Go Back   Toyota Tundra Forums : Tundra Solutions Forum > General Forums > Off-Roading
Old 09-22-2007, 11:57 PM
Jwitz's Avatar
Dealer : Stokes Brown Toyota
Last Online: 11-12-2009 12:00 PM
Jwitz is on a distinguished road.
Send a message via AIM to Jwitz Send a message via Yahoo to Jwitz Jwitz's Photo Albums
Default DIY: front t-case seal replacement
Was going to let ya'll know that after 96000 miles, the front seal on my transfercase (to the front driveshaft) is leaking... The good thing is the TOYOYA part was only $10. I've done lots of work on my truck, but this is a first for me, so if anyone wants directions, I can certainly post a play by play...
2000 Tundra
4x4
6spd
v6
285 Nitto Terra Grapplers
Donahoe Racing Coilovers
Total Chaos UCA's
arb bumper
12000lb warn w/ amsteel line
optima batt, 130amp alternator, KC daylighters
Poly steering bushings
custom long travel swaybar links
HAM: KI4RXK google me! www.gaprs.net
Old 09-23-2007, 11:00 AM
jim65wagon's Avatar
Dealer : Palmiero Toyota
2003 Toyota Tundra SR5 4x4
Last Online: Today 05:23 AM
Images: 3
jim65wagon is on a distinguished road.
Send a message via AIM to jim65wagon jim65wagon's Photo Albums
Default re: DIY: front t-case seal replacement
yeah do the play by play with lots of pics! Mines not leaking but with 90,000 on the clock you start watching things and hearing noises...
2003 SR5 V8 4x4 Access Cab; SS Autochrome intake with AEM dryflow; Truxedo cover; Rhino lining; 255/85/16 Cooper Discoverer S/T's; 16x8 Black Steel Wheelers; Ram Air; breather extensions; Viair 380COBA; Donahoe coilovers; Deaver 3leaf AAL; homemade bed rack; 21 gallon water tank, front Hidden Hitch w/Superwinch...
The 140,000 Mile Tundra Thread
Old 09-23-2007, 10:18 PM
Jwitz's Avatar
Well my camera is in the truck, so no pictures today, but hopefully tues if the dealership can get the parts in... OH YES, the parts... so apperantly I have a transfercase that no one in town stocks seals for... I'm sure all the rest of you V8 auto guys have this seal, but my v6 manual has a larger OD seal... yea, that was nice to find out as my stuff is all apart.... D***.... but as soon as I get it all back together I'll give yall a nice write up for you DIY'ers out there... so far it's actually pretty easy... impact gun is a pre-requisite though...
2000 Tundra
4x4
6spd
v6
Total Chaos UCA's
arb bumper
Old 09-24-2007, 03:41 PM
Dealer : Western Slope Auto Co.
Last Online: 10-23-2008 10:54 PM
elks is on a distinguished road.
elks's Photo Albums
Yes mine on 01 V8 is leaking a little also. I will replace it if it is easy enough.
Cna't wait for write up.
Old 09-26-2007, 09:36 PM
Jwitz's Avatar
Well, I thought I was going to do it tonight, but it will be tomorrow, probably during lunch. Well, I think I have the right seal now, at least it LOOKS the same, so hopefully it will be quick tomorrow... I promise to have lots of pictures and some part numbers! And it is easy to do yourself... till tomorrow !!!
2000 Tundra
4x4
6spd
v6
Total Chaos UCA's
arb bumper
Old 09-28-2007, 12:49 AM
Jwitz's Avatar
Here as promised is the how-to replace your transfer case output shaft seal (the one that goes to your drive-shaft). Note that this was performed on a 2000 v6 manual extended cab tundra.
To get ready to do this, you need some tools and parts.
The seal was P/N 90311-41012 and cost about $11.50 from the stealership.
Be very particular to actually see what part you are getting, because the first seal I got was the input transfercase seal (which goes between the tranny and the tcase.
The thing is, they will both fit the shaft, but the outer diameter is not the same. Note that both Advance and Auto Zone had this input tcase seal, so I really could only get the output seal from the dealership.
Next you need some tools. You will need a 14mm wrench to pull off the drive-shaft, a 12mm wrench is you decide to pull off the tcase skid plate, a 24mm socket (I think) to change the fluid, a 30 mm socket to pull off the tcase output nut (preferably impact), Impact wrench or V.long breaker bar, small punch, large hammer (blacksmiths), seal puller, possibly a two jaw puller, and a propane torch. Note that I didn't use all of these, but some of them would have helped.
First you need to pull off the drive-shaft. Here I used a combination of box end wrenches and special high torque wrenches that don't strip the nuts.
Here is also where I didn't use the propane torch, but it would have helped. The nuts are held on with Toyota thread locker, and you CAN bust them loose without too much trouble, but heat would make it a lot easier.
After pulling off the four nuts and washers, you can just set the shaft to one side, I didn't need to pull the entire thing out. (NOTE - to rotate the shaft and break the nuts, you will need to turn the 4wd on and off repeatedly)
After the shaft is moved to the side, you can see the 30 mm nut that is punched to keep it from rotating. First you need to use the punch and hammer/mallet to push the indentation back out. I used a round punch and it worked okay, my Chilton's has the guy using a flat punch, but it's really small so you may want to get it from a specialty store, Auto Zone and Advance didn't have a flat punch (only round). I really wasn't able to make this look nice, but I got it most of the way there.
Now, this is really a make or break part, as I could not get the nut off with just a two ft cheater bar. I was able to borrow a friend's impact and it came off without really any fuss. I didn't have to really hammer on it, it came off quickly, but it's just not something that a 2ft cheater bar will do.
After the nut is off, things get real easy. You can drain the t-case before hand. I didn't.. You pull the flange off, I started to use a puller, but very quickly it came loose and I just pulled it off... It really wasn't even worth putting it on, considering how easily it came off...
Take a good look at the flange and make sure it's not damaged. Note that there is an internal seal right behind the large nut. Check to make sure it's not damaged.
Now get out your seal puller and negotiate the seal out... It took almost no effort to get it out, and that's it your at the halfway point!!!
Now is a good time to look at the seal that you are pulling out... You will notice an outer dust flap, an outer sealing edge and an inner sealing edge... On mine, there was some grime in between the inner and outer sealing edges, and that caused the inner edge to wear away. This is what caused the leak, the seal was no longer small enough.
Get out your new seal and you will see that it should be 59 mm in outer diameter.
(Wrong seal)
With some grease inside the seal and outside, I was able to push the seal in BY HAND!!! Took no "Negotiating."
After this, clean the flange and slip it back over the splines of the tcase output. My nut was marked in blue marking paint and was easy to torque back to what it was originally (Chilton's calls for 87 ft-lbs, I'm sure you can do this, but as long as you punch it, it's not going anywhere). I re-punched the original tab back in.
Filled the T-case with some 75-W90 mobile 1 fully synthetic. Check for any major leaks. Reattach the drive-shaft to the flange. I didn't do this (cause I forgot), but apply some locking compound to the flange studs and tighten down the nuts... And you are done!
2000 Tundra
4x4
6spd
v6
Total Chaos UCA's
arb bumper
Old 02-06-2008, 04:38 PM
jim65wagon's Avatar
Images: 3
Great writeup! Of course I spoke too soon, after a mere 98,000 I now face this same procedure...off to the parts store!
Old 05-13-2008, 10:43 AM
apimpdad's Avatar
2002 Toyota Tundra
Last Online: Yesterday 11:20 PM
Images: 57
apimpdad is a splendid one to behold. apimpdad is a splendid one to behold.
Send a message via AIM to apimpdad apimpdad's Photo Albums My eBay
Thanks for the writeup! Mine just went out at about 58k and I replaced it myself with no problems at all!
SAS Tundra
Build Thread-
SAS on 02 Tundra
Old 05-13-2008, 11:18 PM
TMS2U's Avatar
Moderator
Dealer : Longo Toyota
Last Online: 10-01-2009 03:29 PM
TMS2U is on a distinguished road.
TMS2U's Photo Albums
Default Re: DIY: front t-case seal replacement
Very nice write up!
I'll nominate you for the DIY contest!
Old 05-27-2009, 01:41 PM
Dealer : John Weiss Toyota City
2009 Toyota Rav4 V-6 FWD,
2000 Toyota Tundra SR5 TRD 4X4
Last Online: Yesterday 07:38 AM
Images: 1
INDYMAC will become famous soon enough.
INDYMAC's Photo Albums
I was able to fix this seal leak using Auto-Rx:
Auto-Rx Cleans Internal Engine Transmission Motorcycle Power Steering Differential Diesels, Stop Leaky Seals, Oil Burning, Increase MPG
I put 3 ozs in the T-case and within 200 miles the leak stopped. I did a drain and refill after 1000 miles and it looks like a bone dry, brand new unit now. It also fixed a steering rack seal leak on my G35. It also saved my Tundra tranny from an early grave (hard/violent 2-3 shifts). I love this stuff. My Tundra has 159K miles and is almost 10 years old now. I think anyone experiencing seal leaks, tranny shifting problems, or engine oil consumption and sludging should give Auto-Rx a try first before doing extensive maintenance procedures. They may not be necessary.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/off-roading/111466-diy-front-t-case-seal-replacement/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-18-2009 02:41 AM
All-New 2007 Lexus ES 350 Sedan Packages More Power, Performance, Luxury and Safety i TS Support Toyota, Scion & Lexus News 0 09-12-2006 09:07 AM
Lexus IS 250/350 Luxury Sport Sedans Offer New "X Package" for 2007 TS Support Toyota, Scion & Lexus News 0 09-12-2006 09:00 AM
Front seal leaking 5 speed trans cos289 Out-of-Production Trucks & SUVs 1 08-16-2006 12:04 PM
89 front oil seal Sunhouse Out-of-Production Trucks & SUVs 2 07-05-2006 01:33 PM
All-New Fifth-Generation 2007 Lexus ES Sedan Redefines Entry Luxury Segment nhparrot Toyota, Scion & Lexus News 0 02-09-2006 05:50 AM
