Originally Posted by DevinSixtySeven
I thought you ditched the stock case.
How did you fool the ECU? I think that's exactly what I need.
Two position switch, one position normal, one position spoof.
How do you shift your stock case? Do you still have to hit both buttons sequentially?
no i am still running the stock t-case also, didnt feel like replacing the whole trans just to remove the stock t-case. but anyway, i was fooling around with the connector that plugs into the front ADD, randomly connecting wires, checking if some wires were live, blowing fuses, and i finally got the t-case to work. it is really hard to explain how it works, but this is how you engage it. you flip a toggle switch (that i installed) to the on position, push the 4hi button, wait for it to engage, and in neutral, press the 4low button to engage that. and when you are done, disengage 4hi/4low and then flip the toggle switch off. it is kinda booty fab but it works. i have some pics somewhere of the connector with the wires that i hooked up to it. i will see if i can find them.
