Go Back   Toyota Tundra Forums : Tundra Solutions Forum > General Forums > Off-Roading
  #106 (permalink)
Old 10-15-2007, 03:08 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Today 02:02 PM
Images: 22
Default Re: SAS on 02 tundra
Cool cool...I think a bunch of us are waiting to see the rebuild .
Why lift the rear back up? can you drop the front at all, to match? 35"-36" should fit on your setup, plus there are some great narrow 35s around. Since it sounds like you do mud, what about a wide 35" from Pit Bull or somewhere for playing and a set of whatevers for the street?
GFX by FreedomEagle50
Manual Hubs
  #107 (permalink)
Old 10-15-2007, 03:28 PM
apimpdad's Avatar
2002 Toyota Tundra
Last Online: Today 04:45 PM
Images: 57
apimpdad is a splendid one to behold. apimpdad is a splendid one to behold.
Send a message via AIM to apimpdad apimpdad's Photo Albums My eBay
no rebuild for me, i have since moved on from that
im not going to bother lowering the front, becuase then i will have issues with the front d-shaft hitting the trans crossmember and steering problems and some other stuff. it would be so much easier to just throw in a 1" block and call it a day. i dont really want to go to a smaller tire, just one that is better on road. i might not even lift the rear end back up, i may just keep it sittin how it is. i really want and need some lockers
SAS Tundra
Build Thread-
SAS on 02 Tundra
  #108 (permalink)
Old 11-22-2007, 12:08 AM
apimpdad's Avatar
2002 Toyota Tundra
Images: 57
well i have been having some bad sounds coming from under the truck, and i originally thought it was the np205. but after listening closely, i realized that it was coming from the front end, so then i assumed that the expensive @$$ unit bearings were going out. well come to find out, it was my stupid track bar. this thing has been causing so many problems. the mount on the axle was cracked almost all the way around, so i took the track bar off and no more sound. im still working on getting a marlin crawler dual case installed and maybe a late tacoma manual t-case. but first, warn hubs will be here soon.
SAS Tundra
Build Thread-
SAS on 02 Tundra
  #109 (permalink)
Old 12-05-2007, 01:10 PM
apimpdad's Avatar
2002 Toyota Tundra
Images: 57
well the warn hubs are here but they wont be installed for another couple of weeks, marlin crawler cant answer their phones or reply back to my e-mails, so i e-mailed Jim at inchworm. I got a reply back yesterday saying that he has what i want in stock and can have it shipped out in just a few days. not to mention, their crawl boxes are on sale!!!
SAS Tundra
Build Thread-
SAS on 02 Tundra
  #110 (permalink)
Old 12-05-2007, 04:08 PM
Images: 22
You're gonna have an excellent truck when you're done . Ever get around to trimming the wheel wells, so you can drop the front?
A tip on the Warn hubs...take them apart and grease everything. If yours are like mine, there are no bearings, just a bronze self-lubricating bushing with a bit of play to it. I used Green Grease, particularly for where you wheel I'd highly recommend the same . Give everything a thin coating, moisture can get in there if the seals are compromised and rust the splines in the locking mechanism, and parts of the rotating assembly. They don't come coated, black CV grease is good but the green stuff is far better.
Once the cap is off and the inner accordion spring out, there will probably be a small wire clip holding the locking slug in...push slug down, remove wire clip, remove slug.
On the back, there's a circlip holding the rotating assembly in the bushing. It comes out through the front of the hub body.
Oh yeah...I know you were talking MTs but have you looked at the SX?
-Sean
Manual Hubs
  #111 (permalink)
Old 12-05-2007, 04:53 PM
apimpdad's Avatar
2002 Toyota Tundra
Images: 57
-Sean
thanks for the tip about greasing the warn hubs, i will do that! and i guess you are talkin about the super swamper SX? no, i have never looked at them, im trying to avoid anything with the super swamper name right now..
SAS Tundra
Build Thread-
SAS on 02 Tundra
  #112 (permalink)
Old 12-08-2007, 11:03 PM
Herbicidal's Avatar
Just a Herbicidal maniac.
2001 Toyota Tundra,
2008 Toyota Yaris Sedan 'S' Flint Mica,
2009 Toyota Corolla 'S' Barcelona Red
Last Online: Today 11:17 AM
Images: 150
Herbicidal's Photo Albums
Excellent! Jim's a great guy! I'm fortunate that his shop is only about an hour from my house. His guys initially set up my 4.88 gears and most recently did my rear ARB locker. I wish I could do a dual transfer case in my truck, but it's just not in the cards.
Good luck with your next phase.
  #113 (permalink)
Old 12-20-2007, 05:04 PM
apimpdad's Avatar
2002 Toyota Tundra
Images: 57
Update: Just got off the phone with Inchworm and the crawl box is ordered! they will be closed until the 2nd of January so it wont be shipped out until then. but i will do the install on this thread so stay tuned!
SAS Tundra
Build Thread-
SAS on 02 Tundra
  #114 (permalink)
Old 12-20-2007, 06:27 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
How's the motor after breathing in some muddy H2O???
Mike
http://dyogim.blogspot.com
  #115 (permalink)
Old 12-20-2007, 06:38 PM
apimpdad's Avatar
2002 Toyota Tundra
Images: 57
if you are talking about the atv, its running just like it was before! only problem now is a flat tire and a bent rim on the front of it
SAS Tundra
Build Thread-
SAS on 02 Tundra
  #116 (permalink)
Old 12-20-2007, 06:50 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
I thought it was the truck... oops!
Mike
  #117 (permalink)
Old 12-20-2007, 07:09 PM
apimpdad's Avatar
2002 Toyota Tundra
Images: 57
haha i thought to myself as i read your last post that you might be thinkin it was the truck, but no. i try to avoid deep water with the truck, because water hides pleasant surprises.
SAS Tundra
Build Thread-
SAS on 02 Tundra
  #118 (permalink)
Old 12-21-2007, 07:35 PM
apimpdad's Avatar
2002 Toyota Tundra
Images: 57
I forgot to add this forever ago, but i finally welded in a front crossmember, complete with Advance Auto Parts Tow Hooks! i still need to do some reinforcing with a few gussets and what not, so that will probably happen when or if i remove the body lift with the bumper will be off. but they have been used, and yes they held up great! so great that a 3" 30,000 pound strap snapped when i was hooked up to a F-250 on 44's! here are a couple of pics from the build/install.
SAS Tundra
Build Thread-
SAS on 02 Tundra
  #119 (permalink)
Old 12-22-2007, 04:06 PM
apimpdad's Avatar
2002 Toyota Tundra
Images: 57
here are a few other pics from the front crossmember that i built.
SAS Tundra
Build Thread-
SAS on 02 Tundra
  #120 (permalink)
Old 12-24-2007, 11:47 AM
apimpdad's Avatar
2002 Toyota Tundra
Images: 57
so the other night at about 1 a.m. i was stranded because my truck wouldn't start, and i was hoping that it wasn't the starter. it ended up being the terminals that connect to the battery. somehow they just went bad, and besides, the stock ones are thin and wimpy, so i went to advance auto parts and picked up some bigger and better ones.
Before:
After:
SAS Tundra
Build Thread-
SAS on 02 Tundra
7000 mile trip with 3000 mile towing with Tundra and Outback BaseCamp Towing 20 02-25-2008 08:55 PM
Do you think the 2007 Tundra will sell? Proposed truck idea My03Tundra Polls 75 07-17-2007 12:50 PM
Tundra Vs. Tacoma towing joewildlife Tacoma 11 11-13-2006 03:35 PM
Tundra vs. Tacoma and towing joewildlife 1Gen-Tundra 18 11-11-2006 12:21 AM
Toyota Unveils Long Bed Versions Of All-New 2007 Tundra Full-Size Pickup Truck TundraSoul Toyota, Scion & Lexus News 0 09-18-2006 01:42 PM
