Go Back   Toyota Tundra Forums : Tundra Solutions Forum > General Forums > Off-Topic
Old 01-02-2006, 07:22 AM
Toasted Coastie's Avatar
Locked in for life
Dealer : Toyota of Nashua
Last Online: 09-12-2009 06:14 PM
Toasted Coastie is on a distinguished road.
Toasted Coastie's Photo Albums
Arrow Help, hard drive problems?
How do you know when your hard drive is crapping the bed? I just wiped and rebooted my laptop with the system recovery disk, uninstalled all the stuff I didnt want, got halfway through installing the stuff I wanted, and it died on me. And this was the second time I went throught the process. I keep getting BIOS errors, and bad clusters when I do the check disk function.
I have wiped this laptop twice in 4 days. It's a Toshiba Satellite A75-S226, and its only a year and 1/2 old. I have a friggen sony thats 4 years old and has never crashed. This one has crashed at least once a day in the last two weeks, including after rebooting the image.
ok, the clicking noises started about 4 months ago. Just here and there. Then came the inability to boot back up from hybernation, then the crashes (blue screen saying computer has had a catastrophic failure in the BIOS and is now dumping memory) then the check disk results saying I had 40 orphaned files and 10 bad clusters, that would come up the same no matter how many times windows said that it fixed them.
I just want to make sure I'm not going to spend $130 for a new hard drive for no reason, and then who knows how much for an install, when it could be fixable.
Is my hard drive dying, or does this laptop just blow?
It is better to remain silent and have people wonder if you are an idiot, rather than to open your mouth and prove to everyone you are an idiot beyond all doubt. ~ Jim Rogers
Old 01-02-2006, 08:16 AM
Salty_Dog's Avatar
Assistant Administrator
Dealer : Toyota Of Stafford
2001 Toyota Tundra,
2002 Toyota Corolla
Last Online: Today 03:15 PM
Images: 578
Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything.
Send a message via Yahoo to Salty_Dog Salty_Dog's Photo Albums
Default Re: Help, hard drive problems?
If it is making clicking noises, then that is an indication of impending hardware failure. The clicking noise indicates a mechanical problem with the drive, and no amount of wiping/formatting/reinstalling is going to fix it.
If it were me, I'd bite the bullet and get a new drive.
If you know how to operate a screwdriver, you can install a hard drive in a laptop yourself. Remove the screw that holds it in, and pull out the drive cradle assembly. Usually four screws hold the drive itself into the cradle. Remove the old drive and install the new drive. Put it back in, reinsert the screw that hold the cradle in place and you are ready to rock.
-Cyberbilly
Microsoft Certified Professional.
Salty Dog
You've been..... TUNDRASTRUCK!
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Kenwood KCA-XM100V Satellite Radio Interface, Polk Audio db6501 component speakers (Front), Polk Audio db651s speakers (Rear), Profile AP740 4-channel amplifier, Rockford Fosgate 8” Punch subwoofer (x 2) in Q-Logic enclosure, Profile AP700M mono subwoofer amplifier, Audiovox ACA200W Rear-view camera, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Ornery Dog
Old 01-02-2006, 08:29 AM
Locked in for life
ok, cool.
Since you are microsoft certified, are these errors bad too?
found bad cluster File 28354\hiberfil.sys
found bad cluster file 22322\$n36E4~1\cryptui.dll
found bad cluster file 2051\windows\$NZZCO~1\ntoskrnl.exe
found bad cluster file 2834\hiberfil.sys
found bad cluster file 28499\system~1\_resto~\snapshot\_r62e7n1
these are usually the consitant ones on the check disk.
yesterday after rebooting off the system restore (wipe and reload) after downloading all the MS updates/service packs, and uninstalling things I do not use, I got the blue screen saying I had a catastrophic error in the BIOS, and that the computer was now dumping memory. I restarted, and the computer said I had recovered from it. But running the check disk, I got all the same errors again.
I'm going to have to assume that consistantly getting errors means it's on its way out. I just want to be completely sure before I drop the coin.
Old 01-02-2006, 10:18 AM
Last Online: 10-30-2009 05:06 PM
Images: 2
pcosens is on a distinguished road.
pcosens's Photo Albums
I concur w/ CyberBilly - never a good sign. HW failure is likely BUT . . . do you have an internal floppy drive? - is something trying to access this (if installed)? - look for the activity light. That often makes an annoying clicking sound along with a delay in system activity.
What Operating system? Turn off hibernation in the short term to eliminate this as an issue. O/S version does impact the viability of the hibernation function. Never been a fan of it myself.
This blue screen (BSOD) should have very specific text about the cause of the crash - hard to read, but often very useful. BIOS issues MAY indicate an underlying problem masked as a hard drive failure.
1 Does the BSOD happen on a restart or boot-up, or just when the system is on and idle, or only when accessing the hard drive (HD activity light will be on)? Only after recovery from hibernation?
2 Any virus issues? (Anti-virus installed and virus defenitions up to date?)
If NOT a drive failure I would look at BIOS compatibility issues w/ the hibernation function. Check the manufacturer's updates page for any BIOS upgrades available for your laptop - may be as simple as a BIOS upgrade.
good luck,
Paul
Oh - 15 years as a Systems Integration Specialist, Microsoft Platforms, I've spent a bit of time in the trenches as well . . .
Old 01-02-2006, 11:56 AM
42GAMI's Avatar
Dealer : Servco Auto Center
2004 Toyota Tundra Stepside
Last Online: 11-15-2009 09:49 AM
42GAMI is on a distinguished road.
42GAMI's Photo Albums My eBay
the only thing more important than the data on your computer is your time. $130 is a small price to pay vice spending hours upon hours trying to fix your hd. funky sounds comming from your hd is a good indicator its going to lunch if it hasnt already.
flip for the new hd and install it yourself. if you still get bsod errs, reset your bios. if you still have probs, get the latest flash bios update and check the cmos battery if it has one. if you have bios probs still you may have a bad floppy drive, cd drive , or other hardware device. last but not least, you might have a device conflict.
most hds have errs on it, even from the factory. with so many clusters on it its nearly imposible not to have any errs. kinda like an acceptable number of burnt pixels on a lcd flatscreen monitor. the o/s just marks tham as bad/unusable and skips it. kinda like putting a red cone next to a pothole so you dont drive over it.
MODS: (TRD Urban package) - tint, stereo, jack-in-the box antennae ball, and my middle finger.
... Find any spelling errors? Take it up with admin.
...... btw If I offend anyone, get over it. I know I will.
......... Panties are optional.
~ been there, done that, got the panties ~
Old 01-02-2006, 12:58 PM
Locked in for life
I bought a new one. It's being installed right now. I pick it up in an hour. Total cost, a little over 100. 30 to install, 80 (after rebate) for hard drive. Thats acceptable.
The BIOS blue screen would come on while accessing info on hard drive.
As soon as I get the computer back, I will install the image and go from there. We'll see what happens. Thanks everyone.
Oh yeah, I liked the beat my weenie sig. Some people are just too touchy feely these days.
Old 01-02-2006, 07:23 PM
Salty_Dog's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
Images: 578
ok, cool.
Any error is bad to some degree. Bad cluster errors are typical of a failing hard drive; it means that the OS is having trouble reading individual spots on the disk.
Salty Dog
Old 01-02-2006, 09:04 PM
Locked in for life
All better now, just getting it back to where I like it. Thanks everyone!
Old 01-10-2006, 10:53 AM
42GAMI's Avatar
after you get your system solid and just the way you want it. i reccomend you create a restore point (windows xp) and then make an image file with ghost or acronis, you can use it to recover later.
i always create 2 recovery disks, just in case the integrity of the media is lousy on either.
i usually partition and format my hard drive into 3 sections
c: primary o/s and apps
d: for data
e: for ghost image. less than 5gb.
my hp8000 laptop is done that way. sure if the hd goes south i loose everything, but if just the c: drive gets corrupted, i can ghost the e: image to the c: in a few keystrokes.
Donahoes, Deavers...problems, cust. service...?? ZPDSOBER Suspension & Axle 7 12-21-2005 10:58 PM
Bugs, TSB's, problems worked out on 06' Tacos??? paulphilly Tacoma 11 10-18-2005 02:22 PM
VSC - Limited Slip - 4 Wheel Drive question dtl2441 Engine & Drivetrain 2 04-20-2004 06:54 PM
hard shifting problems kpk Engine & Drivetrain 14 10-15-2003 07:55 AM
Drive Line / Ujoint findog1922 Engine & Drivetrain 2 03-10-2002 12:29 AM
