Go Back   Toyota Tundra Forums : Tundra Solutions Forum > General Forums > Off-Topic
Old 10-19-2009, 12:35 AM
tinik's Avatar
Travel & camping is 2 much fun
Dealer : Cramer Toyota Scion of Venice
2006 Toyota Sequoia,
2001 Toyota Tundra Supercharged
Images: 51
tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One.
tinik's Photo Albums
Default no more snow? what do you think
I think Russians are out of their mind, Moscow Mayor Promises a Winter Without Snow - Yahoo! News What do you guys think?
2006 Toyota Sequoia Limited 4x4 w/ lxr package, 7008 navi, rear entartaiment system, 20" x-sp enkei.
2001 Toyota Tundra SR5 4x4 - TRD 9+Psi Supercharged, JBA Ceramic Headers, Walboro 255LPH Fuel Pump, 1UZ Rods, 20" x-sp enkei wheels, 7009 navi w/custom JBL wire harness + OEM XM/Sirus radio, drive by wire, and many other mods.
Old 10-19-2009, 12:37 AM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 09:09 PM
Images: 4
Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One.
Mr. Creosote's Photo Albums
Default Re: no more snow? what do you think
Doesn't matter Gene. No superchargers in Russia.
Attention environmentalists, reduce emissions from this:
Old 10-19-2009, 01:12 AM
tinik's Avatar
Images: 51
And YES, Moscow has a lot of rear wheel drive cars that are SC
You know what Mike.... my motor is in pieces for better internals, since I've bended few rods (run a little over 6,000 rpms with about 11 psi of boost)
Here is what you can compare to Lexus 1UZFE, 2UZFE and 3UZFE rod
I have 2uz motor and 2nd gen motors are 3ur
Old 10-19-2009, 01:29 AM
Images: 4
Well it looks like stronger rods are available.
Old 10-19-2009, 03:34 AM
Lazy Ace's Avatar
Mr. Magoo
Dealer : Capitol Toyota
2008 Toyota Prius Black as coal
Last Online: Today 04:41 AM
Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything.
Lazy Ace's Photo Albums
Points sent for stronger rods!
Old 10-19-2009, 02:19 PM
JRE56's Avatar
Dealer : Spirit Toyota
1997 Toyota Camry
Last Online: Today 05:44 PM
JRE56 is on a distinguished road.
JRE56's Photo Albums
Wouldn't this concrete mix eventually settle on people,buildings,cars,ground,etc. and cause a whole slew of problems when mixed with snow?What about inhaling this concrete?
Old 10-19-2009, 02:23 PM
Sanosuke's Avatar
Dealer : High River Toyota
2007 Toyota Tundra SR5 w/4x4
Last Online: Today 09:33 PM
Images: 8
Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor.
Send a message via ICQ to Sanosuke Send a message via AIM to Sanosuke Send a message via MSN to Sanosuke Send a message via Yahoo to Sanosuke Sanosuke's Photo Albums
Talking Re: no more snow? what do you think
Inhaling the concrete isn't a very good idea.. unless you plan on feeling a lot heavier in the chest.. that is!
Sanosuke!
Old 10-19-2009, 07:12 PM
tinik's Avatar
Images: 51
True
I just ordered new 8 Rods for early 1 uzfe, Full set of Gaskets, 20 Head Bolts (Everything from my local Dealer for less then $700)
At least it did not break block in pieces.
Old 10-20-2009, 07:41 AM
mudfuel07's Avatar
Dealer : Gatorland Toyota Scion
- Other - 07 Mako 29RLFW,
2007 Toyota FJ Cruiser The Wifey's
Last Online: Today 10:48 AM
Images: 18
mudfuel07 has blessed us with their presence. mudfuel07 has blessed us with their presence. mudfuel07 has blessed us with their presence.
mudfuel07's Photo Albums
I can't believe you got anything from Cramer that cheap, they've always tried to rake me over the coals when I bought anything there.
Pulling Mako 29RLFW 5'er
Old 10-20-2009, 02:53 PM
pistolpete's Avatar
Dealer : Crystal Toyota
2004 Toyota Tundra 4X4 SR5 Double Cab
Last Online: Today 10:02 PM
Images: 163
pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all.
pistolpete's Photo Albums
JRE56,
this "seeding" uses VERY small amounts...it is a catalyst and finely dispersed. In nearly all other cases, tiny grains of silver are used as seeds. But the NCAR group is using a mixture of sodium, magnesium and calcium chloride, and it appears this type of seeding works better than silver in drought stricken areas.
Before rain can form in a cloud, tiny specks of dust attract moisture from the surrounding area, growing into raindrops. Cloud seeding, basically, consists of adding additional specks of dust that are very proficient at coalescing with other droplets to form rain.
The seeds usually are released from an aircraft via pyrotechnic flares as the plane flies through the updraft below the cloud. Texas has 16 such aircraft, scattered around the state. The seeds are carried by the updraft up into the cloud, increasing in size as they gain moisture on the way up.
Research is showing that the type of catalyst and the timing at which it is applied during cloud formation are the most important factors....
So its not someone just dumping bags of cement out of an airplane
Pistol Pete
#1 COLTS fan!!!!
2004 Toyota Tundra Double Cab 4X4 (7844A), Phantom Grey Pearl, All weather guard package, fog lamps,keyless entry, 17" AA wheels, towing package, color-keyed overfenders, 4.1mm Limited Slip Diffy, Delux 3-in-1 JBL stereo, privacy glass, floor mats with sill protectors, bed extender
MODS- Line-X, Retrax, Onki nerf boards (part #328078), Wade vent visors (part #88401) , TracRac (rail # OL-21609), Ultimate Fly Fishing Rod transporter, Spin Caster Rod holder in bed, Recon bedlights fully adjustable w/"nightvision", HitchSafe, Weathertech floor liners (part #46030-1&2, grey), debadged, visors destickered, rear window stop disabled, dynolock/PL8500 power tailgate lock, tailgate protector mod with detachable floormat, Stebel Nautilus Compact Truck Air horn (300Hz), quick fist flashlight holder (all in photo gallery).....more custom suprises on the way!!
New members from the MidAtlantic (PA,OH,WV,VA,MD,DE,NY,NJ,DC) don't forget to check into the MidAtlantic Forum and introduce yourself!!!
Old 10-20-2009, 08:11 PM
tinik's Avatar
Images: 51
Cramer Toyota in general is the worst dealer, I've had experience with. Service Dept especially. As far as parts Dept, is the best in our area. Next time you have to go to service, ask for John Wood, and tell him that Gene send you there, and he will take care of you!
Originally Posted by pistolpete View Post
JRE56,
Wow, something new I've learned today
Thank you
