Originally Posted by 1of1
2) Limited Slip - also known as a "posi"
3) Locker - Lockright, Detroit, etc. Open normally, but if one wheel loses traction, it locks both together.
I would say you should order this LSD TRD LSD Kazuma Limited Slip Differential and expect to pay a few hundred to get it installed.
First off, just to clarify for the sake of avoiding a common misconception about limited slip differentials, the term "posi" is a slang term derived from the brand name Positraction, which was a clutch type limited slip used in GM vehicles. Not every limited slip is Positraction. There are other brands, such as the Ford Traction Lock, Dana Trac Loc, etc.
I prefer not to use the term "posi" to refer to all limited slip differentials, especially since not all are the same type as the original Positraction. There are the geardriven types (Gleason Torsen, Detroit Truetrac, Quaife). Then there is at least one different type of clutch type limited slips, such as those that use cone type clutches (Auburn) instead of multiplate clutches like Positraction uses. Then there is at least one wheel speed sensitive type used in Chevy and GMC trucks. It is a clutch ype limited slip that has internal fly weights that use centrufugal force to lock the clutches, and is commonly referred to as the GovLoc, since it was originally made for military use.
I've known of people over the years that would say things about a Ford, Dodge, etc. having a factory installed Positraction or "posi" when they actually didn't. They had Traction Lock or Sure Grip (or whatever they call it).
I've even had a guy tell me about a guy with a Ford, saying it had factory installed Positraction, and he is convinced that Positraction is a locker. Nothing I said would convince him that it was neither factory Positraction nor a factory locker, or that Positraction is a brand of limited slip and not a locker.
I remember growing up thinking a vehicle equipped with a "posi" was capable of doing amazing feats, by going anywhere. That seemed to be a general misconception. Now that I am older, I know better.
So that's the reasons I avoid using "posi" as a slang term. It helps to avoid confusion and misconceptions.
It's only been within the past 3 or 4 years that the Eaton Corporation has made Positraction as an aftermarket differential for other than GM vehicles, since they now own the trademark.
Another thing: The automatic lockers you listed, such as the Detroit, Lock Right, etc., are NOT open until they automatically lock. Open differentiation means that one wheel rotates faster than the ring gear, while the other rotates slower than the ring gear. And assuming the tire diameters are exactly the same, the
difference in speed between each tire and the ring gear are exactly the same.
Here is how automatic lockers differentiate: The locker is in 2 halves. One half connects the carrier to the wheel on one side, the other half connects the carrier to the wheel on the other side. In a turn, the locker half connected to the INSIDE wheel remains locked, while the locker half connected to the outside wheel disengages and ratchets or separates, allowing a difference in wheel speed.
So what is happening during a turn or curve is that the INSIDE wheel is rotating the same speed as the ring gear, while the OUTSIDE wheel is rotating faster than the ring gear.
This is why automatic lockers affect handling like they do when used in a rear axle. If you apply throttle, the INSIDE wheel will try to push the vehicle to the OUTSIDE of the turn. If you lift the throttle, the INSIDE wheel will try to pull the vehicle to the INSIDE of the turn.
And if you apply enough throttle while in a turn or curve, the inside wheel will lose taction and spin faster until it catches up with the speed of the outside wheel.
So in order to corner normally, you have to maintain just enough throttle to maintain your speed, or in the case of a manual transmission, you can push in the clutch and coast.
It sounds like the limited slip you supplied the link to is a good deal as far as limited slips are concerned. If I understand correctly, it's an Eaton Positraction made for Toyota, and it is modified with stronger springs that give more preload for the clutches. This helps give better clutch lockup, although the clutch discs will wear faster. But it shouldn't be too hard for you to learn how to replace the clutches.
If you don't plan on doing any kind of off roading where a locker is needed, that may be your best bet.
