Go Back   Tundra Solutions Forum > General Forums > Off-Roading
Free Shipping at Buy.com!
FREE Personal Trainer Program
Off-Roading Discussions specifically related to modifying and driving your Toyota truck/SUV off the pavement, including trip reports.
This is a discussion thread titled "The Old Rope Trick", within the Off-Roading forum, part of the General Forums category.
Old 11-18-2007, 11:06 AM
Tundra_Hick's Avatar
Dealer : Amador Toyota
2004 Toyota Tundra,
- Other - 1969 Mustang
Tundra_Hick's Photo Albums
Last Online: Yesterday 08:41 PM
Tundra_Hick is on a distinguished road.
Default The Old Rope Trick
For quite some time I've been describing a way to get yourself unstuck.
My father taught me, now I'm gonna lern Y'all good!
Now where did I put my lernin' switch?
First you need rope, any length over four feet will do, the more the better.
Second, you need to wrap the rope around the tire, through the rim holes, and repeat. Start where the tire is exposed working your way over the top side, back down to the ground where it goes into the mud.
Pics will help.
As you can see, it gives the smooth tire lugs like a tractor tire.
Make sure you tie the rope in a spot where you can access it later.
While it is possible to drive for quite some time with the rope on, I'd suggest you untie it as soon as its no longer necessary. If not, the rope will eventually break and wrap itself around your axle or worse, around your brake lines.
Works like a charm everytime, whether in mud or snow.
The Tundra is a good single guy's truck. Its pretty, it doesn't rattle too much and its fast. Now I just need to find a woman who matches in all those respects.
Old 11-18-2007, 06:28 PM
TUNDRA786's Photo Albums
Last Online: 08-23-2008 04:44 PM
TUNDRA786 is on a distinguished road.
Default Re: The Old Rope Trick
Ive heard about people doing that before. It would probably be pretty hard to do if your already stuck though. It would take a while to do on all 4 tires as well and then removing them all muddy would suck!. But that would come in handy if your up in some crazy area camping and the only way out is through some nasty mud....
TUNDRA786
2007 Tundra Crew Max 4.7 TRD 4x4
285/65/18's with BF Goodrich All Terrain KO's
BedRug, Undercover, Bed Extender, Husky Liners
Old 11-18-2007, 06:29 PM
Have you tried that before?
TUNDRA786
Old 11-18-2007, 06:50 PM
2004 Toyota Tundra,
Yup, I was driving a 2wd on wet clay. I couldn't get any traction at all, the treads on the tires we full and it was a fairly narrow logging road. If I spun the tires too much, the truck would slide sideways toward the ditch.
I thought I was completely buggered, nobody to tow me and to make matters worse it was raining and the clay was oozing.
I only had 1/4 inch rope, the tires were in about 5 inches of mud, so I started wrapping on the exposed portion of the tire. I then put he truck in gear and gently pushed the accelerator. When the tire moved forward, I continued wrapping the rope around the now exposed part of the tire.
In total, I think I drove for about 4 miles until I got to a better road. I then took all the rope off and threw it into the back of the truck.
Old 11-18-2007, 08:48 PM
ddnail's Avatar
Dealer : Toyota of Muskogee
2003 Toyota Tacoma
My eBay ddnail's Photo Albums
Last Online: 08-27-2008 06:51 PM
ddnail is on a distinguished road.
Kewl, I never heard of that. Nice trick if your up the creek and have no other option.
AKA..dingdong
Silver 03 Taco Limited TRD 4dr. 4X4 V6 Auto
Extang Tonneau, LineX Liner, 3" Toytec lift with front diff drop, rear Alcan, AAL's w/ degree shims, Procomp shocks front and rear, Locker mod, 285/75/16 Nitto's, Code alarm/remote start CA670, Putco Stainless Grill, Several CUSTOM off road pin stripes
Old 11-18-2007, 11:50 PM
Dealer : Toyota Of Runnemede
- Other -
CLAMSHELL's Photo Albums
Last Online: 01-30-2008 03:27 PM
CLAMSHELL is on a distinguished road.
Have you ever used your rear wheels like a winch? It works great with a flat strap.
Heres what you do, loop the strap around the tire of the truck that is not stuck, hook the other end to the truck that is stuck. Chain the unstuck truck to a tree or another truck. Jack up the *** end of the truck, put it in drive and gas it SLOWLY. The strap will wrap around the tire just like a winch and out comes the stuck truck.......WAALA I have done this trick twice be for I bought a winch, but hell it works....
Old 11-19-2007, 05:25 PM
Dealer : Toyota Scion of Winter Haven
2006 Toyota Tacoma
William1's Photo Albums
Last Online: 07-05-2008 09:39 AM
William1 is on a distinguished road.
I was just about to mention using a tire for a winch myself, until you mentioned it.
Seems like I have seen an old military vehicle with provision for winching with one wheel, either by connecting something to a wheel and wrapping a rope around it, or wrapping a rope around something already connected to a wheel.
The winch trick tends to work better on a wheel connected to a locker equipped vehicle. Without a locker, the winch trick could cause the wheel being used as a winch to not spin, while the other wheel spins.
'06 Tacoma TRD Doublecab 4wd
Rear locker mod, 3" Skyjacker lift struts, Skyjacker rear springs and shocks, more to come...
'06 Yamaha Wolverine 450 sport/4wd ATV
'03 Honda ST1300 Sport/touring motorcycle
Old 11-20-2007, 08:17 AM
GGWOODY's Avatar
Doctor JellyFinger
Dealer : Dick Dyer Toyota
GGWOODY's Photo Albums
Last Online: 09-04-2008 07:13 PM
GGWOODY will become famous soon enough.
That's really cool TH!
I'll definitely have to give this a try!
Glad you could contribute something!
"When you die, you might want to have a banana in your pocket"-Me
Old 11-22-2007, 03:40 PM
2004 Toyota Tundra,
It would be nice if you could do the same some day.
Old 11-22-2007, 03:43 PM
2004 Toyota Tundra,
I saw something interesting on TV one time, it was a show from the 70s. A guy had a truck, possibly a Jeep I don't recall exactly, with a spare rim. There was a no tire on the rim. He looped a rope around the rim where the tire should go, then used it as a winch.
If memory serves he was getting a person out of a hole or a well or something like that. I'm sure it could work to pull too.
Old 12-02-2007, 11:35 AM
ddnail's Avatar
2003 Toyota Tacoma
I've actually seen this done with a tractor before. My brother got a John Deere 4460 stuck behind a pond dam. It was bad enough that it stayed there for 3 weeks! We kept trying different things with no luck untill his neighbor brought him a dual wheel with no tire on it and about 100ft of cable. We bolted the dual wheel on the outside of the rear tire, ran the cable to an oak tree, and put the tractor in low gear with the rear diff locked in. The tractor "idled" itself out of the hole while my brother "floated" the front end with the bucket. Worked like a charm!
AKA..dingdong
