Re: 2003 Celica GT-S Cruise Control/ABS
Here are some PDF's to help check for codes in the ABS. Use the chart to get you in the approximate area of fault.
Post whatever code you find and we can help assist you from there.
Yes the ABS light will cancel the cruise, so will a brake warning light.
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
