hank75 Suspension & Axle 1 03-23-2007 12:00 AM
New Plugs nhparrot Engine & Drivetrain 1 10-21-2006 01:14 AM
DJ, another Alignment question brshooter Suspension & Axle 3 03-04-2006 06:51 AM
Alignment problem MATRDguy 1Gen-Tundra 9 01-26-2006 11:50 PM
DJ's Alignment Setting Recommendations nhparrot Knowledgebase Archive 0 04-10-2002 06:50 AM
