Go Back   Toyota Tundra Forums : Tundra Solutions Forum > General Forums > Off-Roading
Old 06-03-2009, 01:37 PM
T23's Avatar
T23 T23 is offline
Dealer : Nye Frontier Toyota/Scion
Last Online: 10-16-2009 01:18 PM
T23 is on a distinguished road.
T23's Photo Albums
Default Hi-Lift Jack Set Up & Usage
I have a 2001 Tundra Access Cab.
Buying a Hi-Lift Jack.
1) What size do I need?
2) What accessories do I NEED?
3) What accessories are nice to have?
4) Where are the best "usage" points on the truck?
Old 06-04-2009, 12:43 AM
rambrush's Avatar
Ever the explorer
Dealer : Findlay Toyota Scion
2006 Toyota Tundra,
2003 Toyota Avalon
Last Online: Today 08:43 AM
Images: 83
rambrush will become famous soon enough. rambrush will become famous soon enough.
Send a message via AIM to rambrush rambrush's Photo Albums
Default Re: Hi-Lift Jack Set Up & Usage
I would suggest the tallest one, cast iron. Mine is around 29 years old and still going strong. (Hard for me to believe I have been wheeling that many years).
Then a good base for it. they now make accessories that you can hook onto curved bumpers plus jacking up on your wheels which is a nice feature. my other trucks I welded channel iron on each corner under the bumpers that the jack would fit into. this prevented the jack from doing the famous slip out. But with those in place I could and did jack the rig up and push it over onto terra ferma instead of muck.
some will say that you don't need one and it takes up valuable space. but its good to know you have a versatle tool when you need it. Last year my pole barn in Montana could not handle the snow load and broke the end supports. had to drill a hole in the beam bolted the hi lift to it and then jacked the puppy up enough to slide in a new post. raising a log off the ground to prevent my saw from cutting dirt. so yes it has many other uses.
ARB Sahara,Front Springs www.coilsprings.com Firestone Ride-rites 2245, Hell roaring technology dual battery setup, Wrangler dual battery tray, (2) Odyssey PC1200T batteries, Tru-speed recalibrator, Toyo open country MT 265x75x16's, USA Spec PA-15,AmSteel 7/16 x 90' synthetic winch line, 100' AmSteel 7/16 extension rope, Fumoto quick drain #F103N.
Future Ideas
Winch Warn 16.5ti coming soon..
Sliders Stubbs
Lockers ARB
Viar 460c w twin 2.5 gal tanks
255 x 85 x 16's
4:56 gears
Skid row skid plate package
Old 06-04-2009, 11:32 AM
T23's Avatar
T23 T23 is offline
T23's Photo Albums
I saw a 60" one at AIH (local store) the other day. I guess that is the tallest I can find. I'll go for that and scour the net for deals on the various accesories. In Alaska the importance of being self reliant and able to get your own self "out" is emphasized all the more!
Old 06-04-2009, 02:29 PM
Herbicidal's Avatar
Just a Herbicidal maniac.
2001 Toyota Tundra,
2008 Toyota Yaris Sedan 'S' Flint Mica,
2009 Toyota Corolla 'S' Barcelona Red
Last Online: Today 11:31 AM
Images: 150
Herbicidal's Photo Albums
I would recommend Hi-Lift's off-road kit (Hi-Lift Accessories). It's pretty darn complete. I have the off-road base. If you get that, drill two holes and add a loop of rope through it. It's easier to get it out of the muck if you bury it.
Additional items (see link above):
Handle keeper to keep the handle from banging all over the place.
Mounting brackets. Either the 'tube mount' or 4xRAC. Depends upon how you mount it. Mines in my bed over the passenger side wheel well (pic in my album).
Lift-mate and/or bumper lift.
Useage:
Kick the base in towards the vehicle a little bit. As the jack raises the vehicle, it will straighten up.
Never wrap your thump around the main vertical bar as the handle could smack it.
Never get your face in the way of the handle. Same as above.
Chock and block your wheels before lifting.
Never work under your vehicle with just the Hi-lift supporting it.
I suppose there are hundreds of other 'never's'.
Do - use common sense.
Do - practice using it.
Do - use WD-40 to lube the working parts. Check monthly.
Don't use white lithium grease as it attacks dirt, sand, etc.
Do - respect the tool.
Be safe!
