Originally Posted by iforceV8
Thanks Sean, as always..very helpful....
I got these when Bill West first came on the site..so they are several years old. They have been in sunny socal since they were mounted. The shafts looked pretty smooth last time I was changing my oil.
I'll email a few places to see if I can add an ext res to the shock while they are out. I remember when I had these installed Bill said it would be about an extra $100 per side.
I might pick up a TC LT kit soon, Can get it without coilovers and just use the current TW SAW + ext res? Or would this setup not be ideal. The difference would be a 2.0 dia shock vs 2.5'' dia
Also if you add the external resi, you can avoid the nonsense I got in to, trying to get a charge in those deep Schraeder valves! It cost about a hundred bucks to get them machined down
. I shoulda just got resis
Bill chose the 8" shaft so the kit would be bolt-on for the Chaos and Camburg bolt-on LT kits, it should work great. I remember him saying he's jumped it plenty, that was with the original 2" bodies like you and I have. I'm planning that route in a few weeks and don't expect any problem at all.
Shelby (I think?) is selling a Chaos LT kit, over at SoCalTundras, and editmars is selling a set of used LT axles, CV to CV, for the ADD...I was gonna get them myself but I'm after the Camburg kit and the manual hubs would mean by the time I got mars's used axles and converted them for my kit, I could have bought new axles
. If you're seriously considering it, you can probably get the parts cheap through those guys. Bill's shocks should bolt right up, you'll still need limit straps but you'll be using the shocks the way they were designed.
-Sean
