Go Back   Tundra Solutions Forum > General Forums > Off-Roading
Off-Roading Discussions specifically related to modifying and driving your Toyota truck/SUV off the pavement, including trip reports.
This is a discussion thread titled "Traction/Ladder Bars", within the Off-Roading forum, part of the General Forums category.
Old 07-03-2008, 06:55 PM
apimpdad's Avatar
2002 Toyota Tundra
My eBay apimpdad's Photo Albums
Last Online: Today 06:46 PM
apimpdad is on a distinguished road.
Send a message via AIM to apimpdad
Default Traction/Ladder Bars
OK, heres the deal.... as many of you know I do a lot of mudding and what not, few trails, tug o wars, blah blah blah you get the picture. I Know that the best traction bar for the rear consists of 2 mounting points on the axle that consist of heims(better) or poly bushings(not as good) and a shackle mounted in tension to the frame (such as the budbuilt unit). Well I dont have enough room to mount that kinda of traction bar underneath my truck, so I thought about doing the simple and very popular alternative, which is 2 bars mounted at one point kinda below the axle and a solid (no shackle) mount to the frame, with poly bushings at each end.
What do you guys think about all this?
2002 Tundra-SAS-Dana 50-Sterling 10.5-Inchworm 2.28 Dual Transfer Case-4.56 Gears-38.5 Thornbirds-ASP Underdrive Pulley-Flowmaster Muffler
Build Thread-
SAS on 02 Tundra
Old 07-03-2008, 07:05 PM
Imdone's Avatar
2004 Toyota 4Runner,
My eBay Imdone's Photo Albums
Last Online: Today 04:40 PM
Imdone is on a distinguished road.
Default Re: Traction/Ladder Bars
If you don't have enough space for the Bud-built then look into RCD trac-bars. They have some really nice ones. I bought a set for my 00 but never installed them, they were out of the box and the quality was just like the RCD lift kit, no complaints.
You may need a specific size/length for your truck though because of all you have done. I have seen a few running around in AZ with what looks like an adjustable trac bar, you may want to look into something like this, it will adjust for length similar to the way a tie-rod end is connected to a steering rack.
Work in progress...
Old 07-03-2008, 07:20 PM
apimpdad's Avatar
2002 Toyota Tundra
That is what I don't know about, the size/length/ whatever... I found these though... Chucks Trucks Forum :: View topic - pro comp ladder bars.
They are 64" from eye to eye, and were made for a super duty, but this guy used them on a 85 f-250 with a dana 70 rear. And they are only $175, if he doesn't sell them...
Build Thread-
SAS on 02 Tundra
Old 07-04-2008, 04:33 PM
Imdone's Avatar
I think the RCD ones I had were about that same length, I never measured eyelet to eyelet but they were damn long, I know that. Those might work, it's just that pro-comp sucks something fierce and I wouldn't buy anything that had the pro-comp name on it.
However, that is really cheap for a set of traction bars. I know my RCDs were two to three times that amount.
Work in progress...
Old 07-05-2008, 05:13 PM
apimpdad's Avatar
2002 Toyota Tundra
I'm not a big fan of pro comp either, even though i have their shocks and steering stabilizer..... but if I did happen to get these, I would take the Pro Comp Stamped piece of metal off.
Build Thread-
SAS on 02 Tundra
Old 07-06-2008, 10:44 AM
Imdone's Avatar
Also get a decent powder coating job done on them and you might have an OK set of trac-bars there!!!
Work in progress...
Old 07-06-2008, 02:37 PM
apimpdad's Avatar
2002 Toyota Tundra
Too late now, they have been sold. So now I am back to square one and wandering if a single bar setup (some thik DOM tube) would hold up to the abuse?
Build Thread-
SAS on 02 Tundra
Old 07-06-2008, 08:09 PM
Imdone's Avatar
thick wall 1.25" should easily hold up to what yo can throw at it.
Especially DOM tubing, that is probably overkill for what you are going to do.
Work in progress...
Old 07-06-2008, 09:17 PM
apimpdad's Avatar
2002 Toyota Tundra
Yea thats what a lot of trucks run around here, and I dont think they have much problems with them. The only thing is that 12 feet of that stuff is like $160+
Build Thread-
SAS on 02 Tundra
Old 07-07-2008, 02:38 PM
apimpdad's Avatar
2002 Toyota Tundra
Took a video today to see how bad the axle wrap actually was, and it doesn't look too bad, until I put it in double low at 1:30 into the video.
[/url]
Build Thread-
SAS on 02 Tundra
Old 07-08-2008, 09:36 AM
Dealer : Mark Miller Toyota
2007 Toyota Tacoma
Corban_White's Photo Albums
Last Online: Yesterday 10:04 AM
Corban_White is on a distinguished road.
You may have already seen this but here is a good site with info on all the different types of traction bars: Axle Wrap Prevention
Old 07-08-2008, 01:10 PM
apimpdad's Avatar
2002 Toyota Tundra
yes, I have looked at this many times before, but thanks for the link anyway!
Build Thread-
SAS on 02 Tundra
Old 07-09-2008, 11:01 PM
Imdone's Avatar
That's a lot cheaper than a $500.00 set of traction bars though
Work in progress...
Old 07-11-2008, 03:51 PM
apimpdad's Avatar
2002 Toyota Tundra
yes, thats true. But for now, this project will be put on the back burner, as a set of 4" springs and new pitman arm are more important right now.
Build Thread-
SAS on 02 Tundra
Old 07-15-2008, 11:55 PM
Imdone's Avatar
GAWD! Prioritizing SUCKS!!!
Work in progress...
