Go Back   Toyota Tundra Forums : Tundra Solutions Forum > General Forums > Off-Topic
  #16 (permalink)
Old 09-11-2009, 06:11 PM
Rut's Avatar
Rut Rut is offline
Dealer : Team Toyota
Last Online: Today 12:35 AM
Rut has blessed us with their presence. Rut has blessed us with their presence. Rut has blessed us with their presence.
Rut's Photo Albums
Default Re: Can... will Toyota build something to compete with this?
My garage:
http://www.vhoist.com/ride/100527
  #17 (permalink)
Old 09-13-2009, 02:15 PM
arthur's Avatar
2001 Toyota RAV4 Black 2 wd 3 doors,
- Other - '71 pontiac firebird,
2007 Toyota Tundra pyrite mica crewmax.
Last Online: Yesterday 12:23 AM
Images: 30
arthur is the One. arthur is the One. arthur is the One. arthur is the One. arthur is the One. arthur is the One. arthur is the One. arthur is the One. arthur is the One. arthur is the One. arthur is the One.
arthur's Photo Albums
Is that Boyd Coddington in the pic. ??????
A lot of CID.
  #18 (permalink)
Old 11-02-2009, 09:24 PM
H2O_MAN's Avatar
Obama lies ~ the economy dies
Dealer : Heyward Allen Toyota Scion
2002 Toyota Tundra 4WD long bed V8 SR5
H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor.
H2O_MAN's Photo Albums
Exclamation Re: Can... will Toyota build something to compete with this?
I saw something interesting this afternoon...
An all black Raptor was being trailed closely by a silver short bed, 2 door Tundra.
It looked like they were about to have some fun on some country roads
Old T100 items for sale
Thunder Gray Metallic
2002 REGULAR CAB - LONG BED - 4WD - V8 - SR5
TRD / Kazuma LSD made by EATON
Bilstein HD shocks
Michelin 8 ply E series radials
JBA headers
Hellwig rear bar
Line-X over the rail
2005 tail lights
OEM Door Sill protectors
TRD Off-Road front coil springs
Color matched LEER Hi-Top cap
Wet Okole Sport Seat Covers
Tinted Windows
OEM Rubber Bed Mat
OEM All-Weather mats
OEM Towing Package with Remote Transmission Cooler
  #19 (permalink)
Old 11-03-2009, 02:41 PM
dsrtrcr01's Avatar
2005 Toyota Tundra Doublecab TRD 2wd,
2001 Toyota Celica 17" Rims, TRD Bumper,
1995 Toyota Truck Pre Runner
Last Online: Yesterday 04:02 PM
Images: 11
dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence.
dsrtrcr01's Photo Albums
Long Travel? The only thing "Better" about the raptor suspension is the Fox's. 11 inches in front and the same as a stock truck in the rear. All this Hype over 2 inches of increased front wheel travel and maybe $2k in shocks? My Long travel gave me 4-5 inches more travel not 2, which is what you get from a simple upper arm replacement not "Long Travel".
My 95 F150 had WAY more travel then that with stock I beams and the stock rear leafs. Then I added bent beams and a 4 inch coil and it had rediculous travel. They shouold have slapped some bent beams and fox coilovers with some 62's in the rear and THEN they would have had something to brag about. The front shocks don't even have a Resi.
I will stick with my reliable Toyota and then throw some $ at the suspension to have it correct rather then spend ALOT on a truck that needs long travel and better front shocks any ways. PLUS after all that you still have a Ford.
BUT this is coming from someone who goes to the desert ALOT and builds/beats and uses the truck for off road. I know the travel I have now is not enough and I plan on building my next truck with more.
BUT In my Opinion NOTHING beats Fox Shocks so at least they got the best shock maker on this project. As long as they are not a watered down version of the fox's like the bilstiens that come on our TRD's. Bilstein is a GREAT off road shock as well but not when they come on our Toyotas.
38k or 41k with the 6.2, OR a standard F150 for starting at 21k? OK take the standartd for $25k since I am sure it is more then 21 and then add the good stuff. $4190 for a J&D kit which gives 16 inches of front travel with better strength. Then add $440 for steering upgrades which I would recomend on either truck. $895 for a spring Under Deaver which gives 19 inches of rear travel. Then Shocks depends on what you want and how many you want to run.
Truck+Front(J&D)+Steer(J&D)+rear(Spring under Deaver)+Shocks (2 bypasses Rear)+shocks(2 bypasses Front)+Shocks(2 coilovers Front)+Coils(4 coils)+Bumps(4 2.5 bumpstops)=Total
25,000+4,200+440+900+1450+1450+1450+400+1260= $36,550 (You can find better deals as well this is all list price from the net)
36,550 is parts added up (Rounded up) for an F150 that would absolutly KILL any raptor out there plus the suspension and steering would be stronger and more reliable and it would have things the raptor doesn't (Stronger steering, Adjustable bypasses, More travel, Hydrolic bump stops....). You could build a raptor imitation for MUCH cheaper. There are other things needed as well but those are needed on the raptor as well like Cage, Seats, harnesses and so on.
In the end it is not worth it (I think). The truck they follow on the offroad races to hype this thing is as raptor as the rest of the trucks are F150's. It has custom Foxs not the ones it is sold with and custom everything else just like every other race car.
The article says "Usually it’s over-design, jump it, break it, increase safety factor, try again. We took an engineering approach: Jump it, measure it and design it to those loads.” This bothered me because no doubt we (Public) will go beyond those measured amounts.
'05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
  #20 (permalink)
Old 11-03-2009, 04:07 PM
Last Online: 11-24-2009 04:11 PM
F22nrptr is on a distinguished road.
F22nrptr's Photo Albums
Originally Posted by H2O_MAN View Post
I'm not interested in everyone else following with their own, I just want TOYOTA to offer up a better Raptor.
Hahaha hell yea me too. My brother's been bashing my dad's 08 and my 05 ever since that thing showed up on the radar!
  #21 (permalink)
Old 11-03-2009, 04:08 PM
scottnmos's Avatar
E PLURIBUS UNUM
Dealer : Nye Frontier Toyota/Scion
2001 Toyota Tacoma Xtra Cab....SOLD,
2008 Toyota Tundra 5.7 4x4 SR5 Crew Max,
2004 Toyota Tundra 4.7 4x4 DC SR5-Sold,
1993 Toyota 4Runner SR5 Wheelin' Machine
Last Online: Yesterday 07:17 PM
scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor.
scottnmos's Photo Albums
Nice response... It's about time someone broke down the numbers behind the hype
  #22 (permalink)
Old 11-03-2009, 08:21 PM
NoKz's Avatar
Was I Speeding Officer?
Dealer : Penske Toyota
2005 Toyota Tundra
Last Online: 11-21-2009 05:05 PM
Images: 19
NoKz is a splendid one to behold. NoKz is a splendid one to behold. NoKz is a splendid one to behold.
Send a message via MSN to NoKz NoKz's Photo Albums
Saw one on the freeway the other day. Uglier than hell and I pulled up next to it. The dude looked up at me and I slammed on my gas to taunt him into a 50+ race. He looked over and didn't want to bite. I laughed and took off. Perhaps not enough confidence in it's performance area? I destroy Ford 5.4's all the time, so I don't blame him.
www.OutlawOffroad.com
- Tell Them John w/the Tundra Sent You!
Car Domain: www.cardomain.com/ride/3304446
  #23 (permalink)
Old 11-03-2009, 08:23 PM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 02:52 AM
Images: 4
Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One.
Mr. Creosote's Photo Albums
I suppose Ford deserves some credit for building something different, but I can't see a huge demand for street legal desert racer wannabes, especially today. Maybe their market researchers know something I don't.
Attention environmentalists, reduce emissions from this:
  #24 (permalink)
Old 11-03-2009, 09:18 PM
SE2000's Avatar
Dealer : Northway Motor Car Corp.
- Other -,
2008 Toyota Tundra DC Blue Streak
Last Online: Yesterday 08:31 PM
SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything.
SE2000's Photo Albums
Baja is not about 0 -60 . Have yet to see a tree in the sand. I think there are several non tundra owners with the same silly smirk thinking they got a kill off of me because I have outgrown the need to boost my "manhood" by pressing the peddle. I'll let them think they won something. Cannot figure what.
  #25 (permalink)
Old 11-04-2009, 01:46 PM
rockstate45's Avatar
Last Online: Today 01:56 AM
Images: 3
rockstate45 has done just about everything. rockstate45 has done just about everything. rockstate45 has done just about everything. rockstate45 has done just about everything. rockstate45 has done just about everything. rockstate45 has done just about everything. rockstate45 has done just about everything. rockstate45 has done just about everything. rockstate45 has done just about everything. rockstate45 has done just about everything. rockstate45 has done just about everything.
rockstate45's Photo Albums
Yeah, I too have outgrown the Tundra's power. It's great at first but once you get used to it (key words - used to it), it's not all that impressive. Sure you can squeal the tires from 20 roll and you can break 'em loose from a 40 in the rain, but what's that get you? Nothing.
I just like the sound of my Borla exhaust.... BSE, maybe that's something the Ford designers know about that you don't.... although, I keep reading rep comments about borla lmao.
-rockstate
"Mr. Policeman" by Brad Paisley
Hey, hey, Mr. Policeman
Bet I can drive faster than you can
Come on Tinker, let's have some fun
Go on shoot me with your radar gun
You look bored and I sure am
Catch me if you can
  #26 (permalink)
Old 11-04-2009, 09:51 PM
2003 Toyota Avalon G-Ma's car.,
2002 Toyota Tundra SR-5 AC 4x4 V8
Last Online: Yesterday 05:35 PM
Rrumbler is a splendid one to behold. Rrumbler is a splendid one to behold.
Rrumbler's Photo Albums
Talking Re: Can... will Toyota build something to compete with this?
They already do. But, that thing could be exciting to a Ford guy, I suppose.
Rrumbler - Wrenching and banging on stuff for over sixty years.
