Go Back   Tundra Solutions Forum > General Forums > Off-Roading
Old 01-08-2007, 10:12 AM
apimpdad's Avatar
2002 Toyota Tundra
Last Online: Today 07:36 PM
Images: 54
apimpdad is a splendid one to behold. apimpdad is a splendid one to behold.
Send a message via AIM to apimpdad apimpdad's Photo Albums My eBay
Default Apimpdad's 02 Tundra Buildup Thread
i just purchased both front and rear axles off of a 2001 f250, and soon i am having it straight axled on 38s. can anyone tell me how much it cost them to do the same thing on their truck, and any more info that i need to know. thanks
Old 01-08-2007, 10:15 AM
Jetes03tundra's Avatar
2003 Toyota Tundra 4.7 with duals
Last Online: 09-05-2009 11:06 AM
Jetes03tundra is on a distinguished road.
Send a message via AIM to Jetes03tundra Jetes03tundra's Photo Albums
Default Re: SAS on 02 tundra
check out www.teddnet.com where all the SAS tundra guys have posted alot of their info and help
2006 silverado with full bolt on's and its fast
Old 01-08-2007, 12:50 PM
apimpdad's Avatar
2002 Toyota Tundra
Images: 54
i have been to this website many times before, but is there anyone else that know how much this costs???
Old 01-08-2007, 02:09 PM
Send a PM to Dyogim, Joe, JJC, flyin6 as well as TMS2U and ask them as they are the ones on here that have been through the process.
Old 01-08-2007, 05:12 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
It can range from $5K to $15K. Depends on the set-up, what parts you use and how much of the work you do yourself. Leaf spring set-up, is cheaper, coil over will be a lot more $$$.
Best thing to do would be to get a parts list together with the best prices you can find. Next determine what you do yourself and what a shop will need to do and get their prices. You'll also need to add the cost of all the nuts, bolts, washers, lock washers needed (grade 8 stuff) and include all the fluids.
I'm assuming you are using a D60 for the front, are you planning on changing the inner C's to kingpin (stronger) or staying with ball joints?
Another big question is how much are you willing to spend?
Mike
http://dyogim.blogspot.com
Old 01-09-2007, 09:22 AM
apimpdad's Avatar
2002 Toyota Tundra
Images: 54
i am doing a leaf spring setup, i dont need anything too serious because this truck will be mostly a road warrior. only weekend trips to the mud or trails will be the only thing that it will see.
Old 01-09-2007, 12:55 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 05:41 PM
Images: 22
Go to pirate4x4.com and LURK. DO NOT ask these questions there, lurk and search...use google, or if you're really serious about it, spend 20 bucks so you can easily search. If you ask there and mention "road warrior" they will toss you out in a hurry.
Just a guess, but a 2001 F250, isn't that a d44/9"?
Tedd had a parts list with prices, I think...
GFX by FreedomEagle50
Manual Hubs
Old 01-09-2007, 01:01 PM
TMS2U's Avatar
Moderator
Dealer : Longo Toyota
Last Online: 10-01-2009 03:29 PM
TMS2U is on a distinguished road.
TMS2U's Photo Albums
http://www.teddnet.com/sasparts.htm
an approximation as several additional items were not included, but a good starting point
Good luck and if you want to be included on my site let me know!
Old 01-10-2007, 09:33 AM
apimpdad's Avatar
2002 Toyota Tundra
Images: 54
id love to be on your website. but it will be a month or two so ill get back to you on that one. another question, should 4.56 gears be good fo 38s and i dont plan on cuttin the axles down at all, i think the wms on the new axles is about 74 inches. do you think the wider stance will look good???
Old 01-10-2007, 11:41 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
Go with 4.88's at least. 74" that's one wide mofo. You'll probably want to go with wheels with a lot of backspacing or cut them down.
In any case, I'm thinking of building a Dana 60 this year.
Mike
Old 01-10-2007, 01:05 PM
Images: 22
4.88 should feel like stock with 37s. consider 5.13 or something...and before anyone sez thats a weak ratio, there are a lot of factors that contribute to gear strength. look at getting a complete third member from truehi9.com, mike qualley is a great guy and just redesigned the 5.13 gearsets for equivalent strength to the other ratios. even the 5.13 is pirate-proof now, and it'll give you a little extra kick to get the wheels turning.
there is no way your axles are 74" wms. they're probably 69f/67r, or 69/69, or 67/66, unless they were modified and extended. the widest production "normal" axle is at 69.5", my custom rear is coming at 72" wms and i'll be running a lot of backspacing...like 5-6".
also, once you put a wide tire on there, you're pushing 90" from outside to outside of the tire...you'll about need a shoehorn around town and on the trail. if you run a standard hummer rim, you can get a ton of backspacing but might have trouble finding steering arms for a d44 (cuz i bet its a d44) that will work with 7" backspacing. i know theyre available for d60 knuckles, it might be worth a swap to dedenbears like jjc's front setup if you decide you need the track width narrower.
yeah...i've been doing a lot of web wheeling lately...i'm doing what youre doing and it's all going in autocad first for a reality check since i'm also dovetailing the rear about 10" on a side, and i gotta give a nod to street legality regarding how far out the tires sit beyond the glass. at 74" with a tire ~14" wide, you'll be something like 3-4" beyond the trd flares, consider glass to cover them instead, also you wont be able to stuff a 38 in the stock wheel well anyway. largest that will fit is a 35.
for reference iirc tundra wms is 67" front/66" rear.
-sean
Manual Hubs
Old 01-10-2007, 09:28 PM
apimpdad's Avatar
2002 Toyota Tundra
Images: 54
that might not be how wide they are after all. thats what the guy told me that i bought them from. btw i hate fender flares im leavin the stock ones on there cause i like the look of the tires stickin out
Old 01-11-2007, 12:41 AM
snoman02's Avatar
Dealer : Gateway Toyota Edmonton
2002 Toyota Tundra
Last Online: 09-08-2007 02:09 PM
snoman02 is on a distinguished road.
snoman02's Photo Albums
So what front springs are being used:
Stock Chevy front, lifted chevy front, 52" chevy rears, 56" chevy rear etc.
Extreme ... Life's to Short Not Too Be
02' Tundra Limited Access Cab - 2.5" fabtech dirt logics, 3" body lift, 285/75R16's, Heated Seat
Old 01-11-2007, 09:29 AM
apimpdad's Avatar
2002 Toyota Tundra
Images: 54
im not really sure, but def. lifted chevy front i dont know exactly im not doin the lift myself im having someone local do it
Old 01-11-2007, 11:40 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
Tedd and I are using 4" chevy lift springs in the front. Tedd got his from BDS and I got mine from Rancho. My parts list is located in my Photo Gallery.
In the rear I'm still running stock leafs with an AAL, 1.25" lift block and shackles. I have a set of chevy 4x4 springs (aka 63" Chevies) sitting in my garage. new front mounts and spring perch need to be welded on.
Mike
7000 mile trip with 3000 mile towing with Tundra and Outback BaseCamp Towing 20 02-25-2008 08:55 PM
Do you think the 2007 Tundra will sell? Proposed truck idea My03Tundra Polls 75 07-17-2007 12:50 PM
Tundra Vs. Tacoma towing joewildlife Tacoma 11 11-13-2006 03:35 PM
Tundra vs. Tacoma and towing joewildlife 1Gen-Tundra 18 11-11-2006 12:21 AM
Toyota Unveils Long Bed Versions Of All-New 2007 Tundra Full-Size Pickup Truck TundraSoul Toyota, Scion & Lexus News 0 09-18-2006 01:42 PM
