Question on Ball Joint Recall and Yet to be installed Coilover Lift
Hey folks,
I just got the letter in the mail about my ball joint recall on my '05 DC. I have a couple questions though that I thought one of you could answer.
1. I need an alignment anyway, will they be doing an alignment when they do this? (Hoping to save a few $$$'s) I thought I read that they do one during this, but perhaps not.
2. I have a set of Donahoes in my basement waiting to go on. Should I put them on before or after the ball joint replacement? Thinking again to the alignment. If I have to get an alignment done anyway, why not kill two birds at once. But......I don't want my dealer to tell me I'm not eligible for the replacement because I've modified my suspension. (my dealer does not seem to like aftermarket mods.....)
Thanks in advance.
2005 Tundra DC SR5 4x4 Timberland Mica De-badged, Borla Dual Exhaust, Westin Bull Bar and Oval Nerf Bars, Extang Tonneau, Rhino Liner, PIAA 520s, Donahoes, Mickey Thompson MK IIs wrapped in BFG ATs 265/75/16. (soon to come, billett grille)
Re: Question on Ball Joint Recall and Yet to be installed Coilover Lift
Originally Posted by pluslt
Hey folks,
Thanks in advance.
I don't think there is an easy way out of this.
You should probably go get the ball joint work done first. They may align it; they may not. If they do align it, it should be free as a part of the recall.
Then go do the Donahoes and have it aligned again at your expense (which you would have to do anyway)
If you put on the Donnies first, they might well say "you altered your suspension; we are not honoring the recall." Then you have brand new coils but old ball joints (which could conceivably wear out even faster now).
So yeah, get the recall work done first. It is going cost you either way, but this way will cost you the least.
Go ahead and put the coilovers on..i put my Donahoe CO's and Camburg UCAs on and then about a week later i got the letter in the mail, took it in, alignment done
Hey folks,
Thanks in advance.
my dealer didnt do an alignment after my recall. he said the reason for it was they take note of where you toe and camber were at before and after..if they are the same they dont touch it...if different then they do whats needed to be done. thats the way i was told.
__________________ 2006 silverado with full bolt on's and its fast
if they called for a RECALL of a part they put on that IS defective, they should replace it no matter what you've done to your truck. The recall notice states that the LBJ was bad since the beginning, what's the difference if you've jacked it up? It's been defective since it came out of the container!
*side note: I had my LBJ done one day before the lift* (haha)
