Go Back   Toyota Tundra Forums : Tundra Solutions Forum > General Forums > Off-Roading
Old 01-22-2009, 02:34 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 02:56 PM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Question fix a tire off the bead in seconds on the trail
You guys seen this before?
http://www.cartoonland.de/archiv/reifen-aufpumpen/
Is that for real?
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 01-22-2009, 02:46 PM
Random Poster
Dealer : New Country Toyota
2004 Toyota Tundra
Last Online: 10-22-2009 07:34 PM
Jodan is on a distinguished road.
Jodan's Photo Albums
Default Re: fix a tire off the bead in seconds on the trail
I've seen it done on shows before, I know its a method for when you have no choice to get to a tire shop .
Heres anouther
Top Gear - How To Fix a Tire On the North Pole • VideoSift: Online Video *Quality Control
Old 01-22-2009, 02:50 PM
d-lo's Avatar
Dealer : Champion Toyota Scion of Austin
Last Online: Today 11:49 AM
d-lo is on a distinguished road.
d-lo's Photo Albums
pretty clever... but it looks like the tire deflated back off the rim at the end of the 1st video.
2008 Tundra Crew Max Limited 4x4 5.7L
Sunroof
20" Wheels
Skid Plate Enhancement
XM
Anodized Aluminum 'T' Shifter
Stebel Nautilus 110dB Compact Air Horn
Air Lift LoadLifter 5000 Air Springs
Pulling:
2007 Fleetwood Evolution E3
Tekonsha P3 Brake Controller
a
Old 01-22-2009, 04:19 PM
RIjon's Avatar
The emblem & panel guy
Dealer : Valenti Toyota
Last Online: Today 06:34 PM
Images: 25
RIjon will become famous soon enough.
RIjon's Photo Albums
We used to do that in the military all the time in the field.
2008 Tundra 5.7L RCSB
Custom Switch panels and Emblems for your tundra. PM for details
READ IT, LEARN IT, STAND FOR IT
http://www.usconstitution.net
Si vis pacem, para bellum
Old 01-22-2009, 05:23 PM
Rodge's Avatar
2006 Toyota Tacoma
Last Online: 04-17-2009 04:33 PM
Rodge is on a distinguished road.
Rodge's Photo Albums
I'd only do that if the wheel/tire were laying flat on the ground. And the people who did this waited too long to fill it up with air. You have to be real quick about it.
When I or anyone else blows a bead we usually jack the truck up, pull the valve stem and have several sets of hands holding pressure on the bead until the pressure inside the tire is enough to reseat it. When that doesn't work, we'll throw a ratchet strap around the circumference of the tire and crank down on it, then fill it with air.
2006 DC Tacoma
Mods: It gets me places.
1985 Pickup - Regular Cab
Mods: 22R/108:1/Spooled Rear-Open Front/36" Iroks/Internal Jungle Gym
Old 01-22-2009, 05:58 PM
dsrtrcr01's Avatar
2005 Toyota Tundra Doublecab TRD 2wd,
2001 Toyota Celica 17" Rims, TRD Bumper,
1995 Toyota Truck Pre Runner
Last Online: Today 06:08 PM
Images: 11
dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence.
dsrtrcr01's Photo Albums
I have done it MANY MANY times. I usually pull the valve core because once the fire is out it starts to suck back in and if the valve is in it will pop it right back off the bead. Be careful how much gas/Carb spray/Flamable stuff you use. We blew a 35 inch tire off both sides of a 15 inch wheel by using a little to much. I will also suggest you do not put your finger over the valve stem when it starts sucking back in as well. I had a burnt circle on my fingertip for a while. If you get it to pop on the bead and blast it with air to keep it filled up it is best. FYIU if the gas does not go in the wheel but stays on the outside when you do this the tire will set on fire.
DO NOT TRY THIS AT HOME
'05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
Old 01-22-2009, 07:15 PM
tinik's Avatar
Travel & camping is 2 much fun
Dealer : Cramer Toyota Scion of Venice
2006 Toyota Sequoia,
2001 Toyota Tundra Supercharged
Images: 51
tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One.
tinik's Photo Albums
My friend does this all the time, he is on call to repair semi trucks on a road. Good advise!
2006 Toyota Sequoia Limited 4x4 w/ lxr package, 7008 navi, rear entartaiment system, 20" x-sp enkei.
2001 Toyota Tundra SR5 4x4 - TRD 9+Psi Supercharged, JBA Ceramic Headers, Walboro 255LPH Fuel Pump, 1UZ Rods, 20" x-sp enkei wheels, 7009 navi w/custom JBL wire harness + OEM XM/Sirus radio, drive by wire, and many other mods.
Old 01-23-2009, 09:42 AM
jjc's Avatar
jjc jjc is offline
Dealer : Beaman Toyota Co.
2008 Toyota Tundra SR5 4x4 TRD,
2001 Toyota Tundra SR5 4x4 TRD
Last Online: 11-20-2009 08:27 AM
Images: 231
jjc will become famous soon enough. jjc will become famous soon enough.
jjc's Photo Albums
I've done it several times on a backhoe tire - helps to put a large ratchet strap around the tire and tighten it down as tight as possible, then spray starting fluid in the tire and light. Once it pops on the rim, you have to hit it with a lot of air in a hurry, my CO2 tank works really good for this. With a ratchet strap and CO2 bottle you can sometimes even seat a tire without the starter fluid.
2001 TRD 4x4 with a lift kit & a bone stock 2008 TRD 4x4
My Junk - http://community.webshots.com/user/0...host=community
Old 01-23-2009, 02:58 PM
Dealer : Mark Miller Toyota
2007 Toyota Tacoma
Last Online: 11-21-2009 08:39 PM
Corban_White is on a distinguished road.
Corban_White's Photo Albums
I used to work in a semi truck repair shop and that is how we did all the tires till we got one of these:
Yes, that is a 2 inch ball valve on the outlet. 185 psi thru 2 inches will seat any tire.
Old 01-25-2009, 12:30 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Images: 22
I thought you meant all the way off the bead...in that case a set of tire irons is your best friend, but anyway a CO2 bottle and a ratchet strap is what we've used around here, messing around.
It'd work better to pull the core before using the bottle, but then you gotta get the right sort of chuck to make it work. None of the guys here have had a problem with the core in, tho.
GFX by FreedomEagle50
Manual Hubs
Old 01-27-2009, 02:59 AM
Quentin18's Avatar
2003 Toyota Tundra
Last Online: 11-15-2009 02:22 PM
Images: 2
Quentin18 is on a distinguished road.
Quentin18's Photo Albums
hahaha i saw a vid of that once on u tube.
so when i had auto shop in highschool. i had an assignment to put a tire on the rim and inflate it. well my friends and i being lazy and not want to wait our turn to use the machine; we managed to jam the rim on the inside of the tire. and then we went and got some parts cleaner spray, and a match. sprayed the parts cleaner on the inside of the tires and dropped a lit match on the tire. well i think we mighta used 2 much parts cleaner cuz the tire popped like a baloon and the rim zung a 6 inches and smashed my buddys foot and broke his pinky toe. needless to say we coulnt go in the shop for a few classes and had to learn from a gay book for a while.
in my opion it was well worth it. and yes i know we got lucky, trust me every person that thought they had authority over us told us that. multiple time. and my mom. and grandma. even my neighbor.
Tundra with a little lift and 33's
Old 01-28-2009, 01:03 PM
dsrtrcr01's Avatar
Images: 11
Man Schools sure have changed. Making you read from a Gay book just for popping a tire on. That seems extreme to me. I wonder if Token got in a lot of trouble in school??
