Go Back   Toyota Tundra Forums : Tundra Solutions Forum > General Forums > Off-Roading
Old 03-11-2009, 10:57 PM
SmokeySevin's Avatar
Dealer : Star Toyota
Last Online: Yesterday 11:12 PM
SmokeySevin is on a distinguished road.
SmokeySevin's Photo Albums
Default Smokeysevin's 4Wheel drive conversion buildup thread.
Alright everyone I went to the beach today with some friends and was very luckey to make it out with my truck still dry, I was returning my jetski to the trailer and my truck got stuck. well the tide was coming in and it got up to nearly the trim on the door before I was rescued. Needless to say I'm a little freaked out right now so to prevent this from ever happening again I'm going to do some sort of 4 wheel drive swap weather it be solid axle or factory toyota. either way I'll be runnign 33s for probably 2 years and then 35s
SAS
should I do the solid axle swap i would be going 9 inch rear 44 front with a divorse mount transfer case dana 300 or 205. I'm thinking I will just buy a bronco or blazer with the solid front axle and strip it.
IFS
If I go the IFS route it will be less custom fab but I need to swap the tranny which is not what I really want to deal with.
Comments, thoughts, ideas, suggestions, anything will be help.
Sean
2001 Tundra 4.7L i-Force V8
True Flow filter, Cherry Bomb Glasspack, URD MAF calibrator, Magnaflow cats, Jet Accuspeed, NGK Iridium plugs, Royal Purple Lube, ASP Underdrive pulley, SSAUTOCHROME headers and Y Pipe, GM 12 Bolt Rear Axle, Yukon gear 4.56's and Heat Treated axles, Rear Disc Brake swap, Moser Bearing Support Diff cover and 1310 Yoke, Mark Williams Enterprises Bearing cap, Camburg UCA, Bilstein 5100 front shocks, Pro CompMX-6 12 InCh TrAvEl Rear Reservoir Shocks, Daystar AAL, Mb Blintz 16 inch wheels, 285-75-16 front 305-70-16 rear NITTO DUNE GRAPPLERS, 2006 Big Brake Upgrade, Debadged, Custom black grille and emblem, PIAA Lights, Red Hoses, Infinity Speakers, Sony XPLOD head unit w/ Bluetooth, 2 KICKER S8L5 subs powered by 800W Xplod Amp
15.56 in the 1/4 before Axle number 3, 305's, MAF calibrator, and cats
0-60 6.2 seconds
Old 03-12-2009, 10:57 AM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Images: 22
Default Re: Smokeysevin's 4Wheel drive conversion buildup thread.
Originally Posted by SmokeySevin View Post
SAS
Read jjc's and apimpdad's build threads and decide if you really wanna go that route. Personally, I wouldn't do the D44 front or the dv-mount case. You're gonna sink a bunch of money in to this route, in part because it's not something you can do yourself yet.
IFS
Time consuming but not difficult to swap for stock IFS, if that's what you want.
Some choices you gotta make...
T-case:
Electronic or simple transfer case?
4WD or AWD?
Driveline disconnects?
IFS:
Manual or ADD hubs?
Stock or extended front suspension travel?
SAS:
Width?
Center?
Knuckles?
Housing?
Suspension?
Rear axle?
General:
Gear ratio?
Lockers?
You could also just make the switch to 35"x12.5" tires now, and air down more...12# and all-terrains should get you around on the beach just fine.
GFX by FreedomEagle50
Manual Hubs
Old 03-12-2009, 04:54 PM
T-case:
I'm thinking something either stock toyota or dana 300 or np205 or np241
IFS:
Manual hubs
suspension with my bilstein 5100s and camburg uppers
SAS:
Width stock or just a little wider
Center I'm not sure what you mean by that
Knuckles stock or d60
Housing dana 44 or ford 9
Suspension leaf spring
Rear axle ford 9 or 10.25
General:
Gear ratio 4.56
Lockers arb or lsd for rear lsd for front
0-60 6.2 seconds
Old 03-14-2009, 12:09 PM
editmars's Avatar
Dealer : Toyota of Santa Cruz
Last Online: 05-06-2009 02:25 AM
editmars is on a distinguished road.
editmars's Photo Albums
Correct me if I'm wrong but SASing a 2wd requires more than just putting a straight axle under the truck (besides fabwork etc) Does the computer or tranny have to be touched?
Also, didnt you say you had to be able to fit under your parking garage?
