Garage door keeps opening back up!
+ Reply to Thread
Results 1 to 14 of 14
Thread: Garage door keeps opening back up!
  1. #1
    Join Date
    Dec 2005
    Location
    Boynton Beach, FL
    Posts
    871
    Liked
    82 times
    Rep Power
    1519
    Default Garage door keeps opening back up!
    When I hit the button to close my garage door it closes completly then opens back up. I usually have to close it two or three times before it will stop reversing itself. Anyone have any ideas on what I should check out?
    Ray Kane
    If you don't try, nothing happens
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Aug 2004
    Location
    College Station, TX
    Posts
    267
    Liked
    0 times
    Rep Power
    11
    Default Re: Garage door keeps opening back up!
    it might be pushing on the ground too hard and thinks it is hitting something and is going back up. there should be an adjustment to make it not go down so far/hard. the other thing that i have seen was on a garage door with insulation on it and the insulation was sticking out a little bit and when the door would close it would break the laser beam that senses if anything is under the door.
    just a couple ideas to look at
    hope it helps
  4. #3
    DJ
    DJ is offline
    Join Date
    Sep 2000
    Location
    Newcastle, OK
    Posts
    2,423
    Liked
    606 times
    Rep Power
    27934
    There are typically two adjustments that govern the closing of the door. One is how far the traveler on the opener moves. If it's trying to move too far, it'll try to close the door beyond the point where it's completely closed. Then the second adjustment comes into play, which detects that the door has hit an obstruction.
    Step one is to adjust the first adjustment so the door closes completely, but not more than "completely". Likely that will cure the problem, because the second adjustment can't come into play without an obstruction under the door unless the first adjustment is off.
    Step two is to adjust the second adjustment if it needs it. Place a piece of 2x4 on the floor under the door and close the door on it. The door should reverse when it hits the wood, and you can adjust it so that it does.
  5. #4
    Join Date
    Dec 2005
    Location
    Boynton Beach, FL
    Posts
    871
    Liked
    82 times
    Rep Power
    1519
    Thread Starter
    Makes sense
    Where do I find these adjustments? Any tricks to make the job easier?
    Ray Kane
  6. #5
    DJ
    DJ is offline
    Join Date
    Sep 2000
    Location
    Newcastle, OK
    Posts
    2,423
    Liked
    606 times
    Rep Power
    27934
    Quote Originally Posted by Ray Kane
    Makes sense
    It depends on the brand of opener.
    Chamberlain openers have the adjustments up on the drive unit, generally travel limit adjustments on the side and force adjustments on the rear. All it takes is a screwdriver. Chamberlain makes openers for Sears, Raynor, Liftmaster, Master Mechanic, and others.
    Genie openers have the force adjustments on the drive unit and the travel limit adjustments on the rail.
    You might find manuals to download at
  7. #6
    Join Date
    May 2005
    Location
    Tuscaloosa Alabama
    Age
    66
    Posts
    144
    Liked
    0 times
    Rep Power
    11
    Also check your electric eye beam. If it isn't lined up correctly the door will not stay shut because it thinks that something is tripping it.
  8. #7
    Join Date
    Feb 2002
    Location
    Silicon Valley, CA
    Posts
    1,802
    Liked
    2 times
    Rep Power
    15
    Quote Originally Posted by Bamataco1
    When this is the problem, you won't be able to close the door at all. It will open up almost as soon as it starts down.
    Alan
  9. #8
    Join Date
    Jan 2006
    Location
    Spanish Fork, UT
    Posts
    18
    Liked
    0 times
    Rep Power
    0
    Makes sense
    Garage doors are frustrating! My adjustment for the door is on the rail.... it's looks like a little tab that the screw drive hits to let the engine know when to stop. Easy to adjust if that's the case. Just move the tab closer to the unit
    Jerm
  10. #9
    DJ
    DJ is offline
    Join Date
    Sep 2000
    Location
    Newcastle, OK
    Posts
    2,423
    Liked
    606 times
    Rep Power
    27934
    Quote Originally Posted by germster1
    Nah, they smell and look like gold. Installing and servicing garage doors and openers is my brother's business. It's easy once you've learned how it's done.
  11. #10
    Supporter 42GAMI's Avatar
    Join Date
    Jun 2004
    Location
    808-state
    Posts
    1,677
    Liked
    0 times
    Rep Power
    15
    tell your wife or son, stop playing with the other remote inside the house. dont mess with you, its not funny.
    MODS: (TRD Urban package) - tint, stereo, jack-in-the box antennae ball, and my middle finger.
    ~ been there, done that, got the panties ~
  12. #11
    Join Date
    Dec 2005
    Location
    Boynton Beach, FL
    Posts
    871
    Liked
    82 times
    Rep Power
    1519
    Thread Starter
    I wish it were that simple
    Ray Kane
  13. #12
    DJ
    DJ is offline
    Join Date
    Sep 2000
    Location
    Newcastle, OK
    Posts
    2,423
    Liked
    606 times
    Rep Power
    27934
    You could simply call a pro. Ask for references from friends and co-workers and you'll likely find a recommendation from someone who was pleased with the work. A "tune-up" service call is fairly cheap, and I think that's all you need.
  14. #13
    Rookie jaycee's Avatar
    Join Date
    Feb 2002
    Location
    Garland, Texas
    Posts
    18
    Liked
    0 times
    Rep Power
    0
    Sometimes the change in temperature will affect the closing of my garage door. According to the manual that came with it , it is a normal thing. Mine is a Sears model.
  15. #14
    Junior Member monolithic's Avatar
    Join Date
    Aug 2002
    Location
    Central NJ
    Posts
    375
    Liked
    0 times
    Images
    17
    Rep Power
    13
    Post some pics of the controls (might be under a light cover on each side or on top) so we can see what you have.
    2004 Toyota Tundra V6 Reg Cab 2wd Auto (Phantom Gray)
    Options - Tilt wheel, Intermittent Wipers, AC, Mudflaps, Cold weather package, Bed liner (removed), Carpet floor mats, Trailer hitch receiver, Door sill protectors
    Mods - Cruise Control w/factory dash indicator, Hellwig Anti-Sway Bar, Chromatic Mirror w/Temp & Compass, Phantom Gray Door Edge Guards, PT Industries Raptor SS Nerf for Access Cab, Fog Lights w/Factory Head Lamp Switch; Great Covers velour seat cover, 2004 Reg Base Cab Cargo Light Mod (use factory switch, no light when door opened), 2004 Reg Base Cab Auto Headlight Off Disabled Mod (lights stay on when door opened); SR5 Chrome Wheel Arch Moldings; Chrome power & heated side mirrors w/factory heat switch;Burlwood control faceplate & door switch panels; Overhead console w/garage opener & Luxeon Star LEDs; Alpex #244 Chrome dual air horns - 118db - 405Hz/450Hz - 15A; Horn baffle removal mod; Rostra Radar Backup Sensors;Pilot PL-250 Backup 55w Lights; H4 Osram Silverstar Headlights; Enkei Brawn II alloys; 245/70/16 Revos; Power Outlet Mod; Ltd Visors w/lights; RainTracker rain sensor; Factory power windows; Manik tail light SS guards #925659SP; Power door locks (DEI relay module 451M); ATS grill;ARE MX camper shell (full side screens & w/o vista window); CompuStar 2W900FM(S) Remote Start/Keyless Entry/Ignition Auto Lock;Bed Carpet Kit w/Couch & Storage Boxes; Pop&Lock PL8500 Pwr Tailgate Lock; WeatherTech Mats, TRD LSD
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. synthetic oils - yes or no?
    By nhparrot in forum Engine, Intake, Exhaust, Induction
    Last Post: 06-10-2010, 03:43 PM
  2. How do you program the garage opener
    By TJBI in forum Highlander
    Last Post: 11-14-2005, 09:44 PM
  3. Back seat angle???
    By tracy stein in forum Interior & Exterior
    Last Post: 02-11-2005, 11:06 AM
  4. Truck finally back on the road!
    By BirdDog0 in forum Off-Roading
    Last Post: 08-21-2002, 08:29 AM
  5. Power sliding back window
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 03-28-2002, 10:17 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
