60,000 Mile Service for Civic
+ Reply to Thread
Results 1 to 7 of 7
Thread: 60,000 Mile Service for Civic
  1. #1
    Junior Member 03SilverSky's Avatar
    Join Date
    Nov 2003
    Location
    The Golden State
    Posts
    373
    Liked
    0 times
    Rep Power
    14
    Default 60,000 Mile Service for Civic
    I have a Civic due for its 60,000 mile service. My local Honda dealership wants $374 for the service. A local Toyota's/Honda's only shop wants $289. I used to have my 89 Toyota 4x4 seviced at that shop and the work seemed fine. As far as I can tell each shop will perform the same service.
    Will the dealership do anything special that you are aware of? Does the dealership plug into the ECU to make sure everything is running OK?
    Built 06/2003 SR5 Acc. Cab V8 Silver Sky Metallic 4x2
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Eddie's Avatar
    Join Date
    Jul 2000
    Location
    New Jersey
    Posts
    1,743
    Liked
    0 times
    Images
    32
    Rep Power
    25
    Quote Originally Posted by 03SilverSky
    I'm doubtful about using the scantool unless you have a check engine light on.
    They'll probably do cap/rotor/wires/spark plugs,PCV valve,change all fluids including coolant,and possibly a valve adjustment (new valve cover gasket included).
  4. #3
    Join Date
    Jul 2003
    Location
    Southeast
    Posts
    860
    Liked
    0 times
    Rep Power
    12
    Man, I'd put that $300 in the bank for my next car. My '94 tercel has almost 75K and has only seen gas, oil, brakes, batteries, tires, mostly by my dad or me. Not a one of the recommended toyota services. Drive it to 100-150K then sell and let the next guy worry about it.
  5. #4
    Veteran Member Brian M's Avatar
    Join Date
    Dec 2002
    Location
    Galveston, Texas
    Age
    46
    Posts
    919
    Liked
    2 times
    Rep Power
    13
    I believe that car has a interference engine. Change it.
    2011 Ford F150 Lariat 4x4 5.0L
    2013 Avalon Limited
  6. #5
    Join Date
    Nov 2003
    Location
    The Golden State
    Posts
    373
    Liked
    0 times
    Rep Power
    14
    Thread Starter
    Quote Originally Posted by Brian M
    That went right over my head???
  7. #6
    Join Date
    Jul 2000
    Location
    New Jersey
    Posts
    1,743
    Liked
    0 times
    Images
    32
    Rep Power
    25
    You don't need to do a Honda/Acura t-belt until 90,000 miles not 60K.
  8. #7
    Join Date
    Dec 2002
    Location
    Galveston, Texas
    Age
    46
    Posts
    919
    Liked
    2 times
    Rep Power
    13
    Some cars have an engine that allows the belt to break without doing any damage. In others (like the I-Force and many Honda and Nissan engines) once the belt breaks it causes the valves to collide with other engine parts making things not so pretty.
    2013 Avalon Limited
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
